Handling Function returns from variational equations
Hey all,
How are Function values handled when solving the variational equation?
For example if we consider the Hyperelasticty Tutorial:
u = fem.Function(V)
# Spatial dimension
d = len(u)
# Identity tensor
I = ufl.variable(ufl.Identity(d))
# Deformation gradient
F = ufl.variable(I + ufl.grad(u))
# Right Cauchy-Green tensor
C = ufl.variable(F.T * F)
Ic = ufl.variable(ufl.tr(C))
J = ufl.variable(ufl.det(F))
# Elasticity parameters
E = default_scalar_type(1.0e4)
nu = default_scalar_type(0.3)
mu = fem.Constant(domain, E / (2 * (1 + nu)))
lmbda = fem.Constant(domain, E * nu / ((1 + nu) * (1 - 2 * nu)))
psi = (mu / 2) * (Ic - 3) - mu * ufl.ln(J) + (lmbda / 2) * (ufl.ln(J))**2
# Stress
# Hyper-elasticity
P = ufl.diff(psi, F)
ds = ufl.Measure('ds', domain=domain, subdomain_data=facet_tag, metadata=metadata)
# Define form F (we want to find u such that F(u) = 0)
F = ufl.inner(ufl.grad(v), P) * dx - ufl.inner(v, B) * dx - ufl.inner(v, T) * ds(2)
Is it possible to write something similar to the following that works:
class MaterialCoordinates():
        # (0): Defining rotation
        def __init__(self, rot=ROT):
            self.rot = ROT
        # (1): Rotate coordinates into new field
        def eval(self, x):
            self.xMat = np.cos(self.rot) * x[0] + np.sin(self.rot) * x[1]
            self.yMat = -np.sin(self.rot) * x[0] + np.sin(self.rot) * x[1]
            self.zMat = x[2]
            return (self.xMat, self.yMat, self.zMat)
matCoords = MaterialCoordinates()
u_mat = matCoords.eval(x=u)
F = ufl.variable(I + ufl.grad(u_mat))
Before the earlier lines so that the deformation gradient is with respect to a rotated coordinate system? i.e. how can I interact with outputs of u on each iteration to change calculation of F?
Any reason you can’t use something like
rot = np.pi / 2
mat_x = ufl.cos(rot) * x[0]
mat_y = ufl.sin(rot) * x[1]
mat_z = x[2]
mat = ufl.as_vector((mat_x, mat_y, mat_z))
If you can’t use it, please post a complete code (ref Read before posting: How do I get my question answered?), because no-one can run what you wrote, and thus I couldn’t even test the snippet that I sent you.
Hey @francesco-ballarin, I appreciate the response. What you provided is fine for a ufl.SpatialCoordinte(mesh) but my question is regarding u (u = fem.Function(V)) as the output of the Hyperelasticity Tutorial.
I’m interested in if I can conduct a similar operation to my snippet (or yours) on u to convert it into a different coordinate scheme before calculating F or other kinematic variables (i.e. C, E).
The code of interest is the tutorial code, but per completeness here is a MWE edited copy with my snippet inserted which produces an error:
from dolfinx import log, default_scalar_type, io
import pyvista
from dolfinx import nls
from dolfinx import fem, mesh, plot
L = 20.0
domain = mesh.create_box(MPI.COMM_WORLD, [[0.0, 0.0, 0.0], [L, 1, 1]], [20, 5, 5], mesh.CellType.hexahedron)
V = fem.VectorFunctionSpace(domain, ("Lagrange", 2))
def left(x):
    return np.isclose(x[0], 0)
def right(x):
    return np.isclose(x[0], L)
# Concatenate and sort the arrays based on facet indices. Left facets marked with 1, right facets with two
marked_values = np.hstack([np.full_like(left_facets, 1), np.full_like(right_facets, 2)])
facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
u_bc = np.array((0,) * domain.geometry.dim, dtype=default_scalar_type)
left_dofs = fem.locate_dofs_topological(V, facet_tag.dim, facet_tag.find(1))
bcs = [fem.dirichletbc(u_bc, left_dofs, V)]
B = fem.Constant(domain, default_scalar_type((0, 0, 0)))
u = fem.Function(V)
# Spatial dimension
d = len(u)
# Identity tensor
        def __init__(self, rot=np.pi/4):
            self.rot = np.pi/4
        def eval(self, x):
            self.zMat = x[2]
# Stress
# Hyper-elasticity
problem = NonlinearProblem(F, u, bcs)
solver = NewtonSolver(domain.comm, problem)
# Set Newton solver options
solver.atol = 1e-8
solver.rtol = 1e-8
num_its, converged = solver.solve(u)
if converged:
    print(f"Converged in {num_its} iterations.")
    print(f"Not converged after {num_its} iterations.")
# += Export
with io.VTXWriter(MPI.COMM_WORLD, "test.bp", u, engine="BP4") as vtx:
    vtx.write(0.0)
    vtx.close()
WARNING:py.warnings:/Users/murrayla/Documents/main_PhD/FEniCSx/FEniCSx/Material_Field/test.py:14: DeprecationWarning: This method is deprecated. Use FunctionSpace with an element shape argument instead
  File "/Users/murrayla/Documents/main_PhD/FEniCSx/FEniCSx/Material_Field/test.py", line 65, in <module>
  File "/Users/murrayla/anaconda3/envs/fenicsx-env/lib/python3.11/site-packages/ufl/operators.py", line 345, in grad
    f = as_ufl(f)
  File "/Users/murrayla/anaconda3/envs/fenicsx-env/lib/python3.11/site-packages/ufl/constantvalue.py", line 501, in as_ufl
    raise ValueError(
ValueError: Invalid type conversion: (Sum(Product(FloatValue(0.7071067811865476), Indexed(Coefficient(FunctionSpace(Mesh(blocked element (Basix element (P, hexahedron, 1, gll_warped, unset, False), (3,)), 0), blocked element (Basix element (P, hexahedron, 2, gll_warped, unset, False), (3,))), 0), MultiIndex((FixedIndex(0),)))), Product(FloatValue(0.7071067811865475), Indexed(Coefficient(FunctionSpace(Mesh(blocked element (Basix element (P, hexahedron, 1, gll_warped, unset, False), (3,)), 0), blocked element (Basix element (P, hexahedron, 2, gll_warped, unset, False), (3,))), 0), MultiIndex((FixedIndex(1),))))), Sum(Product(FloatValue(-0.7071067811865475), Indexed(Coefficient(FunctionSpace(Mesh(blocked element (Basix element (P, hexahedron, 1, gll_warped, unset, False), (3,)), 0), blocked element (Basix element (P, hexahedron, 2, gll_warped, unset, False), (3,))), 0), MultiIndex((FixedIndex(0),)))), Product(FloatValue(0.7071067811865475), Indexed(Coefficient(FunctionSpace(Mesh(blocked element (Basix element (P, hexahedron, 1, gll_warped, unset, False), (3,)), 0), blocked element (Basix element (P, hexahedron, 2, gll_warped, unset, False), (3,))), 0), MultiIndex((FixedIndex(1),))))), Indexed(Coefficient(FunctionSpace(Mesh(blocked element (Basix element (P, hexahedron, 1, gll_warped, unset, False), (3,)), 0), blocked element (Basix element (P, hexahedron, 2, gll_warped, unset, False), (3,))), 0), MultiIndex((FixedIndex(2),)))) can not be converted to any UFL type.
Then just use u instead of x = ufl.SpatialCoordinate(mesh) in my snippet above.
Hey @francesco-ballarin, great. much more elegant than I expected. Thank you.
