Hi again, Please find the code and the attached error:
(sorry don’t know how to quote it correctly, I use "Block quote )
Blockquote
from dolfinx.mesh import create_unit_square, create_box, CellType
from dolfinx import mesh, fem
from dolfinx.fem import locate_dofs_geometrical, Constant, form
import pyvista # visualizing the mesh using pyvista, an interface to the VTK toolkit.
print(pyvista.global_theme.jupyter_backend)
import dolfinx.plot as plot
from ufl import TrialFunction, TestFunction, dot, div, inner ,dx, SpatialCoordinate
from slepc4py import SLEPc
import math
import sys, io, slepc4py, os.path
factor = math.pi*math.pi
slepc4py.init(sys.argv)
opts = PETSc.Options()
print(f"DOLFINx version: {dolfinx.version} based on GIT commit: {dolfinx.git_commit_hash} of GitHub - FEniCS/dolfinx: Next generation FEniCS problem solving environment")
Blockquote
import math
import sys
def lshape_unstructQuad_gmsh2(element, num_elem):
print(’ The number of elements:‘, num_elem)
if (num_elem%2) != 0:
print(f"Insurt an even number of elements, the given number is {num_elem}")
exit()
num_of_points = num_elem + 1
lc = 1e-2
# boundaries: [-1,1]x[-1,1]
p1 = gmsh.model.geo.addPoint(-1 , -1 , 0, lc, 1)
p2 = gmsh.model.geo.addPoint(0 , -1 , 0, lc, 2)
p3 = gmsh.model.geo.addPoint(0 , 0 , 0, lc, 3)
p4 = gmsh.model.geo.addPoint(1 , 0 , 0, lc, 4)
p5 = gmsh.model.geo.addPoint(1 , 1 , 0, lc, 5)
p6 = gmsh.model.geo.addPoint(-1 , 1 , 0, lc, 6)
input(‘The boundaries of the domain are [-1,-1]x[1,1]:’)
l1 = gmsh.model.geo.addLine(p1, p2, 1)
l2 = gmsh.model.geo.addLine(p2, p3, 2)
l3 = gmsh.model.geo.addLine(p3, p4, 3)
l4 = gmsh.model.geo.addLine(p4, p5, 4)
l5 = gmsh.model.geo.addLine(p5, p6, 5)
l6 = gmsh.model.geo.addLine(p6, p1, 6)
# Adding points, lines, Create surface
gmsh.model.geo.addCurveLoop([l1, l2, l3, l4, l5, l6], 1)
gmsh.model.geo.addPlaneSurface([1], 1)
gmsh.model.addPhysicalGroup(0, [1, 2, 3, 4, 5, 6], 1)
gmsh.model.addPhysicalGroup(1, [1, 2, 3, 4, 5, 6], 2)
gmsh.model.addPhysicalGroup(2, [1], 1)
gmsh.model.geo.mesh.setTransfiniteCurve(l1, int(num_of_points/2)+1)
gmsh.model.geo.mesh.setTransfiniteCurve(l2, int(num_of_points/2)+1)
gmsh.model.geo.mesh.setTransfiniteCurve(l3, int(num_of_points/2)+1)
gmsh.model.geo.mesh.setTransfiniteCurve(l4, int(num_of_points/2)+1)
gmsh.model.geo.mesh.setTransfiniteCurve(l5, num_of_points)
gmsh.model.geo.mesh.setTransfiniteCurve(l6, num_of_points)
# # To create quadrangles instead of triangles, one can use the `setRecombine’
# # constraint:
gmsh.model.geo.mesh.setRecombine(2, 1)
gmsh.model.geo.synchronize()
# Finally we apply an elliptic smoother to the grid to have a more regular
# mesh:
# gmsh.option.setNumber(“Mesh.Smoothing”, 100)
gmsh.model.mesh.generate(2)
#===============testing
# if ‘close’ not in sys.argv:
# gmsh.fltk.run() # Write mesh data:
# gmsh.write(“mymeshmsh”)
# gmsh.finalize()
#=============end testing
#-----------fenicsx
print(“Creating the mesh in fenicsx”)
from dolfinx.io import gmshio
gmsh_model_rank = 0
mesh_comm = MPI.COMM_WORLD
domain, cell_markers, facet_markers = gmshio.model_to_mesh(gmsh.model,
mesh_comm,
gmsh_model_rank,
gdim=2)
print(‘done with the mesh…’)
total_num_of_elems = num_elem*num_elem
print(‘The number of elments in the L-shape domain:’,total_num_of_elems)
# Dimension of the space
tdim = domain.topology.dim
# print(tdim)
topology, cell_types, geometry = plot.create_vtk_mesh(domain, tdim)
print(‘Constructing the mesh …’)
grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
plotter = pyvista.Plotter()
plotter.view_xy()
# To view the mesh
plotter.show()
print(‘done…’)
return domain, tdim, total_num_of_elems, topology, cell_types, geometry
Blockquote
num_elemnts = 6
RT_order = 1 # order=1 is RT_0 lowest order RT for xfenics
element = ‘lshape_unstr_quad’
print(“number of elements %i”%num_elemnts)
‘’’ The mesh’‘’
domain, tdim, total_num_of_elems, ,,_ = lshape_unstructQuad_gmsh2(element, num_elemnts)
‘’‘The function spaces’‘’
print(‘Constructing the space …’)
space = fem.FunctionSpace(domain, (“RT”, RT_order))
print(‘done …\n’)
‘’‘Trial and test functions’‘’
print(‘The trial and test functions…’)
u = TrialFunction(space)
v = TestFunction(space)
print(‘done…\n’)
‘’‘The operators and the bilinear form’‘’
‘’‘Left hand side’‘’
print(‘Constructing the bilinear forms…’)
a = div(u)div(v)dx
stiff_bilinear_form = fem.form(a)
‘’‘Right hand side’‘’
b = inner(u,v)dx
mass_bilinear_form = fem.form(b)
print(‘done…\n’)
‘’‘----------------Setting the BC---------------------’‘’
print(‘Impossing the BC…’)
‘’’ Create facet to cell connectivity required to determine boundary facets’‘’
fdim = tdim - 1
boundary_dofs = fem.locate_dofs_topological(space, fdim, boundary_facets)
ubc = fem.Function(space)
ubc.vector.set(0.0)
bc = fem.dirichletbc(ubc, boundary_dofs)
local_range = space.dofmap.index_map.local_range
dofs = np.arange(local_range)
print(‘INFO :The Dofs ‘, dofs)
‘’‘Assempleing the matrices’’’
print(‘Assembling the system…’)
A = fem.petsc.create_matrix(stiff_bilinear_form, )
A.setOption(PETSc.Mat.Option.SYMMETRIC, True)
A.setOption(PETSc.Mat.Option.SYMMETRY_ETERNAL, True)
A.setOption(PETSc.Mat.Option.IGNORE_ZERO_ENTRIES, True)
fem.petsc.assemble_matrix(A, stiff_bilinear_form,bcs=[bc])
A.setOption(PETSc.Mat.Option.NEW_NONZERO_LOCATIONS, False)
‘’’ Mass matrix ‘’’
B = fem.petsc.create_matrix(mass_bilinear_form)
B.setOption(PETSc.Mat.Option.SYMMETRIC, True)
B.setOption(PETSc.Mat.Option.SYMMETRY_ETERNAL, True)
B.setOption(PETSc.Mat.Option.IGNORE_ZERO_ENTRIES, True)
fem.petsc.assemble_matrix(B, mass_bilinear_form,bcs=[bc])
B.assemble()
B.setOption(PETSc.Mat.Option.NEW_NONZERO_LOCATIONS, False)
print(‘done…\n’)
‘’‘Imposing the zero boundary conditions ‘’’
print(‘Imposing the zero Boundary conditions’)
B.zeroRowsLocal(bc.dof_indices()[0], 1.)
print(‘done…\n’)
print(‘Setting the solver…’)
shift = SLEPc.ST().create(MPI.COMM_WORLD)
shift.setType(‘sinvert’) # spectral transform
shift.setShift(1/factor) # spectral shift
eigensolver = SLEPc.EPS().create(MPI.COMM_WORLD)
numb_eigs = 1000
eigensolver.setDimensions(numb_eigs) # set number of eigenvalues to compute
eigensolver.setProblemType(eigensolver.ProblemType.GNHEP)
eigensolver.setWhichEigenpairs(eigensolver.Which.TARGET_MAGNITUDE) # For shift-and-invert
eigensolver.setST(shift)
eigensolver.setOperators(A,B)
eigensolver.setFromOptions() #any options specified at run time in the command line are
print(‘done…\n’)
print(‘Solving the problem…’)
eigensolver.solve()
print(‘done…\n’)
print("“)
print(” SLEPc Solution Results “)
print(”****“)
print()
num_of_converged_eig_val = eigensolver.getConverged()
vr, vi = A.createVecs()
real_eigs_sorted =
loop = 0
print( “Number of converged eigenpairs %d” % num_of_converged_eig_val )
print(‘’)
if num_of_converged_eig_val > 0:
for i in range (num_of_converged_eig_val):
l = eigensolver.getEigenpair(i ,vr, vi)
if element == ‘lshape_unstr_quad’:
if l.real > 1.4:
print(f"Mode {i} with value {l.real}”)
real_eigs_sorted += [l.real]
loop +=1
if loop == 20: #This is tocontrol the nukmber f eigvalues, not to spit them all
break
Blockquote
#To plot the first eigfunction
lmbda = eigensolver.getEigenpair(0, vr, vi)
x = SpatialCoordinate(domain)
topology1, cell_types1, x = plot.create_vtk_mesh(space)
grid1 = pyvista.UnstructuredGrid(topology1, cell_types1, x)
grid.point_data[“u”] = vr.x.array
warped = grid1.warp_by_scalar(“u”, factor=25)
plotter1 = pyvista.Plotter()
plotter1.add_mesh(warped, show_edges=True, show_scalar_bar=True, scalars=“u”)
plotter1.show()
The error:
raise RuntimeError(“Can only create meshes from continuous or discontinuous Lagrange spaces”)
RuntimeError: Can only create meshes from continuous or discontinuous Lagrange spaces
