How to apply a load on a single point or a node
E.vector()[:] = 2
E.vector()[pos]=5
would assign the value 5 the cell with index pos and 2 to all other cells
Hi Dokken,
Thank you very much.
I am getting an error in a readable file that I am not understanding.
Code
msh = meshio.read("/home/pierre/Desktop/GMSH1/carre.msh")
for cell in msh.cells:
    triangle_cells = cell.data
    if key == "triangle":
mesh =meshio.Mesh(points=msh.points,
meshio.write("test.xdmf",mesh)
E = 2.1e11    #p[0]
nu = 0.3    #p[1]
beta = (E)/(1-(nu*nu))
C = as_matrix([[beta, beta*nu, 0],[beta*nu, beta, 0],[0, 0, beta*(1-nu)/2]])
def eps(v):
    return sym(grad(v))
def strain2voigt(e):
    """e is a 2nd-order tensor, returns its Voigt vectorial representation"""
    return as_vector([e[0,0],e[1,1],2*e[0,1]])
def voigt2stress(s):
    s is a stress-like vector (no 2 factor on last component)
    returns its tensorial representation
    return as_tensor([[s[0],s[2]],[s[2],s[1]]])
def sigma(v):
    return voigt2stress(dot(C,strain2voigt(eps(v))))
class Top(SubDomain):
        return near(x[1],10) and on_boundary
class Left(SubDomain):
        return near(x[0],0) and on_boundary
class Bottom(SubDomain):
          return near(x[1],0) and on_boundary
# exterior facets MeshFunction
facets = MeshFunction("size_t", mesh, 1)
Error message
  File "/home/pierre/Desktop/MesEssais/essai28_jun/essai28_jun22.py", line 59, in <module>
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/mesh/meshfunction.py", line 18, in __new__
    return fn(mesh, dim)
TypeError: __init__(): incompatible constructor arguments. The following argument types are supported:
    1. dolfin.cpp.mesh.MeshFunctionSizet(arg0: dolfin.cpp.mesh.Mesh, arg1: int)
    2. dolfin.cpp.mesh.MeshFunctionSizet(arg0: dolfin.cpp.mesh.Mesh, arg1: int, arg2: int)
    3. dolfin.cpp.mesh.MeshFunctionSizet(arg0: dolfin.cpp.mesh.Mesh, arg1: str)
    4. dolfin.cpp.mesh.MeshFunctionSizet(arg0: dolfin.cpp.mesh.Mesh, arg1: int, arg2: dolfin.cpp.mesh.MeshDomains)
    5. dolfin.cpp.mesh.MeshFunctionSizet(arg0: dolfin.cpp.mesh.Mesh, arg1: dolfin::MeshValueCollection<unsigned long>)
Invoked with: <meshio mesh object>
  Number of points: 146
  Number of cells:
    triangle: 250
  Cell data: name_to_read, 1
I tried to correct it based on the error message but unsuccessfully.
Please need your help again.
Thanks
You need to load the mesh from XDMF. i.e.
# First write mesh to xdmf
# Then define functions and classes
# Then load mesh
mesh = Mesh()
with XDMFFile("test.xdmf") as infile:
    infile.read(mesh)
# Then create mesh function
Thank you dokken,
I have followed your instructions, but I have another error message:
Shapes do not match: <ListTensor id=140219301787456> and <Sym id=140219301787200>.
  File "/home/pierre/Desktop/MesEssais/essai28_jun/essai28_jun22.py", line 86, in <module>
    a = inner(sigma(du), eps(u_))*dx
  File "/usr/lib/python3/dist-packages/ufl/operators.py", line 158, in inner
    return Inner(a, b)
  File "/usr/lib/python3/dist-packages/ufl/tensoralgebra.py", line 147, in __new__
    error("Shapes do not match: %s and %s." % (ufl_err_str(a), ufl_err_str(b)))
  File "/usr/lib/python3/dist-packages/ufl/log.py", line 158, in error
UFLException: Shapes do not match: <ListTensor id=140219301787456> and <Sym id=140219301787200>.
Please, how to solve this?
You need to provide a minimal code example that reproduces the error, as this is related to the variational form
Ok, based on your previous advice, I have developed the code bellow:
# Then load mesh
mesh = Mesh()
    infile.read(mesh)
facets.set_all(0)
Top().mark(facets, 1)
Left().mark(facets, 2)
Bottom().mark(facets, 3)
ds = Measure("ds", subdomain_data = facets)
# Define function space
V = VectorFunctionSpace(mesh, 'CG', 1)
du = TrialFunction(V)
u_ = TestFunction(V)
u = Function(V, name='Displacement')
# uniform traction on top boundary
Ttrac = Constant((0., 1e7))
l = dot(Ttrac, u_)*ds(1)
It is the code that gives the previous error I sent you.
If your mesh is 2 dimensional, you Need to prune the z-coordinates of points before writing to file (you can use mesh.prune_z_0() for the mesh above.
You can verify this by printing mesh.geometry().dim() after loading the mesh into dolfin; it should be 2
Sorry Dokken, another error occurs when I was trying to prune the z-coordinates.
from numpy import linalg as LA
mesh.prune_z_0()
Error message:
  File "/home/pierre/Desktop/MesEssais/essai28_jun/essai28_jun22.py", line 18, in <module>
    mesh.prune_z_0()
AttributeError: 'Mesh' object has no attribute 'prune_z_0'
Thank you for spending your time with me.
What version of meshio are you using? This function is part of: meshio/_mesh.py at 20ef6275f4fdd07c2a85082761dd38fccf393476 · nschloe/meshio · GitHub
and has been in meshio since version 4.3.0
meshio version : 2.3.10 on ubuntu 20.04 environment.
I am trying to update it to the latest version.
Come back soon
thanks
My meshio version is 5.3.4 but I get the same error. Can you please help me with this?
Thanks
See What is wrong with my mesh? - #8 by dokken
It worked. Thank you so much.
Hi Dokken, thank you very much for your help! I have a question to ask you. When I run this code, it returns this error. Is this a problem with my “fenics_adjoint”, or is it something else?
See reply in: Implement point source in the variational formulation - #11 by dokken
Pleaee avoid making duplicate questions.
I apologize for this and thank you for the reminder.
Hi Dokken, thank you very much for your help. Am I to understand that the position (1, 1) where delta is loaded is its function space and not its coordinates in the actual space.
Hello, Dokken. I understand that the delta in your code is a 2D vector. Its x-component is a delta function, and its y-component is 0. I want to define a scalar delta function, which has one component. I changed your code a little bit, as shown below:
mesh = UnitSquareMesh(20, 20)
V = VectorFunctionSpace(mesh, "CG", 1)
V_new = FunctionSpace(mesh, "CG", 1)
class Delta(UserExpression):
    def __init__(self, eps, x0, **kwargs):
        self.eps = eps
        self.x0 = x0
        UserExpression.__init__(self, **kwargs)
    def eval(self, values, x):
        eps = self.eps
        values[0] = eps/pi/(np.linalg.norm(x-self.x0)**2 + eps**2)
    def value_shape(self): return (1, )
delta = Delta(eps=1E-4, x0=np.array([1, 1]), degree=5)
u_new = project(delta, V_new)
File("u_new.pvd") << u_new
As shown in the above code, I defined a scalar delta function, and projected it into a scalar function. Then I open it using Paraview to see its value. However, when I run this code, I got this error:
ufl_legacy.log.UFLException: Shapes do not match: <Argument id=133605434534752> and <Coefficient id=133604840997376>.
Could you please give me some advice? Thank you very much.
Try
def value_shape(self): return ()
