How can I reproduce the mesh used in the magnetostatic example?
I have tried to reproduce the nice mesh shown in Fig. 4.3 from
Solving PDEs in Python The FEniCS Tutorial I - p. 103 (109):
I have used the provided code:
from math import sin, cos, pi
a = 1.0 # inner radius of iron cylinder
b = 1.2 # outer radius of iron cylinder
c_1 = 0.8 # radius for inner circle of copper wires
c_2 = 1.4 # radius for outer circle of copper wires
r = 0.1 # radius of copper wires
R = 5.0 # radius of domain
n = 10 # number of windings
# Define geometry for background
domain = Circle(Point(0, 0), R)
# Define geometry for iron cylinder
cylinder = Circle(Point(0, 0), b) - Circle(Point(0, 0), a)
# Define geometry for wires (N = North (up), S = South (down))
angles_N = [i*2*pi/n for i in range(n)]
angles_S = [(i + 0.5)*2*pi/n for i in range(n)]
wires_N = [Circle(Point(c_1*cos(v), c_1*sin(v)), r) for v in angles_N]
wires_S = [Circle(Point(c_2*cos(v), c_2*sin(v)), r) for v in angles_S]
# Set subdomain for iron cylinder
domain.set_subdomain(1, cylinder)
# Set subdomains for wires
for (i, wire) in enumerate(wires_N):
    domain.set_subdomain(2 + i, wire)
for (i, wire) in enumerate(wires_S):
    domain.set_subdomain(2 + n + i, wire)
# Create mesh
mesh = generate_mesh(domain, 32)
and visualised the besh:
plot(mesh)
plt.xlim(-1.6, 1.6)
plt.ylim(-1.6, 1.6)
but results are disappointing:
Mshr.3
How can I reproduce the mesh? Also, is it possible to generalise that approach to 3D meshes?
You can try the following
wires_N = [Circle(Point(c_1*cos(v), c_1*sin(v)), r, 100) for v in angles_N]
wires_S = [Circle(Point(c_2*cos(v), c_2*sin(v)), r, 100) for v in angles_S]
# Create mesh
plot(mesh)
The additional parameter in the Circle constructor defines the number of segments for the boundary approximation. The default seems to be set to 32 though, so i do not know why it does not work properly when you do not set the parameter.
To generalize this approach to 3D, i would strongly suggest using external sotware such as pygmsh/gmsh. This is mostly due to the fact that the support for mshr in the later years have become very limited.
Thanks, it works.
In my version of dolfin (2018.1.0) segments defaults to 0. By setting it to 32 I got:
Mshr.3
On the visualization part check out vtkplotter shorcut function plot():
