How to run fenics in parallel?
Hi all,
I’m trying to run my scrip in parallel with
mpirun -np 64 python3 script.py
but get the following error in the terminal:
[v-VirtualBox:02207] *** Process received signal ***
[v-VirtualBox:02207] Signal: Segmentation fault (11)
[v-VirtualBox:02207] Signal code: Address not mapped (1)
[v-VirtualBox:02207] Failing at address: 0x28
[v-VirtualBox:02207] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890)[0x7f83d6214890]
[v-VirtualBox:02207] [ 1] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi/mca_pmix_pmix112.so(+0x31433)[0x7f83cd366433]
[v-VirtualBox:02207] [ 2] /usr/lib/x86_64-linux-gnu/libopen-pal.so.20(opal_libevent2022_event_base_loop+0x7f1)[0x7f83d6486c31]
[v-VirtualBox:02207] [ 3] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi/mca_pmix_pmix112.so(+0x2efcd)[0x7f83cd363fcd]
[v-VirtualBox:02207] [ 4] /lib/x86_64-linux-gnu/libpthread.so.0(+0x76db)[0x7f83d62096db]
[v-VirtualBox:02207] [ 5] /lib/x86_64-linux-gnu/libc.so.6(clone+0x3f)[0x7f83d5f3288f]
[v-VirtualBox:02207] *** End of error message ***
Segmentation fault (core dumped)
Here all the modules that I am including:
from dolfin import*
from matplotlib import *
import os
from scipy.interpolate import interp1d
import scipy as sp
What causes the error? Is there some kind of document that helps using fenics in parallel?
Thank you!
How did you install dolfin?
Usually, dolfin scripts run out of the box in parallel (few exceptions)
Have you tried to run some of the demos in parallel?
(Bitbucket)
I installed it like this:
sudo apt-get install software-properties-common
sudo apt-get update
sudo apt-get install --no-install-recommends fenics
I haven’t tried running the simulations, thanks for the hint, will do it.
