I want to assemble the matrices of my weak form, I’m doing compressible flow and plastic fluid structure interaction, the variables are (p,u,T), which have 4 variables, then I write a function to assemble the weak form
from ufl_legacy import transposefrom Compute_DC import compute_DC_constants
from compute_SUPG import compute_tau_supgfrom fenics import *
import numpy as npdef assemble_weak_form(V_fluid, Y, Y_n, dt, A0_f, A1_f, A2_f, A1_sp, A2_sp,
K11, K12, K21, K22, A0_s, A1_s, A2_s,
markers, beta=1.0):
Assemble the weak form for FSI problem with 4x4 matrices
# Test and trial functions
W = TestFunction(V_fluid)
dY = TrialFunction(V_fluid) # For bilinear form# Get mesh info mesh = V_fluid.mesh() n = FacetNormal(mesh) h = CellDiameter(mesh) # Define measures dx = Measure('dx', domain=mesh) dx_s = Measure('dx', subdomain_data=markers, subdomain_id=2) dS = Measure('dS', domain=mesh) # Initialize bilinear and linear forms a = 0 # Bilinear form L = 0 # Linear form # Get gradients grad_dY = grad(dY) grad_W = grad(W) grad_Y = grad(Y) # 1. Mass terms # LHS (bilinear form) a += inner(W, dot(A0_f, dY)) * dx # Whole domain a -= inner(W, dot(A0_f, dY)) * dx_s # Subtract solid domain a += inner(W, dot(A0_s, dY)) * dx_s # Add solid domain mass # RHS (linear form) L += (1/dt)*inner(W, dot(A0_f, Y_n)) * dx # Whole domain L -= (1/dt)*inner(W, dot(A0_f, Y_n)) * dx_s # Subtract solid domain L += (1/dt)*inner(W, dot(A0_s, Y_n)) * dx_s # Add solid domain mass # 2. Convective terms # LHS conv_term = dot(A1_f, grad_dY[:, 0]) + dot(A2_f, grad_dY[:, 1]) a += inner(W, conv_term) * dx # Whole domain a -= inner(W, conv_term) * dx_s # Subtract solid domain # 3. Diffusive terms # LHS F_diff_x = dot(K11, grad_dY[:, 0]) + dot(K12, grad_dY[:, 1]) F_diff_y = dot(K21, grad_dY[:, 0]) + dot(K22, grad_dY[:, 1]) a -= inner(grad_W[:, 0], F_diff_x) * dx a -= inner(grad_W[:, 1], F_diff_y) * dx a += inner(grad_W[:, 0], F_diff_x) * dx_s a += inner(grad_W[:, 1], F_diff_y) * dx_s # 4. SUPG stabilization # Compute residual for current solution (RHS) F_diff_x_n = dot(K11, grad_Y[:, 0]) + dot(K12, grad_Y[:, 1]) F_diff_y_n = dot(K21, grad_Y[:, 0]) + dot(K22, grad_Y[:, 1]) div_F_diff = grad(F_diff_x_n)[:, 0] + grad(F_diff_y_n)[:, 1] Res_n = dot(A0_f, (Y - Y_n) / dt) + \ dot(A1_f, grad_Y[:, 0]) + dot(A2_f, grad_Y[:, 1]) - \ div_F_diff # LHS SUPG terms tau_SUPG = compute_tau_supg(dt, A1_sp, A2_sp, K11, K12, K21, K22, mesh) # Linearized residual for LHS Res_lin = dot(A0_f, dY / dt) + conv_term - (grad(F_diff_x)[:, 0] + grad(F_diff_y)[:, 1]) B_st = inner(dot(transpose(A1_f), grad_W[:, 0]) + dot(transpose(A2_f), grad_W[:, 1]), dot(tau_SUPG, Res_lin)) * dx B_st_s = inner(dot(transpose(A1_f), grad_W[:, 0]) + dot(transpose(A2_f), grad_W[:, 1]), dot(tau_SUPG, Res_lin)) * dx_s a += B_st - B_st_s # 5. DC stabilization K_DC = compute_DC_constants(h, Res_n, Y) a += inner(grad_W, dot(K_DC, grad_dY)) * dx a -= inner(grad_W, dot(K_DC, grad_dY)) * dx_s # 6. Solid domain terms a += inner(W, dot(A1_s, grad_dY[:, 0]) + dot(A2_s, grad_dY[:, 1])) * dx_s # 7. Interface terms a += beta * h * inner(jump(dot(grad_W, n)), jump(dot(grad(dY), n))) * dS # Assemble matrices A = assemble(a) b = assemble(L) return A, b
here, the K11 and other K_ij matrices are 44, and all matrices here are 44, then when I want to assemble the matrices, it says that
determinant_expr not implemented for shape (4, 4).
File "/home/a/Desktop/FluidStructure/main.py", line 258, in <module>
a, L = assemble_weak_form(V_fluid, solution_fluid, solution_fluid_n, dt,
File "/home/a/Desktop/FluidStructure/WeakForm.py", line 105, in assemble_weak_form
A = assemble(a)
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/assembling.py", line 202, in assemble
dolfin_form = _create_dolfin_form(form, form_compiler_parameters)
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/assembling.py", line 60, in _create_dolfin_form
return Form(form,
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/form.py", line 43, in __init__
ufc_form = ffc_jit(form, form_compiler_parameters=form_compiler_parameters,
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/jit/jit.py", line 50, in mpi_jit
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/jit/jit.py", line 100, in ffc_jit
File "/usr/lib/python3/dist-packages/ffc/jitcompiler.py", line 217, in jit
module = jit_build(ufl_object, module_name, parameters)
File "/usr/lib/python3/dist-packages/ffc/jitcompiler.py", line 130, in jit_build
module, signature = dijitso.jit(jitable=ufl_object,
File "/usr/lib/python3/dist-packages/dijitso/jit.py", line 165, in jit
header, source, dependencies = generate(jitable, name, signature, params["generator"])
File "/usr/lib/python3/dist-packages/ffc/jitcompiler.py", line 65, in jit_generate
code_h, code_c, dependent_ufl_objects = compile_object(ufl_object,
File "/usr/lib/python3/dist-packages/ffc/compiler.py", line 142, in compile_form
return compile_ufl_objects(forms, "form", object_names,
File "/usr/lib/python3/dist-packages/ffc/compiler.py", line 185, in compile_ufl_objects
analysis = analyze_ufl_objects(ufl_objects, kind, parameters)
File "/usr/lib/python3/dist-packages/ffc/analysis.py", line 89, in analyze_ufl_objects
form_datas = tuple(_analyze_form(form, parameters)
File "/usr/lib/python3/dist-packages/ffc/analysis.py", line 89, in <genexpr>
File "/usr/lib/python3/dist-packages/ffc/analysis.py", line 169, in _analyze_form
form_data = compute_form_data(form,
File "/usr/lib/python3/dist-packages/ufl_legacy/algorithms/compute_form_data.py", line 253, in compute_form_data
form = apply_algebra_lowering(form)
File "/usr/lib/python3/dist-packages/ufl_legacy/algorithms/apply_algebra_lowering.py", line 175, in apply_algebra_lowering
return map_integrand_dags(LowerCompoundAlgebra(), expr)
File "/usr/lib/python3/dist-packages/ufl_legacy/algorithms/map_integrands.py", line 46, in map_integrand_dags
return map_integrands(lambda expr: map_expr_dag(function, expr, compress),
File "/usr/lib/python3/dist-packages/ufl_legacy/algorithms/map_integrands.py", line 27, in map_integrands
mapped_integrals = [map_integrands(function, itg, only_integral_type)
File "/usr/lib/python3/dist-packages/ufl_legacy/algorithms/map_integrands.py", line 35, in map_integrands
return itg.reconstruct(function(itg.integrand()))
File "/usr/lib/python3/dist-packages/ufl_legacy/algorithms/map_integrands.py", line 46, in <lambda>
File "/usr/lib/python3/dist-packages/ufl_legacy/corealg/map_dag.py", line 36, in map_expr_dag
result, = map_expr_dags(function, [expression], compress=compress,
File "/usr/lib/python3/dist-packages/ufl_legacy/corealg/map_dag.py", line 99, in map_expr_dags
r = handlers[v._ufl_typecode_](v, *[vcache[u] for u in v.ufl_operands])
File "/usr/lib/python3/dist-packages/ufl_legacy/algorithms/apply_algebra_lowering.py", line 135, in inverse
return inverse_expr(A)
File "/usr/lib/python3/dist-packages/ufl_legacy/compound_expressions.py", line 143, in inverse_expr
return adj_expr(A) / determinant_expr(A)
File "/usr/lib/python3/dist-packages/ufl_legacy/compound_expressions.py", line 101, in determinant_expr
error("determinant_expr not implemented for shape %s." % (sh,))
File "/usr/lib/python3/dist-packages/ufl_legacy/log.py", line 158, in error
ufl_legacy.log.UFLException: determinant_expr not implemented for shape (4, 4).
how to solve it
