Hello
I’m relatively new to working with Fenics, and I’m using it for overlapping meshes. So far I haven’t had big problems working with 2D multi-meshes, however, for 3D meshes it hasn’t been possible to build a multimesh. I’m sending you a brief example along with the error. In the article https://arxiv.org/pdf/1610.02277.pdf they describe a successful case using 3D overlapping meshes in Fenics, however it doesn’t work for me. Thanks for any advice.
The example:
SphereTest = Sphere(Point(0.0,0.0,0.0),5.0)
front_mesh = generate_mesh(SphereTest, 10)
front_mesh1 = generate_mesh(SphereTest, 10)
VectorP=Point(0.0,0.0,5.0)
front_mesh.translate( VectorP)
multimesh = MultiMesh()
multimesh.add(front_mesh)
multimesh.add(front_mesh1)
multimesh.build()
The error:
Generating mesh with CGAL 3D mesh generator
File “3D_Sphere.py”, line 23, in
multimesh.build()
RuntimeError:
*** Error: Unable to triangulate convex polyhedron.
*** Reason: Triangulation of polyhedron of topological dimension 2 and geometric dimension 3 not implemented.
*** Where: This error was encountered inside ConvexTriangulation.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 15b823f2c45d3036b6af931284d0f8e3c77b6845
Best regards,
