Error in opening 3D plots in fenics and .pvd files in Paraview 5.8.0 in Ubuntu 19.04
Hi Guys,
I am encountering two errors in the opening of the plots of example file elasticity
# from mpl_toolkits.mplot3d import Axes3D
%matplotlib inline
# from dolfin import *
# from mshr import *
from ufl import nabla_div
# Scaled Variables
L = 1
W = 0.2
mu = 1
rho = 1
delta = W/L
gamma = 0.4*delta**2
beta = 1.25
lambda_ = beta
g = gamma
# Create Mesh and define function space
mesh = BoxMesh(Point(0,0,0), Point(L,W,W), 10, 3, 3)
# Define Boundary Conditions
tol = 1e-14
def clamped_boundary(x, on_boundary):
    return on_boundary and x[0] < tol
bc = DirichletBC(V, Constant((0,0,0)), clamped_boundary)
# Define Strain and Stress
    return 0.5 * (nabla_grad(u) + nabla_grad(u).T)
def sigma(u):
    return lambda_*nabla_div(u)*Identity(d) + 2*mu*epsilon(u)
d = u.geometric_dimension() # space dimension
f = Constant((0,0,-rho*g))
T = Constant((0,0,0))
L = dot(f, v)*dx + dot(T, v)*ds
# Compute Solution
solve(a == L, u, bc)
# Plot Solution
plot(u)
Everything works fine except the plot and error is
NotImplementedError                       Traceback (most recent call last)
<ipython-input-64-bc2b1359fe27> in <module>
     61
     62 # Plot Solution
---> 63 plot(u)
~/anaconda3/envs/fenicsproject/lib/python3.7/site-packages/dolfin/common/plotting.py in plot(object, *args, **kwargs)
    436     # Plot
    437     if backend == "matplotlib":
--> 438         return _plot_matplotlib(object, mesh, kwargs)
    439     elif backend == "x3dom":
    440         return _plot_x3dom(object, kwargs)
~/anaconda3/envs/fenicsproject/lib/python3.7/site-packages/dolfin/common/plotting.py in _plot_matplotlib(obj, mesh, kwargs)
    280     else:
    281         ax = plt.gca()
--> 282     ax.set_aspect('equal')
    283
    284     title = kwargs.pop("title", None)
~/anaconda3/envs/fenicsproject/lib/python3.7/site-packages/matplotlib/axes/_base.py in set_aspect(self, aspect, adjustable, anchor, share)
   1279         if (not cbook._str_equal(aspect, 'auto')) and self.name == '3d':
   1280             raise NotImplementedError(
-> 1281                 'It is not currently possible to manually set the aspect '
   1282                 'on 3D axes')
   1283
NotImplementedError: It is not currently possible to manually set the aspect on 3D axes
I also save the .pvd and .vtu files and tried to open it in Paraview 5.8.0. But I encountered this error
ERROR: In /home/buildslave/dashboards/buildbot/paraview-pvbinsdash-linux-shared-release_superbuild/build/superbuild/paraview/src/VTK/IO/XML/vtkXMLUnstructuredDataReader.cxx, line 649
vtkXMLUnstructuredGridReader (0x95efa70): Error reading cell offsets: Unsupported array type: vtkUnsignedIntArray
I am currently using ubuntu 19.04 to run the cases.
This looks like a basic error but can’t solve it. Can anyone tell me how to resolve this issue?
Thanks a lot
This is fixed in the development version of FEniCS, with the following commit. You can alternatively use vtkplotter to visualize the data.
Could you share how you saved it to pvd, as older versions of paraview seem to work fine. (Latest release of paraview 5.8 is just one day old.)
Thanks a lot for the reply. I installed vtlplotter in it is working and I can view the plot within the jupyter-notebook.
To save the solution I used following code.
# Save solution to file in VTK format
vtkfile = File('elasticity/solution.pvd')
vtkfile << u
I just want to confirm that this is an error that I get with ParaView 5.8 RC3. ParaView 5.7 works. Is it a deprecated format or a bug in ParaView? The former would require a fix on FEniCS side, the latter not.
I tried it in the Paraview 5.7 version and it is working !!!
I think it might be a bug in the Paraview 5.8 version.
Thanks again for the help
Issue added to Paraview gitlab
Will be Fixed in Paraview release 5.8.1
