How to define conjugates for variational formulation?
Hi, I am trying to solve a problem which requires me to form a variational formulation with a term involving the conjugate of a function, as in the following minimum working code example:
  import dolfinx.fem.petsc
  import dolfinx.nls.petsc
  u = dolfinx.fem.Function(V)
  F = ufl.inner(ufl.grad(ufl.conj(u)), ufl.grad(v)) * ufl.dx
  boundary_facets = dolfinx.mesh.exterior_facet_indices(mesh.topology)
  boundary_dofs = dolfinx.fem.locate_dofs_topological(V, mesh.topology.dim-1, boundary_facets)
  bc = dolfinx.fem.dirichletbc(dolfinx.fem.Function(V), boundary_dofs)
  ns_problem = dolfinx.fem.petsc.NonlinearProblem(F, u, bcs=bc)
  newton_solver = dolfinx.nls.petsc.NewtonSolver(mesh.comm, ns_problem)
  newton_solver.solve(u)
The error message I am having with this code is:
  File "/app/fx4f/run_simulation.py", line 40, in <module>
    run_simulation(simulation.main)
  File "/app/fx4f/run_simulation.py", line 25, in run_simulation
    main( logger, **kwargs )
  File "/app/simulation.py", line 35, in main
  File "/usr/local/dolfinx-complex/lib/python3.10/dist-packages/dolfinx/fem/petsc.py", line 907, in __init__
    self._a = _create_form(
  File "/usr/local/dolfinx-complex/lib/python3.10/dist-packages/dolfinx/fem/forms.py", line 249, in form
    return _create_form(form)
  File "/usr/local/dolfinx-complex/lib/python3.10/dist-packages/dolfinx/fem/forms.py", line 244, in _create_form
    return _form(form)
  File "/usr/local/dolfinx-complex/lib/python3.10/dist-packages/dolfinx/fem/forms.py", line 186, in _form
    ufcx_form, module, code = jit.ffcx_jit(
  File "/usr/local/dolfinx-complex/lib/python3.10/dist-packages/dolfinx/jit.py", line 51, in mpi_jit
  File "/usr/local/dolfinx-complex/lib/python3.10/dist-packages/dolfinx/jit.py", line 201, in ffcx_jit
  File "/usr/local/lib/python3.10/dist-packages/ffcx/codegeneration/jit.py", line 256, in compile_forms
    impl = _compile_objects(
  File "/usr/local/lib/python3.10/dist-packages/ffcx/codegeneration/jit.py", line 383, in _compile_objects
    _, code_body = ffcx.compiler.compile_ufl_objects(
  File "/usr/local/lib/python3.10/dist-packages/ffcx/compiler.py", line 108, in compile_ufl_objects
    analysis = analyze_ufl_objects(ufl_objects, options["scalar_type"])  # type: ignore
  File "/usr/local/lib/python3.10/dist-packages/ffcx/analysis.py", line 94, in analyze_ufl_objects
    form_data = tuple(_analyze_form(form, scalar_type) for form in forms)
  File "/usr/local/lib/python3.10/dist-packages/ffcx/analysis.py", line 94, in <genexpr>
  File "/usr/local/lib/python3.10/dist-packages/ffcx/analysis.py", line 180, in _analyze_form
    form_data = ufl.algorithms.compute_form_data(
  File "/usr/local/lib/python3.10/dist-packages/ufl/algorithms/compute_form_data.py", line 427, in compute_form_data
    check_form_arity(preprocessed_form, self.original_form.arguments(), complex_mode)
  File "/usr/local/lib/python3.10/dist-packages/ufl/algorithms/check_arities.py", line 211, in check_form_arity
    check_integrand_arity(itg.integrand(), arguments, complex_mode)
  File "/usr/local/lib/python3.10/dist-packages/ufl/algorithms/check_arities.py", line 205, in check_integrand_arity
    raise ArityMismatch(f"Argument {arg} is spuriously conjugated in complex Form")
ufl.algorithms.check_arities.ArityMismatch: Argument v_1 is spuriously conjugated in complex Form
My fenicsx version is 0.8.0, and I installed it using Docker. I am using my PETSc in complex mode, which was again set from the Dockerfile.
The code above is created only to represent the problem I am facing with my original code.
I don’t know how I am supposed to include the conjugate of a function in the variational formulation, and why I am getting this error. I would appreciate it if you could inform me about the usage of conjugates. Thank you in advance!
ufl.inner already does the conj for you, see ufl/ufl/operators.py at 004a678320e5c65015d56071b968ee08314aecc1 · FEniCS/ufl · GitHub
Furthermore, ufl expects that conjugation happens on the test function, not on the trial, see ufl/ufl/algorithms/check_arities.py at 004a678320e5c65015d56071b968ee08314aecc1 · FEniCS/ufl · GitHub
The following
u = ufl.TrialFunction(V)
print("Case 1")
try:
    a1 = ufl.inner(ufl.grad(ufl.conj(u)), ufl.grad(v)) * ufl.dx
    dolfinx.fem.form(a1)
except BaseException as e:
    print(e)
    print("ok")
print("Case 2")
a2 = ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
dolfinx.fem.form(a2)
print("ok")
print("Case 3: same as case 2")
a3 = ufl.dot(ufl.grad(u), ufl.grad(ufl.conj(v))) * ufl.dx
dolfinx.fem.form(a3)
print("ok")
print("ok")
print("Case 4: same as case 1, but different error")
try:
    a4 = ufl.dot(ufl.grad(ufl.conj(u)), ufl.grad(v)) * ufl.dx
    dolfinx.fem.form(a4)
    print(e)
    print("ok")
prints
Case 1
Case 2
ok
ok
ok
Failure to conjugate test function in complex Form
Hi Francesco, thank you for your answer.
In my case, u is not a TrialFunction but a fem.Function. Also, my problem’s variational form includes the conjugate of a function explicitly, as I provided in the code above. Is there any chance to implement that?
Is the form sesquilinear?
This is a requirement: Form language — Unified Form Language (UFL) 2024.1.0 documentation
And please note that inner also incorporates conj on the second argument, i.e.
ufl.inner(ufl.grad(ufl.conj(u)), ufl.grad(v))*ufl.dx corresponds to
ufl.dot(ufl.grad(ufl.conj(u)), ufl.conj(ufl.grad(v)))*ufl.dx.
You are getting an error when the jacobian is formed, i.e. when
J=ufl.derivative(F, u, du) is formed.
The error stems from: ufl/ufl/algorithms/check_arities.py at 004a678320e5c65015d56071b968ee08314aecc1 · FEniCS/ufl · GitHub
where the assumption is that a TrialFunction cannot be conjugated.
The TrialFunction itself is real valued: Form language — Unified Form Language (UFL) 2024.1.0 documentation meaning that having a ufl.conj on it doesn’t really make sense.
So the big question is, what is the Jacobian of your complex variational form?
Hi dokken, thank you for your answer.
Consider the example in here. It would seem that taking a conjugate of such a solution should be a valid operation.
Suppose in that tutorial, if the PDE were not ‘Delta u_c = f’, but rather ‘Delta conj(u_c) = f’, then how would one solve that?
That equation doesn’t really make sense to me, as you are searching for complex valued coefficients a+ib, so you could solve the non-conjugate version of this and just get a negative b coeff.
I see, for that example your suggestion is indeed the easiest solution. What would you suggest for a variational formulation like the one in the below code?
  import basix
  Ve = basix.ufl.element("Lagrange", mesh.topology.cell_name(), Pu, shape=(mesh.geometry.dim,))
  Qe = basix.ufl.element("Lagrange", mesh.topology.cell_name(), Pp)
  W_element = basix.ufl.mixed_element([Ve, Qe])
  W = dolfinx.fem.functionspace(mesh, W_element)
  V, _ = W.sub(0).collapse()
  vq = ufl.TestFunction(W)
  (v, q) = ufl.split(vq)
  dup = ufl.TrialFunction(W)
  up = dolfinx.fem.Function(W)
  (u, p) = ufl.split(up)
  F = ufl.inner( ufl.dot(ufl.conj(u),ufl.nabla_grad(u))  , v) * ufl.dx
  J = ufl.derivative(F, up, dup)
  ns_problem = dolfinx.fem.petsc.NonlinearProblem(F, up, bcs=[bc], J =J)
  newton_solver.solve(up)
The code above yields the error below:
  File "/app/simulation.py", line 66, in main
    return _form(form)
  File "/usr/local/lib/python3.10/dist-packages/ufl/algorithms/check_arities.py", line 192, in check_integrand_arity
    arg_tuples = map_expr_dag(rules, expr, compress=False)
  File "/usr/local/lib/python3.10/dist-packages/ufl/corealg/map_dag.py", line 35, in map_expr_dag
    (result,) = map_expr_dags(
  File "/usr/local/lib/python3.10/dist-packages/ufl/corealg/map_dag.py", line 103, in map_expr_dags
    r = handlers[v._ufl_typecode_](v, *[vcache[u] for u in v.ufl_operands])
  File "/usr/local/lib/python3.10/dist-packages/ufl/algorithms/check_arities.py", line 57, in sum
ufl.algorithms.check_arities.ArityMismatch: Adding expressions with non-matching form arguments ('conj(v_1)',) vs ('v_1',).
It again raises an ArityMismatch, but of a different kind. Is it again because of the way I am forming the Jacobian? I didn’t understand how the code takes the conjugate of the TrialFunction, although I am not taking it anywhere in the code. I also tried using inner to avoid using conjugates explicitly, and changed the F to:
F = ufl.inner( ufl.inner(ufl.nabla_grad(u), u)  , v) * ufl.dx
Which resulted in the following error:
  File "/app/simulation.py", line 62, in main
  File "/usr/local/lib/python3.10/dist-packages/ufl/operators.py", line 213, in inner
    return Inner(a, b)
  File "/usr/local/lib/python3.10/dist-packages/ufl/tensoralgebra.py", line 166, in __new__
    raise ValueError(f"Shapes do not match: {ufl_err_str(a)} and {ufl_err_str(b)}")
ValueError: Shapes do not match: <NablaGrad id=139896952732160> and <ListTensor id=139896712508928>
I don’t understand why I cannot use conjugate explicitly in the variational formulation above. Could you tell me how I should form the variational formulation / Jacobian for the code here? Thank you in advance.
Again, could you please write out the strong formulation of your problem, to me I do not understand what PDE would give rise to \int_{\Omega} (\bar{u}\cdot(\nabla u)^T) \cdot \bar{v}~\mathrm{d}x.
I am trying to mimic the paper here.
You can see that in the example on the 3rd page of the article, due to the nonlinear convection operator, I need to use the conjguate of my velocity component in the variational formulation.
I would start by writing out the analytical expression of the Jacobian that will be used in Newton’s method.
