I am not entirely sure whether this is the correct category. In my Fenics Code I use avoided assembly to preassemble fixed parts of my problem like so:
def assemble_stiffness_matrices(trial1,trial2,test1,test2,measure,subdomain=None):
""" Assembly of stiffness matrices
Parameters
trial[1,2]: UFL TrialFunctions, the Legendremoments of the flux
test[1,2]: UFL TestFunctions, the test functions for the weak formulation
from the same functionspace as trial[1,2]
measure: UFL Measure, spatial measure to use in assembly of weak form
subdomain: int, identifier for subdomain, needs to be plain python int! If
not set, the whole domain is taken into account
Returns
K00, K02, K22: Assembled matrices of determined la backend, default is PETSc
if subdomain is not None:
a_K00 = inner(grad(trial1),grad(test1)) * measure(subdomain)
a_K20 = inner(grad(trial2),grad(test1)) * measure(subdomain)
a_K22 = inner(grad(trial2),grad(test2)) * measure(subdomain)
return assemble(a_K00), assemble(a_K20), assemble(a_K22)
Because I am interested in the solution spatially integrated over each subdomain I define the measure to be specific for each subdomain. When I look at the code generated by dijitso it only differs in ids for the different classes. So is there a way to use the function without the subdomain specification and still get results integrated over each subdomain, respectively, after the code is finished?
Besides the case with subdomain != None uses humongous amounts of RAM on FFC-compilation.
Thanks in advance for your help.
