How to extract mesh's coordinates and values according to facet markers
I try to extract mesh’s coordinates and values according to facet markers,here is a simple example from flow around cylinder:
fluid_marker = 1
    assert(len(volumes) == 1)
    gmsh.model.addPhysicalGroup(volumes[0][0], [volumes[0][1]], fluid_marker)
    gmsh.model.setPhysicalName(volumes[0][0], fluid_marker, "Fluid")
inlet_marker, outlet_marker, wall_marker, obstacle_marker = 2, 3, 4, 5
inflow, outflow, walls, obstacle = [], [], [], []
    for boundary in boundaries:
        if np.allclose(center_of_mass, [0, H/2, 0]):
            inflow.append(boundary[1])
        elif np.allclose(center_of_mass, [L, H/2, 0]):
            outflow.append(boundary[1])
        elif np.allclose(center_of_mass, [L/2, H, 0]) or np.allclose(center_of_mass, [L/2, 0, 0]):
            walls.append(boundary[1])
            obstacle.append(boundary[1])
    gmsh.model.setPhysicalName(1, inlet_marker, "Inlet")
    gmsh.model.addPhysicalGroup(1, outflow, outlet_marker)
    gmsh.model.setPhysicalName(1, outlet_marker, "Outlet")
    gmsh.model.addPhysicalGroup(1, obstacle, obstacle_marker)
    gmsh.model.setPhysicalName(1, obstacle_marker, "Obstacle")
For example,what should I do to get the mesh’s coordinates and physics values from the marker with Obstacle and Fluid when solving the problem?
See: Extract the coordinates of the boundary points and the value of a function on them - #4 by dokken
and change boundary_facets to the facet_tag.find(obstacle_marker), if facet_tag is the name of the facet markers.
You can then use entities_to_geometry to get the vertices of those facets, which can in turn be used with mesh.geometry.x to get the physical coordinates.
Do you mind me asking what you have in mind to do with these values?
Hi @dokken , thank you for your reply. I’m training a physics informed neural network to predict the fluid flow,which need to sample from each boundary conditions to limit the neural network (This is the reason why I want to extract coordinates and physics values from facet tags).
After I replaced boundary_facets = dolfinx.mesh.exterior_facet_indices(mesh.topology) with the boundary_facets = facet_tag.find(inlet_marker). I encountered the same problem as in that discussion:
TypeError: compute_incident_entities(): incompatible function arguments. The following argument types are supported:
    1. (mesh: dolfinx.cpp.mesh.Mesh, entities: numpy.ndarray[numpy.int32], d0: int, d1: int) -> numpy.ndarray[numpy.int32]
What version of DOLFINx are you running?
My DOLFINX version is 0.6.0
Please supply the actual code that you are running, as it is unclear to me what you are sending into dolfinx.mesh.compute_incident_entities.
Fine,here are my code:
            self.inlet_marker, self.outlet_marker, self.wall_marker, self.obstacle_marker = 2, 3, 4, 5
            boundary_facets = ft.find(self.inlet_marker)
            domain = mesh.geometry.x # The coordinates of all mesh
            boundary_vertices = dolfinx.mesh.compute_incident_entities(mesh.topology, boundary_facets, 1, 0)
            vertex_to_geometry = dolfinx.cpp.mesh.entities_to_geometry(mesh._cpp_object, 0, boundary_vertices, False)
            c_to_v = mesh.topology.connectivity(mesh.topology.dim, 0)
            mesh.topology.create_connectivity(0, mesh.topology.dim)
            v_to_c = mesh.topology.connectivity(0, mesh.topology.dim)
            num_dofs = V.dofmap.index_map.size_local + V.dofmap.index_map.num_ghosts
            dof_to_geometry_map = np.full(num_dofs, -1, dtype=np.int32)
            dofmap = V.dofmap
            layout = dofmap.dof_layout
            for i, (vertex, node) in enumerate(zip(boundary_vertices, vertex_to_geometry)):
                cell = v_to_c.links(vertex)[0]
                cell_dofs = dofmap.cell_dofs(cell)
                cvs = c_to_v.links(cell)
                local_index = np.flatnonzero(cvs == vertex)[0]
                dof = cell_dofs[layout.entity_dofs(0, local_index)]
                dof_to_geometry_map[dof] = node
And here are the full code:
import sys
import pandas as pd
from dolfinx import geometry
from dolfinx.fem import (Constant, Function, FunctionSpace,
                         assemble_scalar, dirichletbc, form, locate_dofs_topological, set_bc)
                               create_vector, create_matrix, set_bc)
from dolfinx.geometry import BoundingBoxTree, compute_collisions, compute_colliding_cells
from dolfinx.io import (XDMFFile, distribute_entity_data, gmshio)
from utils.encoder import normalization
from ufl import (FacetNormal, FiniteElement, Identity, Measure, TestFunction, TrialFunction, VectorElement,
                 as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym)
class simulation:
    def __init__(self, c_x, c_y, o_x, o_y, r, r2,
                 obstacle_type='cylinder',
                 save_mesh='false',
                 save='false',
                 visualize='false'):
        self.L = 2.2
        self.H = 0.41
        self.c_x = c_x
        self.c_y = c_y
        self.r = r
        self.gdim = 2
        self.model_rank = 0
        self.mesh_comm = MPI.COMM_WORLD
        self.save = save
        self.o_x = o_x
        self.o_y = o_y
        self.r2 = r2
        self.obstacle_type = obstacle_type
        self.save_mesh = save_mesh
        self.visualize = visualize
    def generate_mesh(self):
        # L*H:computational domain's size
        # (c_x,c_y):the coordinates of big cylinder
        # r:radius of the big cylinder
        # r2:radius of the small cylinder
        gmsh.option.setNumber('General.Verbosity', 1)
        rectangle = gmsh.model.occ.addRectangle(0, 0, 0, self.L, self.H, tag=1)
        obstacle1 = gmsh.model.occ.addDisk(self.c_x, self.c_y, 0, self.r, self.r)
        pre_fluid = gmsh.model.occ.cut([(self.gdim, rectangle)], [(self.gdim, obstacle1)])
        if self.r2 == 0:
            fluid = pre_fluid
            if self.obstacle_type == 'cylinder':
                obstacle2 = gmsh.model.occ.addDisk(self.o_x, self.o_y, 0, self.r2, self.r2)
            elif self.obstacle_type == 'rectangular':
                obstacle2 = gmsh.model.occ.addRectangle(self.o_x, self.o_y, 0, self.r2, self.r2)
            fluid = gmsh.model.occ.cut([(self.gdim, rectangle)], [(self.gdim, obstacle2)])
        gmsh.model.occ.synchronize()
        fluid_marker = 1
        volumes = gmsh.model.getEntities(dim=self.gdim)
        assert (len(volumes) == 1)
            if np.allclose(center_of_mass, [0, self.H / 2, 0]):
            elif np.allclose(center_of_mass, [self.L, self.H / 2, 0]):
            elif np.allclose(center_of_mass, [self.L / 2, self.H, 0]) or np.allclose(center_of_mass, [self.L / 2, 0, 0]):
        gmsh.model.addPhysicalGroup(1, walls, self.wall_marker)
        gmsh.model.setPhysicalName(1, self.wall_marker, "Walls")
        gmsh.model.addPhysicalGroup(1, inflow, self.inlet_marker)
        gmsh.model.setPhysicalName(1, self.inlet_marker, "Inlet")
        gmsh.model.addPhysicalGroup(1, outflow, self.outlet_marker)
        gmsh.model.setPhysicalName(1, self.outlet_marker, "Outlet")
        gmsh.model.addPhysicalGroup(1, obstacle, self.obstacle_marker)
        gmsh.model.setPhysicalName(1, self.obstacle_marker, "Obstacle")
        res_min = self.r / 3
        distance_field = gmsh.model.mesh.field.add("Distance")
        gmsh.model.mesh.field.setNumbers(distance_field, "EdgesList", obstacle)
        threshold_field = gmsh.model.mesh.field.add("Threshold")
        gmsh.model.mesh.field.setNumber(threshold_field, "IField", distance_field)
        gmsh.model.mesh.field.setNumber(threshold_field, "LcMin", res_min)
        gmsh.model.mesh.field.setNumber(threshold_field, "LcMax", 0.25 * self.H)
        gmsh.model.mesh.field.setNumber(threshold_field, "DistMin", self.r)
        gmsh.model.mesh.field.setNumber(threshold_field, "DistMax", 2 * self.H)
        min_field = gmsh.model.mesh.field.add("Min")
        gmsh.model.mesh.field.setNumbers(min_field, "FieldsList", [threshold_field])
        gmsh.model.mesh.field.setAsBackgroundMesh(min_field)
        gmsh.option.setNumber("Mesh.Algorithm", 8)
        gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 2)
        gmsh.option.setNumber("Mesh.RecombineAll", 1)
        gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 1)
        gmsh.model.mesh.generate(self.gdim)
        gmsh.model.mesh.setOrder(2)
        mesh, _, ft = gmshio.model_to_mesh(gmsh.model, self.mesh_comm, self.model_rank, gdim=self.gdim)
        ft.name = "facet markers"
        if self.visualize == 'true':
            if '-nopopup' not in sys.argv:
                gmsh.fltk.run()
        if self.save_mesh == 'true':
            gmsh.write("cylinders.msh")
        return mesh, ft
    def compute(self, mesh,  ft, points, jet, save='False'):
        jet_position = jet.get("position")
        jet_x = jet.get("jet_x")
        jet_y = jet.get("jet_y")
        bb_tree = geometry.BoundingBoxTree(mesh, mesh.topology.dim)
        jet_cells = []
        jet_points = []
        cells = []
        points_on_pro = []
        cell_candidates = geometry.compute_collisions(bb_tree, points.T)
        jet_cell_candidates = geometry.compute_collisions(bb_tree, jet_position.T)
        colliding_cells = geometry.compute_colliding_cells(mesh, cell_candidates, points.T)
        jet_colliding_cells = geometry.compute_colliding_cells(mesh, jet_cell_candidates, jet_position.T)
        for i, point in enumerate(points.T):
                points_on_pro.append(point)
        for i, jet_point in enumerate(jet_position.T):
            if len(jet_colliding_cells.links(i)) > 0:
                jet_points.append(jet_point)
                jet_cells.append(jet_colliding_cells.links(i)[0])
        t = 0
        T = 7  # Final time
        dt = 1 / 1600  # Time step size
        self.num_steps = 50 # int(T/dt)
        mu = Constant(mesh, PETSc.ScalarType(0.001))  # Dynamic viscosity
        rho = Constant(mesh, PETSc.ScalarType(1))  # Density
        v_cg2 = VectorElement("CG", mesh.ufl_cell(), 2)
        s_cg1 = FiniteElement("CG", mesh.ufl_cell(), 1)
        V = FunctionSpace(mesh, v_cg2)
        Q = FunctionSpace(mesh, s_cg1)
        fdim = mesh.topology.dim - 1
        # Define boundary conditions
        class InletVelocity():
            def __init__(self, t):
                self.t = t
            def __call__(self, x):
                values = np.zeros((2, x.shape[1]), dtype=PETSc.ScalarType)
                values[0] = 4 * 1.5 * x[1] * (0.41 - x[1]) / (0.41 ** 2)
                return values
        class JetVelocity():
            def __init__(self, t, jet_x, jet_y):
                self.t_jet = t
                self.jet_x = jet_x
                self.jet_y = jet_y
                values[1] = self.jet_y
                index = np.where(x[1, :] < 0.2)
                values[1, index] = -self.jet_y
                values[0] = self.jet_x
                return values
        # Inlet
        u_inlet = Function(V)
        u_jet = Function(V)
        inlet_velocity = InletVelocity(t)
        jet_velocity = JetVelocity(t, jet_x, jet_y)
        u_inlet.interpolate(inlet_velocity)
        u_jet.interpolate(jet_velocity)
        bcu_inflow = dirichletbc(u_inlet, locate_dofs_topological(V, fdim, ft.find(self.inlet_marker)))
        # Jets
        bcu_jets = dirichletbc(u_jet, locate_dofs_topological(V, fdim + 1, jet_cells))
        # Walls
        u_nonslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
        bcu_walls = dirichletbc(u_nonslip, locate_dofs_topological(V, fdim, ft.find(self.wall_marker)), V)
        # Obstacle
        bcu_obstacle = dirichletbc(u_nonslip, locate_dofs_topological(V, fdim, ft.find(self.obstacle_marker)), V)
        bcu = [bcu_inflow, bcu_obstacle, bcu_walls, bcu_jets]
        # Outlet
        bcp_outlet = dirichletbc(PETSc.ScalarType(0), locate_dofs_topological(Q, fdim, ft.find(self.outlet_marker)), Q)
        bcp = [bcp_outlet]
        u_ = Function(V)
        u_.name = "u"
        u_s = Function(V)
        u_n = Function(V)
        u_n1 = Function(V)
        p = TrialFunction(Q)
        q = TestFunction(Q)
        p_ = Function(Q)
        p_.name = "p"
        phi = Function(Q)
        # the first step
        f = Constant(mesh, PETSc.ScalarType((0, 0)))
        F1 = rho / k * dot(u - u_n, v) * dx
        F1 += inner(dot(1.5 * u_n - 0.5 * u_n1, 0.5 * nabla_grad(u + u_n)), v) * dx
        F1 += 0.5 * mu * inner(grad(u + u_n), grad(v)) * dx - dot(p_, div(v)) * dx
        F1 += dot(f, v) * dx
        a1 = form(lhs(F1))
        L1 = form(rhs(F1))
        A1 = create_matrix(a1)
        b1 = create_vector(L1)
        # the second step
        a2 = form(dot(grad(p), grad(q)) * dx)
        L2 = form(-rho / k * dot(div(u_s), q) * dx)
        A2.assemble()
        b2 = create_vector(L2)
        # the last step
        a3 = form(rho * dot(u, v) * dx)
        L3 = form(rho * dot(u_s, v) * dx - k * dot(nabla_grad(phi), v) * dx)
        A3 = assemble_matrix(a3)
        A3.assemble()
        b3 = create_vector(L3)
        # Solver for step 1
        solver1 = PETSc.KSP().create(mesh.comm)
        solver1.setOperators(A1)
        pc1 = solver1.getPC()
        pc1.setType(PETSc.PC.Type.JACOBI)
        # Solver for step 2
        solver2 = PETSc.KSP().create(mesh.comm)
        solver2.setOperators(A2)
        solver2.setType(PETSc.KSP.Type.MINRES)
        pc2 = solver2.getPC()
        pc2.setHYPREType("boomeramg")
        # Solver for step 3
        solver3 = PETSc.KSP().create(mesh.comm)
        solver3.setOperators(A3)
        pc3 = solver3.getPC()
        u_probes = []
        p_probes = []
        for i in range(self.num_steps):
            # Update current time step
            # Update inlet velocity
            inlet_velocity.t = t
            A1.zeroEntries()
            assemble_matrix(A1, a1, bcs=bcu)
            A1.assemble()
            with b1.localForm() as loc:
                loc.set(0)
            assemble_vector(b1, L1)
            set_bc(b1, bcu)
            solver1.solve(b1, u_s.vector)
            u_s.x.scatter_forward()
            # Step 2: Pressure corrrection step
            with b2.localForm() as loc:
                loc.set(0)
            assemble_vector(b2, L2)
            set_bc(b2, bcp)
            solver2.solve(b2, phi.vector)
            phi.x.scatter_forward()
            p_.vector.axpy(1, phi.vector)
            p_.x.scatter_forward()
            with b3.localForm() as loc:
                loc.set(0)
            assemble_vector(b3, L3)
            solver3.solve(b3, u_.vector)
            u_.x.scatter_forward()
            # write the data of probes
            u_values = u_.eval(points_on_pro, cells)
            p_values = p_.eval(points_on_pro, cells)
            u_probes.append(u_values)
            p_probes.append(p_values)
            dofmap = V.dofmap
            with u_.vector.localForm() as loc_, u_n.vector.localForm() as loc_n, u_n1.vector.localForm() as loc_n1:
                loc_n.copy(loc_n1)
                loc_.copy(loc_n)
        gmsh.clear()
        probes = {
            "p": p_probes,
            "u0": np.array(u_probes)[:, :, 0],
            "u1": np.array(u_probes)[:, :, 1]
        jet_config = {
            "jet_x": jet.get("jet_x"),
            "jet_y": jet.get("jet_y")
        domain_train = {
        cylinder_inlet, outlet, IC_0_1 = {}, {}, {}
        return cylinder_inlet, outlet, domain_train, IC_0_1, probes, jet_config
if __name__ == "__main__":
    from fluid_mechanics.area import *
    from math import sin, cos, pi
    r = 0.05
    x1 = r * cos(pi / 2) + 0.3
    y1 = r * sin(pi / 2) + 0.2
    x2 = r * cos(3 / 2 * pi) + 0.3
    y2 = r * sin(3 * pi / 2) + 0.2
    jet_positions = [(x1, y1, 0), (x2, y2, 0)]
    jet_coordinates = positions(jet_positions)
    jet = {
        "jet_x": 0,
        "jet_y": 0,
        "position": jet_coordinates
    points = np.array([[0.35, 0.3, 0.3, 0.25],
                       [0.2, 0.25, 0.15, 0.2],
                       [0, 0, 0, 0]])
    simu = simulation(c_x=0.3, c_y=0.2, o_x=0.3, o_y=0.2, r=0.05, r2=0.02)
    mesh, ft = simu.generate_mesh()
    cylinder_inlet, outlet, domain_train, IC_0_1, probes, jet_config = simu.compute(mesh=mesh, ft=ft, points=points,
        jet=jet, save='True')
Replace this with
            boundary_vertices = dolfinx.mesh.compute_incident_entities(mesh, boundary_facets, 1, 0)
as the error message clearly states that it expects a mesh as the first input:
