Hello all, I am trying to incorporate elasticity terms in the chemical potential equation. I have added term3 and term4 in code provided below in the Cahn Hilliard expression. If I remove term3 and term4, solver is working perfectly. I am getting the error meesage “Applying nonlinear operator Power to expression depending on form argument v_1”.
Can someone please help me to figure out the solver issue, I guess I have to modify the Non-linear Newton solver to accomodate elasticity terms.
Code
comm = MPI.COMM_WORLD
msh = create_unit_square(MPI.COMM_WORLD, 96,96 , CellType.triangle)
# finite element function space
element_u = basix.ufl.element("Lagrange", msh.basix_cell(), degree=1, shape=(msh.geometry.dim,))
V = fem.functionspace(msh, element_u)
# Define the state
u = ufl.TrialFunction(V)
# Domain measure.
dx = ufl.Measure("dx", domain=msh)
# cahn hilliard function space
lmbda = 1.0e-02 # surface parameter
dt = 5.0e-08 # time step
theta = 1 # time stepping family, e.g. theta=1 -> backward Euler, theta=0.5 -> Crank-Nicholson
P1 = basix.ufl.elementelement("Lagrange", msh.basix_cell(), 1, dtype=default_real_type)
ME = fem.functionspace(msh, mixed_element([P1, P1]))
q1, v1 = ufl.TestFunctions(ME)
cu = Function(ME) # current solution
cu0 = Function(ME) # solution from previous converged step
# Split mixed functions
c, cmu = ufl.split(cu)
c0, cmu0 = ufl.split(cu0)
# initialize your concentrations
# Zero u
cu.x.array[:] = 0.0
# Interpolate initial condition
rng = np.random.default_rng(42)
cu.sub(0).interpolate(lambda x: 0.63 + 0.02 * (0.5 - rng.random(x.shape[1])))
cu.x.scatter_forward()
c = ufl.variable(c)
f = 100 * c**2 * (1 - c) ** 2
dfdc = ufl.diff(f, c)
# mu_(n+theta)
mu_mid = (1.0 - theta) * cmu0 + theta * cmu
# define the constants for elasticity
Ep = 3.3
Epo = 3.1
E = c*Epo + (1-c)*Ep
nu = 0.3
mu = E / (2.0 * (1.0 + nu))
# Plane strain definition
lmbda = E * nu / ((1.0 + nu) * (1.0 - 2.0 * nu))
# Identity tensor
I = ufl.Identity(2)
# Weak form components
F0 = (ufl.inner(c, q1) - ufl.inner(c0, q1) +
dt * ufl.inner(ufl.grad(mu_mid), ufl.grad(q1))) * ufl.dx
# Nonlinear terms
eps_u = ufl.sym(ufl.grad(u)) # Assuming u is defined elsewhere
trace_eps = ufl.tr(eps_u)
term3 = inner((nu * (Epo - Ep) * (trace_eps**2) / (2 * (1 + nu) * (1 - 2 * nu))), v1) *dx
term4 = inner(((Epo - Ep) / (2 * (1 + nu))) * ufl.tr(eps_u * eps_u), v1) * dx
# Weak form F1
F1 = inner(mu, v1) * dx - inner(dfdc, v1) * dx - lmbda * inner(grad(c), grad(v1)) * dx - term3 - term4
# Total weak form
F2 = F0 + F1
# Create nonlinear problem and Newton solver
problem = NonlinearProblem(F2, cu)
solver.rtol = np.sqrt(np.finfo(default_real_type).eps) * 1e-5
solver.max_it = 200 # Maximum number of iterations
# We can customize the linear solver used inside the NewtonSolver
# modifying the PETSc options
ksp = solver.krylov_solver
opts = PETSc.Options() # type: ignore
sys = PETSc.Sys() # type: ignore
# For factorisation prefer superlu_dist, then MUMPS, then default
if sys.hasExternalPackage("superlu_dist"):
opts[f"{option_prefix}pc_factor_mat_solver_type"] = "superlu_dist"
elif sys.hasExternalPackage("mumps"):
ksp.setFromOptions()
