Hello all,
Consider if I have a spatially varying function, A on some mesh, for example:
mesh = UnitSquareMesh(10,10)
V = FunctionSpace(mesh, 'Lagrange',1)
A = Function(V)
A in reality would be the output from a linear solve.
How would I implement a second function, B which is piecewise dependant on the values in A? i.e.:
B(A) =\begin{cases}
B_0(A) & A < 1 \\
B_1(A) & 1 \leq A < 5 \\
B_2(A) & 5 \leq A < 10 \\
B_3(A) & A > 10
\end{cases}
Where B_0 \dots B_3 are functions in A, say, as an expression: B(A) = A^2 + 5 etc.
Both A and B would then require to appear in the variational formulation of my problem.
Any help would be greatly appreciated.
I’d solve it similar to subdomains as in Subdomains and boundary conditions : Use an Expression with the variable A as input (as an Expression) and then a simple if-loop.
Something like this shuld do the trick:
cpp_code =''' #include <pybind11/pybind11.h>
#include <pybind11/eigen.h>
namespace py = pybind11;
#include <math.h> // to use pow()
#include <dolfin/function/Expression.h> // for expressions
#include <dolfin/mesh/MeshFunction.h> // for MeshFunctions
#include <dolfin/function/Function.h> // for functions
class your_Function_Name : public dolfin::Expression
public:
your_Function_Name() : dolfin::Expression(){}
void eval(Eigen::Ref<Eigen::VectorXd> values, Eigen::Ref<const Eigen::VectorXd> x, const ufc::cell& cell) const override
exp1->eval(values, x);
const double val1 = values[0];
if ( val1 < 1){
values[0] = 10; // your stuff
}else{
values[0] = pow(val1, 2)-3; // your stuff
std::shared_ptr<dolfin::Expression> exp1;
PYBIND11_MODULE(SIGNATURE, m)
py::class_<your_Function_Name, std::shared_ptr<your_Function_Name>, dolfin::Expression>(m, "your_Function_Name")
.def(py::init<>())
.def_readwrite("exp1", &your_Function_Name::exp1);
B=CompiledExpression( compile_cpp_code(cpp_code).your_Function_Name(), exp1=A, degree=2)
Note that I haven’t tested it, but this should give you hopefully an idea
Hope this helps
Hello @Emanuel_Gebauer,
Thank you so much for your reply! - I should’ve specified, I’m unfamiliar with C++ and using Python. However, you pointed me in the right direction, this is what I came up with and it seems to work:
# Function class
class piecewise_fcn(UserExpression):
def set_values(self,A):
self.A = A
def eval(self, value, x):
A_eval = A(x)
if A_eval < 1:
value[0] = 1
elif A_eval >= 1 and A_eval < 5:
value[0] = 2
elif A_eval >= 5 and A < 10:
value[0] = 3
value[0] = 4
def value_shape(self):
return()
Please let me know if there is any way I could improve upon this, but i’ll leave this here as the solution for now,
Thanks again!
