How can I update FENICS from 0.7 to 0.9? Do I need to create another virtual environment?
I am a beginner of FENICS and would like to update myself on FENICS.
You would need to explain how you installed FEniCSx in the first place.
As there are many ways of doing it, the solution will depend on this.
Thank you for your response
I created the environment on both Windows and Linux systems, using wsl+ubuntu+naconda+vscode+paraview, following the installation instructions on the official website.
Create a new conda environment, and install fenics-dolfinx in it: https://anaconda.org/conda-forge/fenics-dolfinx
Thank you very much for your answer. The environment problem has troubled me for a long time. If I install GMSH, PANDAS or PYBISTA and other packages, should I use pip install or conda install?
In general, I’d recommend installing what you can with conda first and then use pip for any other packages after. For example, you could do something like
conda create -n fenicsx-env
conda activate fenicsx-env
conda install -c conda-forge fenics-dolfinx mpich pyvista matplotlib
conda install -c anaconda scipy
pip install gmsh
without any problems.
Please note that gmsh is also on conda, and is always recommended to use conda-packages, if they are available, to avoid binary mismatch. Of course, if a library is not on conda, then using pip install is the only option
