Inhomogeneous Poisson equation with user defined expression
Hi guys, I am writing code for the inhomogeneous Poisson equation - \nabla \cdot K(x) \nabla u = f, where K(x) is a piecewise constant function (defined in the code below).
The issue I encountered is that the assembling of the weak form is extremely time-consuming. I believe it is due to the way I defined the expression for K(x). It’s probably like iterating over a NumPy array using a for loop, which is very slow in python.
Here is the minimal working code. I made a time comparison between running assembling (\nabla u, \nabla v) and (K(x) \nabla u, \nabla v ) in the code.
import time
import math
# Define Layer structure dielectric constant
dielectric_consts = [1,50,1,50,1,50]
class MyExpression(UserExpression):
    def eval(self, values, x):
        num_layer = len(dielectric_consts)
        width = 1.0/num_layer
        if x[1] <= width:
            values[0] = dielectric_consts[0]
        elif x[1] <= 2*width:
            values[0] = dielectric_consts[1]
        elif x[1] <= 3*width:
            values[0] = dielectric_consts[2]
        elif x[1] <= 4*width:
            values[0] = dielectric_consts[3]
        elif x[1] <= 5*width:
            values[0] = dielectric_consts[4]
            values[0] = dielectric_consts[5]
    def value_shape(self):
        return() #scalar function
mesh = UnitSquareMesh(400,400)
f = Expression("100*exp(-(pow(x[0] - 0.5, 2) + pow(x[1] - 0.5, 2)) / 0.01)", degree=2)
# Define weak form 1
K = MyExpression()
a_1 = inner(K*grad(u), grad(v))*dx # Assmbling is super slow with K, not optimized.
L_1 = f*v*dx
# Define weak form 2
a_2 = inner(grad(u), grad(v))*dx
begin = time.time()
A, b = assemble_system(a_1, L_1,None)
end = time.time() - begin
print("With K ... time taken: ",end)
begin = time.time()
A, b = assemble_system(a_2, L_1,None)
print("Without K ... time taken: ",end)
Any ideas on how to optimize this in FEniCS?
This issue was addressed in the book Solving PDEs in Python
– The FEniCS Tutorial Volume 1, 4.3.3 Chaper 4.
The solution is to use C++ code and pass it to python expression. :slight_smile:
Update:
However, I am not able to compile to code after using C++ code in python. Still need help :joy: :joy: :joy:
To reproduce the error, please run the following code. Thank you!
cppcode = """
class DielectricConstant : public Expression
  void eval(Array<double>& values, const Array<double>& x) const
    int num_layer =  dielectric.size();
    double width = 1.0/num_layer;
    for (int i = 0; i < num_layer; i++){
        if( (x[1] >= i*width) && (x[1] <(i+1)*width) ){
          values[0] = dielectric[i];
          break;
public:
  std::vector<double> dielectric {1,50,1,50,1,50};
mesh = UnitSquareMesh(200,200)
f = Expression("100*exp(-(pow(x[0] - 0.5, 2) + pow(x[1] - 0.5, 2)) / 0.01)", degree=1)
K_cpp = Expression(cpp_code = cppcode,degree = 1)
# Define weak form
a= inner(K_cpp*grad(u), grad(v))*dx
begin = time.time()
A, b = assemble_system(a, L_1,None)
print("With K cpp code ... time taken: ",end)
For the latest version of dolfin, I would suggest having a look at: Bitbucket
