I have added adios4dolfinx in ns_code2.ipynb by forking dolfinx-tutorial repo. In particular, I am storing mesh and function at each time step.
adios4dolfinx.write_mesh(cp_filename, mesh)
adios4dolfinx.write_function(cp_filename, u_, time=t, name="u_function")
adios4dolfinx.write_function(cp_filename, p_, time=t, name="p_function")
Commit shown on this link: (Adios coupled · hassaniqbal209/dolfinx-tutorial@d8ecf22 · GitHub)).
The goal is to run with dolfinx the following code written in dolfin: https://github.com/hplgit/fenics-tutorial/blob/master/pub/python/vol1/ft09_reaction_system.py.
Made some changes corresponding to migration to dolfinx (as shown in commit above) but currently receiving error in adios4dolfinx.read_function() in advdiffreac.ipynb
Can you please guide how to go about resolving this?
AssertionError Traceback (most recent call last)
Cell In[38], line 6
4 w = fem.Function(W)
5 # adios4dolfinx.read_function(“./Flows/flow_function_0”, w)
----> 6 adios4dolfinx.read_function(cp_filename, w, time=0, name=“u_function”)
7 # mkdir -p Flows/flow_function_0
8 # touch Flows/flow_function_0/md.0 Flows/flow_function_0/md.idxFile ~/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/adios4dolfinx/checkpointing.py:358, in read_function(filename, u, engine, time, legacy, name)
354 # Compute owner of dofs in dofmap
355 num_dofs_global = (
356 u.function_space.dofmap.index_map.size_global * u.function_space.dofmap.index_map_bs
357 )
→ 358 dof_owner = index_owner(comm, input_dofmap.array, num_dofs_global)
360 # --------------------Step 4-----------------------------------
361 # Read array from file and communicate them to input dofmap process
362 if legacy:File ~/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/adios4dolfinx/utils.py:127, in index_owner(comm, indices, N)
119 “”"
120 Find which rank (local to comm) which owns anindex, given that
121 data of sizeNhas been split equally among the ranks.
124 processes gets an extra value.
125 “”"
126 size = comm.size
→ 127 assert (indices < N).all()
128 n = N // size
129 r = N % sizeAssertionError:
if the degree is changed from 2 to 3 in the following
W = fem.functionspace(
mesh=msh,
element=element( # For Vector Function Space using Vector Element
family="Lagrange", cell=msh.topology.cell_name(), degree=2
The assertion error is resolved. However, a new error is received on
F = (
(u1 - u_n1) / Delta_t * v1
+ ufl.dot(w, ufl.grad(u1)) * v1
+ eps * ufl.dot(ufl.grad(u1), ufl.grad(v1))
) * ufl.dx
as follows
ValueError Traceback (most recent call last)
Cell In[42], line 20
15 f2.interpolate(lambda x: source(x, np.array([0.1, 0.3]), 0.05))
16 f3.x.array[:] = 0.0
18 F = (
19 (u1 - u_n1) / Delta_t * v1
—> 20 + ufl.dot(w, ufl.grad(u1)) * v1
21 + eps * ufl.dot(ufl.grad(u1), ufl.grad(v1))
22 ) * ufl.dx
23 F += (
24 (u2 - u_n2) / Delta_t * v2
25 + ufl.dot(w, ufl.grad(u2)) * v2
26 + eps * ufl.dot(ufl.grad(u2), ufl.grad(v2))
27 ) * ufl.dx
28 F += (
29 (u3 - u_n3) / Delta_t * v3
30 + ufl.dot(w, ufl.grad(u3)) * v3
31 + eps * ufl.dot(ufl.grad(u3), ufl.grad(v3))
32 ) * ufl.dxFile ~/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ufl/operators.py:225, in dot(a, b)
223 if a.ufl_shape == () and b.ufl_shape == ():
224 return a * b
→ 225 return Dot(a, b)File ~/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ufl/tensoralgebra.py:212, in Dot.new(cls, a, b)
210 # Checks
211 if not ((ar >= 1 and br >= 1) or scalar):
→ 212 raise ValueError(
213 “Dot product requires non-scalar arguments, "
214 f"got arguments with ranks {ar} and {br}.”
215 )
216 if not (scalar or ash[-1] == bsh[0]):
217 raise ValueError(“Dimension mismatch in dot product.”)ValueError: Dot product requires non-scalar arguments, got arguments with ranks 0 and 1.
