Hi all!
I went through all the posts related to finding the eigenvalues and the eigenvectors of a matrix constructed from a solution, but couldn’t implement them properly.
In the below MWE, I am finding the solution u to the Poisson equation on a disc. Next, I am creating a vector
U = as_vector((0, u))
Then I need to find the eigenvalues of F^T F, where
d = mesh.geometry().dim()
I = Identity(d)
F = I + grad(U)
Here is the MWE:
from mshr import Circle, generate_mesh
"eliminate_zeros": True, \
"precompute_ip_const": True}
class boundary(SubDomain):
return on_boundary
class disk(SubDomain):
return True
C = Circle(Point(0, 0), 3)
mesh = generate_mesh(C, 100)
surface_markers = MeshFunction("size_t", mesh, mesh.topology().dim(), 0)
boundary().mark(boundary_markers, 2)
disk().mark(surface_markers, 1)
dx = Measure('dx', domain=mesh, subdomain_data=surface_markers)
W1 = FunctionSpace(mesh, "Lagrange", 1)
G , mu = 1, 0.1
u_D=Constant(0.0)
bc = DirichletBC(W1, u_D, boundary_markers, 2)
u = TrialFunction(W1)
v = TestFunction(W1)
f = Constant(-G/mu) # f=-G/mu
a = dot(grad(u), grad(v))*dx
L = -f*v*dx
# Compute solution
u = Function(W1)
solve(a == L, u, bc)
I = Identity(d)
F = I + grad(U)
C = PETScMatrix()
C = assemble(F.T*F, tensor = C);
This raises the error:
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/assembling.py", line 202, in assemble
dolfin_form = _create_dolfin_form(form, form_compiler_parameters)
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/assembling.py", line 64, in _create_dolfin_form
raise TypeError("Invalid form type %s" % (type(form),))
TypeError: Invalid form type <class 'ufl.tensors.ComponentTensor'>
Any suggestions would be helpful.
