How to plot 3d beam after deformation, not colormap
Hi, I just began learning FEA/FEniCS. I followed the tutorial of linear elasticity of clamped 3d beam bending by its gravity. The codes run OK except that plot(u, mode=‘displacement’ gives an error of"NotImplementedError: It is not currently possible to manually set the aspect on 3D axes". Google shows it is because the latest matplotlib has problems of setting equal aspect for 3d. So I commented that line, and exported u to a .pvd file. In paraview it shows the original beam with some colormap. How can I plot the actual bended beam like what is shown in the tutorial, instead of a colormaping? I am not sure if this is a FEniCS or paraview question. Thank you!
The link to the tutorial:
https://fenicsproject.org/pub/tutorial/html/._ftut1008.html
and my codes are in the following (almost identical to the tutorial).
from ufl import nabla_div, nabla_grad
#import matplotlib.pyplot as plt
# scaled variables
L = 1; W = 0.2
mu = 1
rho = 1
delta = W/L
gamma = 0.4*delta**2
beta = 1.25
lambda_ = beta
g = gamma
# create mesh and define function space
#Boxmesh(x0,y0,z0, x,y,z,nx,ny,nz) create tetrahegonal mesh between two points with number of cells
mesh = BoxMesh(Point(0, 0, 0), Point(L, W, W), 10, 3, 3)
# define boundary condition
tol = 1E-14
def clamped_boundary(x, on_boundary):
    return on_boundary and x[0] < tol
# DirichletBC(FunctionSpace, value, boundary)
bc = DirichletBC(V, Constant((0, 0, 0)), clamped_boundary)
# define strain and stress
def sigma(u):
    return lambda_*nabla_div(u)*Identity(d) + 2*mu*epsilon(u)
# define vairational problem
d = u.geometric_dimension()  #space dimension
f = Constant((0, 0, -rho*g))   # gravity
T = Constant((0, 0, 0))
L = dot(f, v)*dx + dot(T, v)*ds
# compute solution
solve(a == L, u, bc)
# plot solution
#plot(u, title='Displacement', mode='displacement')  #Implemtn name error
# plot stress
s = sigma(u) - (1./3)*tr(sigma(u))*Identity(d)  # dviatoric stress
von_Mises = sqrt(3./2*inner(s,s))
von_Mises = project(von_Mises, V)
#plot(von_Mises, title='Stress Intensity')
# compute magnitue of displacement
u_magnitude = sqrt(dot(u, u))
u_magnitude = project(u_magnitude, V)
print('min/max u: ', u_magnitude.vector().get_local().min(), u_magnitude.vector().get_local().max())
# compute strain energy density
strain_energy_density = 0.5*inner(sigma(u), epsilon(u))
SED= project(strain_energy_density, V)
File('ft06_elasticity_u.pvd') << u
File('ft06_elasticity_vonMises.pvd') << von_Mises
File('ft06_elasticity_magnitude.pvd') << u_magnitude
you can try with:
# plot solution
from vedo.dolfin import plot
plot(u, mode="displacements with arrows", text='displaced mesh', interactive=False)
plot(SED, text='strain energy density', new=True, size=(900,400), pos=(1100,0), zoom=2)
Screenshot from 2021-04-05 12-50-34
Hi marcomusy, Thank you for the solution. It is beautiful and exactly what I wanted. Unfortunately I use Fenics Docker, which does not have vedo. But I sort of figured out in parameter, to use wrap by vector filter.
i’m not very familiar with docker, but you can also generate an offscreen image with
cam = dict(pos=(2.04, -0.751, 0.336),
           focalPoint=(0.563, 0.169, -0.0380),
           viewup=(-0.162, 0.137, 0.977),
           distance=1.78,
           clippingRange=(0.676, 3.15))
plt = plot(u, mode="displacements with arrows", text='displaced mesh', camera=cam, offscreen=True)
plt.screenshot('screenshot.png')
…if it helps
Thank you so much marcomusy. Right now it seems the docker image does not have vedo package; and I am not skillful enough to build a new docker image. I have written down your solution in case I will run another FEniCS system on Anaconda.
You can simply install vedo in the docker container by calling pip3 install vedo
Thank you dokken. Would the vedo stay with the image, or I need to install it every time when a container is created?
This depends on your usage of docker.
If you always run docker run -it ... you are creating a new container each time. However, let’s say you run docker run -ti .... —name=dolfin_container ....
and install Vedo in this container, you can start this container (with vedo) later by running docker container start -i dolfin_container.
That makes sense. Thank you @dokken and @marcomusy .
