NotImplementedError: Axes3D currently only supports the aspect argument 'auto'. You passed in 'equal'
I just recently reinstalled fenics in wsl using conda
conda create -n fenics -c conda-forge fenics
And I am trying to run a sample code in fenics
# from mpl_toolkits.mplot3d import Axes3D
%matplotlib inline
# from dolfin import *
# from mshr import *
from ufl import nabla_div
# Scaled Variables
L = 1
W = 0.2
mu = 1
rho = 1
delta = W/L
gamma = 0.4*delta**2
beta = 1.25
lambda_ = beta
g = gamma
# Create Mesh and define function space
mesh = BoxMesh(Point(0,0,0), Point(L,W,W), 10, 3, 3)
# Define Boundary Conditions
tol = 1e-14
def clamped_boundary(x, on_boundary):
    return on_boundary and x[0] < tol
bc = DirichletBC(V, Constant((0,0,0)), clamped_boundary)
# Define Strain and Stress
    return 0.5 * (nabla_grad(u) + nabla_grad(u).T)
def sigma(u):
    return lambda_*nabla_div(u)*Identity(d) + 2*mu*epsilon(u)
d = u.geometric_dimension() # space dimension
f = Constant((0,0,-rho*g))
T = Constant((0,0,0))
L = dot(f, v)*dx + dot(T, v)*ds
# Compute Solution
solve(a == L, u, bc)
# Plot Solution
plot(u)
I encountered this error,
NotImplementedError                       Traceback (most recent call last)
<ipython-input-8-570178011df2> in <module>
     60
     61 # Plot Solution
---> 62 plot(u)
~/anaconda3/envs/fenics/lib/python3.8/site-packages/dolfin/common/plotting.py in plot(object, *args, **kwargs)
    436     # Plot
    437     if backend == "matplotlib":
--> 438         return _plot_matplotlib(object, mesh, kwargs)
    439     elif backend == "x3dom":
    440         return _plot_x3dom(object, kwargs)
~/anaconda3/envs/fenics/lib/python3.8/site-packages/dolfin/common/plotting.py in _plot_matplotlib(obj, mesh, kwargs)
    280     else:
    281         ax = plt.gca()
--> 282     ax.set_aspect('equal')
    283
    284     title = kwargs.pop("title", None)
~/anaconda3/envs/fenics/lib/python3.8/site-packages/mpl_toolkits/mplot3d/axes3d.py in set_aspect(self, aspect, adjustable, anchor, share)
    321         """
    322         if aspect != 'auto':
--> 323             raise NotImplementedError(
    324                 "Axes3D currently only supports the aspect argument "
    325                 f"'auto'. You passed in {aspect!r}."
NotImplementedError: Axes3D currently only supports the aspect argument 'auto'. You passed in 'equal'.
I think in the plotting.py file the ax.set_aspect("equal") instead of “auto”.
Can you tell me how to bypass this error?
This is an old issue in matplotlib. You should be able to reproduce this outside of FEniCS too!
If you want to hack FEniCS’ plot function, then try changing line 282 to ax.set_aspect("auto"). If not, then I would recommend taking a look at @marcomusy’s Vedo examples, or simply using Paraview.
With vedo, you can start at:
from vedo.dolfin import plot as vplot
vplot(u)
This issue has also been fixed in the master branch of dolfin: https://bitbucket.org/fenics-project/dolfin/commits/5e86e7e3409a8d9ec4b1f40aa2b361d5de84d2a0
Thanks for the help. Now it is working
Hi
I got same error now. How to solve this?
I also try vedo. however each time I run with vplot(u), the kernel dies.
Thank you so much.
Use the latest version of dolfin (master branch) NotImplementedError: Axes3D currently only supports the aspect argument 'auto'. You passed in 'equal' - #3 by dokken
