hi everyone,
i need to perform many monte carlo simulation and is it possible for FEniCS to achieve parallel calculation?
hi everyone,
If you want to distribute one code (with one input) over multiple processors, you can use mpirun -n 2 python3 program.py to run the program on two processors.
If you would like to run the same code, with different inputs, you can use concurrent.futures.
