Creating conda env for older versions of fenics
Hi
I would like to ask if it is possible to build a conda env for fenics using an older version of fenics e.g. 2016.1.0. I have some code that I inherited and my pre-existing pipeline works pretty well for 2016.1.0, so if I could build that conda env on my local and work from there, that would be really helpful!
Thanks!
You can specify the version of the package with conda. To create the environment and install fenics 2016.1.0 you can use the following command:
conda create -n fenics2016 -c conda-forge fenics=2016.1.0
Hi! So sorry for the delay. I seem to be having issues with such an installation:
Collecting package metadata (repodata.json): done
Solving environment: failed
UnsatisfiableError: The following specifications were found to be incompatible with each other:
Package mpich conflicts for:
fenics=2016.1.0 -> mpich
Package six conflicts for:
fenics=2016.1.0 -> six
Package python conflicts for:
fenics=2016.1.0 -> python[version='2.7.*|3.4.*|3.5.*']
Package petsc conflicts for:
fenics=2016.1.0 -> petsc=3.7
Package petsc4py conflicts for:
fenics=2016.1.0 -> petsc4py=3.7
Package zlib conflicts for:
fenics=2016.1.0 -> zlib=1.2
Package ply conflicts for:
fenics=2016.1.0 -> ply
Package boost conflicts for:
fenics=2016.1.0 -> boost=1.61
Package gcc conflicts for:
fenics=2016.1.0 -> gcc
Package eigen conflicts for:
fenics=2016.1.0 -> eigen
Package swig conflicts for:
fenics=2016.1.0 -> swig[version='>=3']
Package cmake conflicts for:
fenics=2016.1.0 -> cmake
Package sympy conflicts for:
fenics=2016.1.0 -> sympy
Package ptscotch conflicts for:
fenics=2016.1.0 -> ptscotch
Package numpy conflicts for:
fenics=2016.1.0 -> numpy
Package slepc4py conflicts for:
fenics=2016.1.0 -> slepc4py=3.7
Package pkg-config conflicts for:
fenics=2016.1.0 -> pkg-config
Package slepc conflicts for:
fenics=2016.1.0 -> slepc=3.7
I suspect this is an issue with conda and ill look it up and post back when I figure it out.
You also have to specify the version of the other packages you are working with, e.g.
conda create -n fenics2016 -c conda-forge fenics=2016.1.0 python=3.5
Had the same problem with FEniCS 2017 and had to try out versions of every package I wanted to use. Hope that helps.
