Error in solving heat equation
Hi all,
I am testing dolfinx and try to convert some codes from dolfin to new version. I modified some of the tutorials (e.g. A nonlinear Poisson equation — FEniCSx tutorial) I want to solve the stationary heat equation - \nabla \cdot (\kappa \cdot \nabla T) = 0 with \kappa the conduction tensor and T the temperature. \kappa varies depending on the subdomain.
The error occurs in the line
n, converged = solver.solve(T)
with Did you forget to '#include <pybind11/stl.h>'? Or <pybind11/complex.h>, <pybind11/functional.h>, <pybind11/chrono.h>, etc. Some automatic conversions are optional and require extra headers to be included when compiling your pybind11 module.
Here is my MWE:
''' Thermal Quasistatic Problem  -> Test for implementing in FenicsX'''
# Packages
from dolfinx import fem, mesh, io, nls, log
from dolfinx.fem import FunctionSpace, VectorFunctionSpace, TensorFunctionSpace, Function, dirichletbc, locate_dofs_geometrical, form
from ufl import grad, div, dx, ds, dot, inner, FacetNormal, Measure, TrialFunction, TestFunction, FiniteElement, lhs, rhs, derivative
## Mesh
meshFile = "RVE_2D_f03_Circle_fenics"                         # mesh file name
with XDMFFile(MPI.COMM_WORLD, meshFile+"_mesh.xdmf", "r") as xdmf:
    domain = xdmf.read_mesh(name="Grid")
    ct = xdmf.read_meshtags(domain, name="Grid")                # cell tags
domain.topology.create_connectivity(domain.topology.dim, domain.topology.dim-1)
with XDMFFile(MPI.COMM_WORLD, meshFile+"_facets.xdmf", "r") as xdmf:
    ft = xdmf.read_meshtags(domain, name="Grid")                # facet tags
# Different surfaces
dx = Measure('dx', domain=domain, subdomain_data=ct)
# number of cells
num_cells = domain.topology.index_map(domain.topology.dim).size_local
## Parameters
S = TensorFunctionSpace(domain, ("DG", 0))
kappa = Function(S)
block_size_s = S.dofmap.index_map_bs
for i in range(num_cells):
    if ct.values[i] == 1: # matrix
        kappa.x.array[[i*block_size_s, i*block_size_s+1, i*block_size_s+2, i*block_size_s+3]] = [2, 0, 0, 1]
    elif ct.values[i] == 2: # inclusions
        kappa.x.array[[i*block_size_s, i*block_size_s+1, i*block_size_s+2, i*block_size_s+3]] = [5, 0, 0, 5]
## Element, FunctionSpace and Functions
# Element
P1 = FiniteElement("CG", domain.ufl_cell(), 1)
element = P1
# FunctionSpace
V = FunctionSpace(domain, element)
#Test- und Trial-Functions
dfunc = TrialFunction(V)
T  = Function(V)
dT = TestFunction(V)
## Boundary Conditions
T_left = 273.0 # K
T_right = 310.0 # K
def left(x):
    return np.isclose(x[0], domain.geometry.x.min())
def right(x):
    return np.isclose(x[0], domain.geometry.x.max())
fdim = domain.topology.dim -1
marked_values = np.hstack([np.full_like(left_facets, 3), np.full_like(right_facets, 4)])
facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
left_dofs  = fem.locate_dofs_topological(V, facet_tag.dim, facet_tag.find(3))
right_dofs = fem.locate_dofs_topological(V, facet_tag.dim, facet_tag.find(4))
bc_left  = [dirichletbc(ScalarType(T_left), left_dofs, V)]
bc_right = [dirichletbc(ScalarType(T_right), right_dofs, V)]
bcs = [bc_left, bc_right]
## variational problem
eqn = dot(dot(kappa, grad(T)), grad(dT)) * dx
Jac = derivative(eqn, T, dfunc)
problem = fem.petsc.NonlinearProblem(eqn, T, bcs=bcs, J = Jac)
solver  = nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
assert(converged)
I know that this is actually a linear problem. However, I just wanted to do it like that to have a working example for nonlinear cases. In addition, it also does not work with a linear solver.
Here iare the mesh files: Cloudstore
Thank you for your help.
I’m not at a computer, but I guess the issue here is that bcs should be a list, not a list of lists
You are right - now it works. Thank you for your fast answer!
