Hi all,
I’m trying to convert some FEniCS code to the current FEniCSx (based on dolfinx). I have a NumPy array representing spatially varying Young’s modulus values on a 2D mesh, and I want to assign it to a Functiondefined on a CG1 function space.
Here is what I used previously:
E_vals = np.load("E_field.npy")
assert E_vals.shape == (Ny+1, Nx+1)
ordering = df.dof_to_vertex_map(V_E)
E_func.vector()[:] = E_vals.flatten(order='C')[ordering]
E_func.vector().apply("insert")
Here is my current Fenicsx implementation that is giving wrong result:
from time import time
from ufl import sym, grad, Identity, tr, inner, Measure, TestFunction, TrialFunction, sin, pi, SpatialCoordinate
from dolfinx import fem, io
import dolfinx.fem.petsc
from dolfinx.mesh import create_rectangle, CellType
import pyvista
from dolfinx import plot
from ufl import sym, grad, tr, Identity
from dolfinx.fem import Expression
import os
# Domain and mesh parameters (1×1 physical domain)
def epsilon(v):
return sym(grad(v))
def sigma(v,lmbda,dim,mu):
return lmbda * tr(epsilon(v)) * Identity(dim) + 2 * mu * epsilon(v)
def left(x):
return np.isclose(x[0], 0.0)
def right(x,length):
return np.isclose(x[0], length)
def bottom(x):
return np.isclose(x[1], 0.0)
def top(x,height):
return np.isclose(x[1], height)
def displ(u_sol,domain,dim,direction,Nx = 64):
if direction == 'x' :
i = 0
elif direction == 'y' :
i = 1
return('wrong direction')
V = fem.functionspace(domain, ('CG',1,(dim,)))
u_interpolated = fem.Function(V,name='Interpolated Solution')
u_interpolated.interpolate(u_sol)
array = u_interpolated.x.array[i::2] # Displacements along x or y
dof_coord = V.tabulate_dof_coordinates()[:, :2]
N=Nx
indices = dof_coord / (1./N)
input_indices = np.round(indices).astype(np.int32)
y_sort = np.argsort(input_indices[:, 1])
sorted_coords = dof_coord[y_sort]
sorted_values = array[y_sort]
# Check that x-axis is sorted by increasing x coordinate (per y coord)
for i in range(N+1):
sub_indices = np.flatnonzero(input_indices[y_sort, 1]==i)
sub_sort = np.argsort(input_indices[y_sort[sub_indices], 0])
sub_coords = sorted_coords[sub_indices]
sub_vals = sorted_values[sub_indices]
sorted_coords[sub_indices] = sub_coords[sub_sort]
sorted_values[sub_indices] = sub_vals[sub_sort]
sorted_values = sorted_values.reshape(N, N)
return sorted_values, sorted_coords
def interp_scalar_with_coords(f_sol, domain, Nx=64):
Take a scalar CG1 Function f_sol on 'domain' and return
- sorted_values: an (Nx x Nx) array of nodal values, ordered by y then x
- sorted_coords: the corresponding (Nx*Nx x 2) array of node coords
matching your displ() output.
# 1) Build the same CG1 scalar space
V0 = fem.functionspace(domain, ("CG", 1))
f_i = fem.Function(V0, name=f_sol.name)
f_i.interpolate(f_sol)
# 2) Raw values + coordinates
vals = f_i.x.array # length = (Nx+1)*(Nx+1)
dof_coord = V0.tabulate_dof_coordinates()[:, :2]
# 3) Map coords → integer grid indices
indices = np.round(dof_coord / (1.0 / Nx)).astype(int) # shape=(n_dofs,2)
# 4) First sort by y, then by x within each row
# (exactly like your displ logic)
y_sort = np.argsort(indices[:, 1])
sorted_vals = vals[y_sort].copy()
sorted_coords= dof_coord[y_sort].copy()
sorted_idx = indices[y_sort]
for yy in range(Nx+1):
mask = np.where(sorted_idx[:,1] == yy)[0]
x_order = np.argsort(sorted_idx[mask, 0])
sorted_vals[mask] = sorted_vals[mask][x_order]
sorted_coords[mask] = sorted_coords[mask][x_order]
# 5) reshape into a 2D grid
grid_vals = sorted_vals.reshape(Nx, Nx) # note Nx+1 nodes per side
# if you really want 64×64, use reshape(Nx, Nx) on a 64×64 mesh of 63×63 elements.
return grid_vals, sorted_coords
def compute_fem(file) :
samples = np.load(file)[:2].shape[0]
print(samples)
solutions_disp = np.zeros((samples,2,64,64)) # shape 256,2,65,65
solutions_stress = np.zeros((samples, 3, 64, 64))
solutions_strain = np.zeros((samples, 3, 64, 64))
for i in range(samples):
length, height = 1.0, 1.0 # Physical domain: 1 x 1
Nx, Ny = 63, 63 # Mesh resolution
domain = create_rectangle(
MPI.COMM_WORLD,
[np.array([0.0, 0.0]), np.array([length, height])],
[Nx, Ny],
cell_type=CellType.quadrilateral,
dim = domain.topology.dim
degree = 2
#V = fem.functionspace(domain, ("P", degree, (dim,)))
u_sol = fem.Function(V, name="Displacement")
# Load the GRF for Young's modulus E(x)
#E_vals = np.load(f"{file}")[:,:,i] # shape: (64, 64,4) JE CHANGE POUR ADAPTER AU NOUVEAU FORMAT (256,64,64)
E_vals = np.load(f"{file}")[i,:,:] # shape: (64, 64,4)
nx_grf, ny_grf = E_vals.shape
# Create grid coordinates corresponding to the GRF domain.
x_grf = np.linspace(0, length, nx_grf)
y_grf = np.linspace(0, height, ny_grf)
dx_grf = x_grf[1] - x_grf[0]
dy_grf = y_grf[1] - y_grf[0]
# Project GRF values onto the mesh
V_E = fem.functionspace(domain, ("CG", 1))
E_func = fem.Function(V_E, name="Youngs_modulus")
tdim = domain.topology.dim
domain.topology.create_connectivity(0, tdim) # vertex → cell
domain.topology.create_connectivity(tdim, 0) # cell → vertex
num_vertices = domain.topology.index_map(0).size_local
vertex_indices = np.arange(num_vertices, dtype=np.int32)
vertex_to_dof = fem.locate_dofs_topological(V_E, 0, vertex_indices)
flat = E_vals.flatten(order="C")[vertex_to_dof]
E_func.x.array[:] = flat
E_func.x.scatter_forward()
# Material parameters (spatially varying)
nu = fem.Constant(domain, 0.2) # Poisson's ratio
lmbda = (E_func * nu) / ((1 + nu) * (1 - (2 * nu)))
mu = (E_func) / (2 * (1 + nu))
# Variational problem setup
rho = 2e-3
g = 9.81
f = fem.Constant(domain, np.array([0, -rho * g]))
dx_measure = Measure("dx", domain=domain)
a = inner(sigma(u,lmbda,dim,mu), epsilon(v)) * dx_measure
L = inner(f, v) * dx_measure
# Boundary conditions (Fixed on Bottom, Left, and Right)
left_dofs = fem.locate_dofs_geometrical(V, left)
right_dofs = fem.locate_dofs_geometrical(V, lambda x: right(x, length))
bottom_dofs = fem.locate_dofs_geometrical(V, bottom)
bcs = [
fem.dirichletbc(np.zeros((dim,), dtype=np.float64), left_dofs, V),
fem.dirichletbc(np.zeros((dim,), dtype=np.float64), right_dofs, V),
fem.dirichletbc(np.zeros((dim,), dtype=np.float64), bottom_dofs, V),
top_dofs = fem.locate_dofs_geometrical(V,lambda x: top(x, height))
# Define spatial coordinate
x = SpatialCoordinate(domain)
# Define cosine load function in UFL form
F0 = 10 # Load magnitude
cosine_load = F0 * sin(pi * x[0]) # f_y(x) = F0 * sin(pi * x), zero at x=0, x=1, max at x=0.5
# Apply as Neumann boundary condition (traction force) to the y-component
ds = Measure("ds", domain=domain)
L += inner(cosine_load, v[1]) * ds # Fixed: Apply force only to the y-component
# The fix ensures shape compatibility in UFL expressions
# Solve the linear elasticity problem
problem = fem.petsc.LinearProblem(
a, L, u=u_sol, bcs=bcs,
petsc_options={"ksp_type": "preonly", "pc_type": "lu"}
problem.solve()
# Output the solution
vtk = io.VTKFile(domain.comm, "displacement_field.pvd", "w")
vtk.write_function(u_sol)
vtk.close()
ux_array, sorted_coords_x = displ(u_sol,domain,dim,'x',Nx = 64)
uy_array, sorted_coords_y = displ(u_sol,domain,dim,'y',Nx = 64)
ux_array = ux_array[::-1, :]
uy_array = uy_array[::-1, :]
solutions_disp[i,0,:,:] = ux_array
solutions_disp[i,1,:,:] = uy_array
dx = Measure("dx", domain=domain)
eps = sym(grad(u_sol))
sigma_expr = lmbda*tr(eps)*Identity(dim) + 2*mu*eps
W = fem.functionspace(domain, ("CG", 1, (dim, dim)))
V1 = fem.functionspace(domain, ("CG", 1))
expr_xx = Expression(sigma_expr[0,0], V1.element.interpolation_points())
expr_yy = Expression(sigma_expr[1,1], V1.element.interpolation_points())
expr_xy = Expression(sigma_expr[0,1], V1.element.interpolation_points())
sig_xx = fem.Function(V1, name="sigma_xx")
sig_yy = fem.Function(V1, name="sigma_yy")
sig_xy = fem.Function(V1, name="sigma_xy")
sig_xx.interpolate(expr_xx)
sig_yy.interpolate(expr_yy)
sig_xy.interpolate(expr_xy)
# write them all into one PVD
vtk_s = io.VTKFile(domain.comm, "stress_components.pvd", "w")
vtk_s.write_function(sig_xx)
vtk_s.write_function(sig_yy)
vtk_s.write_function(sig_xy)
vtk_s.close()
# CG1 projection space
p = TrialFunction(V1)
q = TestFunction(V1)
a_proj = inner(p, q) * dx
# components: (xx,yy,xy)
for comp, (i0,i1) in enumerate([(0,0), (1,1), (0,1)]):
expr = sigma_expr[i0, i1]
L_proj = inner(expr, q) * dx
proj = fem.petsc.LinearProblem(
a_proj, L_proj, bcs=[],
petsc_options={"ksp_type":"preonly","pc_type":"lu"}
sigma_cg1 = proj.solve() # CG1 nodal Function
# reorder to 64×64 array
grid_vals, _ = interp_scalar_with_coords(sigma_cg1, domain, Nx=64)
solutions_stress[i, comp, :, :] = grid_vals
expr_ep = eps[i0, i1]
L_proj = inner(expr_ep, q) * dx
eps_cg1 = proj.solve() # CG1 nodal Function
grid_vals, _ = interp_scalar_with_coords(eps_cg1, domain, Nx=64)
solutions_strain[i, comp, :, :] = grid_vals
if i >= samples - 1 :
N = 64
X_ = sorted_coords_y[:, 0].reshape(N, N)
Y_ = sorted_coords_y[:, 1].reshape(N, N)
fig = plt.figure()
ax = plt.gca()
im1 = ax.imshow(uy_array, cmap="viridis")
fig.colorbar(im1)
return solutions_disp, solutions_stress[:,:,::-1,:] , solutions_strain[:,:,::-1,:]
Thank you in advance for your help!
