Get current spatial configuration of the mesh as ufl variable
Hello all,
I am quite new to FENiCSx so my problem could be very basic. How do i get the current configuration (basically the nodal coordinates) as a ufl.variable which can be then used to create the expressions in the bilinear weak form. Here’s the code that i am using to implement this:
from dolfinx import log, default_scalar_type
import pyvista
from dolfinx import nls
from dolfinx import fem, mesh, plot
# mesh domain:
L  = 0.5
Nx =  20
Ny =  20
# L = 20.0
msh = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([-2, -1]), np.array([2, 1])], [Nx, Ny], mesh.CellType.quadrilateral)
tdim = msh.topology.dim
## Assign function space to the mesh
# Build function space with Lagrange multiplier
V123 = ufl.FiniteElement("Lagrange", msh.ufl_cell(), 1, 3)  #finite element for discplacement variable
Vp = ufl.FiniteElement("Real", msh.ufl_cell(), 0)           # finite element space for lagrange multipliers
V   = fem.FunctionSpace(msh, ufl.MixedElement([V123,Vp,Vp,Vp,Vp,Vp,Vp]))                # mixed function space
v                        = ufl.TestFunction(V)   # create test function space
(v123,lm_lambda1,lm_lambda2,lm_lambda3,lm_mu1,lm_mu2,lm_mu3)   = ufl.split(v)
dy                      = ufl.TrialFunction(V)
(dy123,dlm_lambda1,dlm_lambda2, dlm_lambda3,dlm_mu1,dlm_mu2,dlm_mu3) = ufl.split(dy)
x_ref                       = fem.Function(V, name="displacement")
# split the function into u_ref (displacement variable) and other lagrange multiplier variables
(u_ref,lambda1_ref,lambda2_ref, lambda3_ref,mu1_ref,mu2_ref,mu3_ref)     = ufl.split(x_ref)
print(x_ref.x.array.shape)
X0_ref = ufl.SpatialCoordinate(msh)
x0_current = ufl.variable(X0_ref + u_ref)   # current coordinates = reference_coordinate + displacement
Error that i get is as follows:
(441,)
  File "/home/.../fenics_try.py", line 83, in <module>
    x0_current = ufl.variable(X0_ref+u_ref)
  File "/home/.../miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ufl/exproperators.py", line 204, in _add
    return Sum(self, o)
  File "/home/.../miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ufl/algebra.py", line 41, in __new__
    raise ValueError("Can't add expressions with different shapes.")
ValueError: Can't add expressions with different shapes.
Can someone help we this?
Thanks
Please note that Real-spaces are currently not supported in DOLFINx.
As far as I can understand your question, would x = ufl.SpatialCoordinate(mesh) give you the coordinate of your current configuration (at quadrature point)?
