Hi, I am trying to solve a fluid reconstruction problem and want to get some feedback on the code:
Helper functions: forward model and objective function
def forward(u0,V,total_steps,objective,storage,points,mask,mesh,loss_fn):
T = 10 # final time
num_steps = 10000 # number of time steps
mu = 0.001
nu = mu
rho = 1 # density
inflow = 'near(x[0], -1)'
outflow = 'near(x[0], 4)'
walls = 'near(x[1], -0.5) || near(x[1], 0.5)'
cylinder = 'on_boundary && not(near(x[0], -1)) && not(near(x[0], 4)) && not(near(x[1], -0.5)) && not(near(x[1], 0.5))'
Q = FunctionSpace(mesh, "Lagrange", 1)
V1 = FunctionSpace(mesh, "Lagrange", 1)
# Define inflow profile
inflow_profile = ('1', '0')
# Define boundary conditions
bcu_inflow = DirichletBC(V, Expression(inflow_profile, degree=2), inflow)
bcu_walls = DirichletBC(V, Constant((0, 0)), walls)
bcu_cylinder = DirichletBC(V, Constant((0, 0)), cylinder)
bcp_outflow = DirichletBC(Q, Constant(0), outflow)
bcu = [bcu_inflow,bcu_walls, bcu_cylinder]
bcp = [bcp_outflow]
p = TrialFunction(Q)
q = TestFunction(Q)
# Define functions for solutions at previous and current time steps
u1 = Function(V)
p1 = Function(Q)
f = Constant((0, 0))
k = Constant(dt)
nu = Constant(nu)
rho = Constant(rho)
# Define variational problem for step 1
F1 = inner(u - u0, v)*dx + k*inner(grad(u0)*u0, v)*dx + \
k*nu*inner(grad(u), grad(v))*dx - inner(f, v)*dx
a1 = lhs(F1)
L1 = rhs(F1)
a2 = inner(grad(p), grad(q))*dx
L2 = -(1/k)*div(u1)*q*dx
a3 = inner(u, v)*dx
L3 = inner(u1, v)*dx - k*inner(grad(p1), v)*dx
# Assemble matrices
A1 = assemble(a1)
A2 = assemble(a2)
A3 = assemble(a3)
# Use amg preconditioner if available
prec = "amg" if has_krylov_solver_preconditioner("amg") else "default"
# Use nonzero guesses - essential for CG with non-symmetric BC
parameters['krylov_solver']['nonzero_initial_guess'] = True
# Time-stepping
t = 0
for n in range(total_steps):
# Update current time
b1 = assemble(L1)
[bc.apply(A1, b1) for bc in bcu]
solve(A1, u1.vector(), b1, 'gmres', 'default')
b2 = assemble(L2)
[bc.apply(A2, b2) for bc in bcp]
[bc.apply(p1.vector()) for bc in bcp]
solve(A2, p1.vector(), b2, 'gmres', 'default')
b3 = assemble(L3)
[bc.apply(A3, b3) for bc in bcu]
solve(A3, u1.vector(), b3, 'gmres', 'default')
# Plot solution
# Update previous solution
u0.assign(u1)
if n%10==0:
d_observe = Function(V, name="data")
d_observe.vector()[:] = storage['observation'][n+1,:]
if objective is not None:
objective(u0, d_observe, n,points,loss_fn=loss_fn)
def objective_point_wise(storage, u=None, d_observe=None,idx=None,points=None,loss_fn="l2",Q=None,finalize=False,obversation_steps=None):
if finalize:
count = 0
for idx in range(obversation_steps.shape[0]):
step = obversation_steps[idx]
if idx==0:
loss = storage['functional'][step]
count = count + 1
if step>=len(storage['functional']):
continue
loss += storage['functional'][step]
count = count + 1
storage["loss"] = loss/count
return loss/count
if idx==0:
storage["functional"] = []
storage["estimate_field"]=[]
storage["gt_observation"]=[]
storage["gt_field"]=[]
storage["loss"] = 0
loss = 0
observation = [d_observe(p) for p in points]
prediction = [u(p) for p in points]
if loss_fn=="l2":
# storage["functional"].append(sum([(observation[i]-(prediction[i][0]**2+prediction[i][1]**2))**2 for i in range(len(points))])/len(points))
storage["functional"].append(sum([(observation[i][0]-prediction[i][0])**2+(observation[i][1]-prediction[i][1])**2 for i in range(len(points))])/len(points))
elif loss_fn=="l1":
storage["functional"].append(sum([(((observation[i]-prediction[i])**2)**0.5) for i in range(len(points))])/len(points))
Run optimization/solve inverse problem
observation,observed_coords,mask,_= get_observation(nodes,solution,observation_setup["timestep"])
storage = {"functional": [],'solution':solution,'observation':observation, "time": 0, "estimate_field": [], "gt_observation": [],'gt_field':[],'loss':0}
obj = lambda u, d, idx,observed_coords,loss_fn, Q: objective_point_wise(storage,u, d, idx,observed_coords,loss_fn, Q)
observation_setup = {"start_time":500,"timestep":10,"endtime":580}
obversation_steps = np.arange(observation_setup["endtime"]-observation_setup["start_time"])[0:observation_setup["endtime"]-observation_setup["start_time"]:observation_setup["timestep"]]
obversation_steps = np.floor(obversation_steps/observation_setup["timestep"]).astype(np.int)
# initialize u at 0
u= Function(V)
u.vector()[:] = 0
forward(u,V=V,total_steps=observation_setup["endtime"]-observation_setup["start_time"],
objective=obj,storage=storage,points=observed_coords,mask=mask,mesh=mesh,loss_fn=loss_fn)
control = Control(u)
J = objective_point_wise(storage, finalize=True,obversation_steps=obversation_steps)
print("J:{}".format(J))
Jhat = ReducedFunctional(J, control, eval_cb_post=eval_cb)
problem = MinimizationProblem(Jhat)
parameters = {'maximum_iterations': 100}
solver = IPOPTSolver(problem, parameters=parameters)
rho_opt = solver.solve()
