Heat Equation with Varying Kappa
#! /usr/bin/env python3
def heat_steady_01 ( ):
#*****************************************************************************80
heat_steady_01, 2D steady heat equation on a rectangle, constant K.
Discussion:
Del K Del U = 0 in Omega
U = 10 on dOmegaTop
U = 100 on dOmega - dOmegaTop
Omega = rectangle with corners (0.0, 0.0 ) and ( 5.0, 1.0 ).
K = 1 (thermal diffusivity)
Licensing:
This code is distributed under the GNU LGPL license.
Modified:
19 October 2018
Author:
John Burkardt
MESH:
The region is a rectangle with corners (0.0, 0.0 ) and ( 5.0, 1.0 ).
The mesh uses 50 horizontal and 10 vertical divisions.
sw = Point ( 0.0, 0.0 )
ne = Point ( 5.0, 1.0 )
mesh = RectangleMesh ( sw, ne, 50, 10 )
FUNCTION SPACE:
piecewise linear Lagrange functions.
V = FunctionSpace ( mesh, “Lagrange”, 1 )
BOUNDARY CONDITIONS:
BC_TOP: Along the top, we impose U=10.
BC_SIDE: Along the bottom and sides, U=100.
Combine these conditions as “BC”.
y_top = 1.0
u_top = 10.0
def on_top ( x, on_boundary ):
return ( y_top - DOLFIN_EPS <= x[1] )
bc_top = DirichletBC ( V, u_top, on_top )
u_side = 100.0
def on_side ( x, on_boundary ):
return ( on_boundary and x[1] < y_top - DOLFIN_EPS )
bc_side = DirichletBC ( V, u_side, on_side )
bc = [ bc_top, bc_side ]
TRIAL and TEST FUNCTIONS:
u = TrialFunction ( V )
v = TestFunction ( V )
BILINEAR and LINEAR FORMS:
k = 1
def k ( x ):
value = conditional ( le ( x[0], 0.75 ), 1.0, 4.0 )
return value
k = Expression ( ‘1 + x[0]’, degree = 0 )
k = Expression ( ‘1’, degree = 0 )
Auv = k * inner ( grad ( u ), grad ( v ) ) * dx
f = Constant ( 0.0 )
Lv = f * v * dx
SOLVE:
Solve the variational problem a(u,v)=l(v) with boundary conditions.
w = Function ( V )
solve ( Auv == Lv, w, bc )
Plot the solution W.
plot ( w, title = ‘heat_steady_01’ )
plu=plot(w)
plt.colorbar(plu)
filename = ‘heat_steady_01.png’
plt.savefig ( filename )
print ( “Saving graphics in file ‘%s’” % ( filename ) )
plt.close ( )
Terminate.
return
def heat_steady_01_test ( ):
heat_steady_01_test tests heat_steady_01.
Licensing:
Modified:
21 October 2018
Author:
John Burkardt
import time
print ( time.ctime ( time.time() ) )
Report level = only warnings or higher.
level = 30
set_log_level ( level )
print ( ‘’ )
print ( ‘heat_steady_01_test:’ )
print ( ’ FENICS/Python version’ )
print ( ’ 2D steady heat equation in a rectangle.’ )
heat_steady_01 ( )
Terminate.
print ( ‘’ )
print ( ’ Normal end of execution.’ )
print ( ‘’ )
return
if ( name == ‘main’ ):
Please format your post with 3x` encapsulation, so that your post becomes readable. Please also add a question, and a potential error message if you obtain one. Follow the guidelines in: Read before posting: How do I get my question answered?
