Hi, I tried to find some references on how to get vertices on…say…the interior boundary of a mesh but I couldn’t find anything.
The methods that I coded only work for the exterior boundary of a mesh. Here is a small working example of an outer disk which has an inner disk hole inside. I am interested in getting the vertices on the inner boundary.
from dolfinx import mesh
class DiskwithHoleMesh():
def __init__(self,
radius_inner = 0.3,
radius = 1.0,
center = (0.0, 0.0),
resolution: float = 0.005,
output_dir: str = './meshes',
self.radius = radius
self.center = center
self.resolution = resolution
self.name = 'disk'
self.radius_inner = radius_inner
self.output_dir = output_dir
if not os.path.exists(self.output_dir):
os.makedirs(self.output_dir)
def create_mesh(self,
order: int = 1):
domain = self.create_disk(self.name, order)
return domain
def create_disk(self, name: str = 'disk_with_hole', order: int = 1) -> gmsh.model:
model = gmsh.model()
model.add(name)
model.setCurrent(name)
outer_sphere = model.occ.addDisk(self.center[0], self.center[1], 0, self.radius, self.radius)
inner_sphere = model.occ.addDisk(self.center[0], self.center[1], 0, self.radius_inner,
self.radius_inner)
model_dim_tags = model.occ.cut([(2, outer_sphere)], [(2, inner_sphere)],
removeObject=True, removeTool=True)
model.occ.synchronize()
outer_surface = model.add_physical_group(2, [outer_sphere], tag=1)
inner_surface = model.add_physical_group(2, [inner_sphere], tag=2)
model.set_physical_name(2, outer_surface, "Outer Surface")
model.set_physical_name(2, inner_surface, "Inner Surface")
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", self.resolution)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", self.resolution)
model.mesh.generate(2)
gmsh.write(f"{self.output_dir}/{self.name}.msh")
domain, cell_marker, facet_marker = dolfinx.io.gmshio.model_to_mesh(
model, MPI.COMM_WORLD, 0, gdim=2)
gmsh.finalize()
return domain
disk_mesh = DiskwithHoleMesh(radius_inner=0.3, radius=1.0, resolution=0.05)
domain = disk_mesh.create_mesh(order=2)
disk_mesh.plot_mesh()
If I use the following function, it will only retrive the exterior boundary vertices.
def get_boundary_vertices(self):
boundary_vertices = mesh.locate_entities_boundary(
self.domain, 0, check_coordinates)
return boundary_vertices
