How to scale vector element for specific subdomain
Hi there,
I am trying to scale my vector field by some constant. But, I cannot get the correct dofs of the subdomain. Here is the MWE;
import pyvista
from dolfinx.fem import (Constant, dirichletbc, Function, FunctionSpace, assemble_scalar,
                         form, locate_dofs_geometrical, locate_dofs_topological)
from dolfinx.mesh import create_unit_square, locate_entities
from ufl import VectorElement
# pyvista.start_xvfb()
# Q = FunctionSpace(mesh, ("DG", 0))
v_cg = VectorElement("CG", mesh.ufl_cell(), 1)
Q = FunctionSpace(mesh, v_cg)
def Omega_0(x):
    return x[1] <= 0.3
def Omega_1(x):
    return x[1] >= 0.7
kappa = Function(Q)
cells_0 = locate_entities(mesh, mesh.topology.dim, Omega_0)
cells_1 = locate_entities(mesh, mesh.topology.dim, Omega_1)
dofs_0 = locate_dofs_geometrical(Q, Omega_0)
dofs_1 = locate_dofs_geometrical(Q, Omega_1)
kappa.x.array[dofs_0] = 1
kappa.x.array[dofs_1] = 0.1
with XDMFFile(MPI.COMM_WORLD, "test.xdmf", "w", encoding=XDMFFile.Encoding.HDF5 ) as xdmf:
    xdmf.write_mesh(mesh)
    xdmf.write_function(kappa)
I import subdomains from gmsh and I can access the cell tags by;
cell_tags = subdomains.find(tag)
How can I access the dofs of the cell_tags?
I get this;
Screenshot from 2023-03-16 19-05-42
whereas I should get this;
Screenshot from 2023-03-16 19-06-50
Any help would be much appreciated!
One way to do it is by unrolling the dofmap (as you are using a vector function space):
import numba
from dolfinx.fem import (Function, FunctionSpace,
                         locate_dofs_geometrical)
def Omega_0(x):
    return x[1] <= 0.3
def Omega_1(x):
    return x[1] >= 0.7
kappa = Function(Q)
@numba.njit
def unroll_dofmap(dofs, bs):
    dofs_unrolled = np.zeros(bs*len(dofs), dtype=np.int32)
    for i, dof in enumerate(dofs):
        for b in range(bs):
            dofs_unrolled[i*bs+b] = dof*bs+b
    return dofs_unrolled
dofmap_bs = Q.dofmap.bs
kappa.x.array[unroll_dofmap(dofs_0, dofmap_bs)] = 1
kappa.x.array[unroll_dofmap(dofs_1, dofmap_bs)] = 0.1
with XDMFFile(MPI.COMM_WORLD, "test.xdmf", "w", encoding=XDMFFile.Encoding.HDF5) as xdmf:
There is another way that should be better (I will post it later when I have time to jot it down).
Here is an example using only topological information, and illustrating the speedup compared to using locate_dofs_geometrical:
import time
import numba
from dolfinx.fem import (Function, FunctionSpace, locate_dofs_geometrical,
N = 1000
mesh = create_unit_square(MPI.COMM_WORLD, N, N)
def Omega_0(x, tol=1e-13):
    return x[1] <= 0.3 + tol
def Omega_1(x, tol=1e-13):
    return x[1] >= 0.7 - tol
kappa = Function(Q)
@numba.njit
        for b in range(bs):
# cold start to compile code
unroll_dofmap(np.array([0], dtype=np.int32), dofmap_bs)
MPI.COMM_WORLD.Barrier()
start = time.perf_counter()
dofs_0 = locate_dofs_topological(Q, mesh.topology.dim, cells_0)
dofs_1 = locate_dofs_topological(Q, mesh.topology.dim, cells_1)
kappa.x.scatter_forward()
end = time.perf_counter()
total_time = MPI.COMM_WORLD.gather(end-start, root=0)
if MPI.COMM_WORLD.rank == 0:
    print(
        f"Topological: {min(total_time)=:.2e} {max(total_time)=:.2e} avg(total_time)={sum(total_time)/len(total_time):.2e}")
kappa2 = Function(Q)
kappa2.x.array[unroll_dofmap(dofs_0, dofmap_bs)] = 1
kappa2.x.array[unroll_dofmap(dofs_1, dofmap_bs)] = 0.1
kappa2.x.scatter_forward()
    print(
        f"Geometrical: {min(total_time)=:.2e} {max(total_time)=:.2e} avg(total_time)={sum(total_time)/len(total_time):.2e}")
assert np.allclose(kappa2.x.array, kappa.x.array)
which gives
Serial:
Topological: min(total_time)=1.24e-01 max(total_time)=1.24e-01 avg(total_time)=1.24e-01
Geometrical: min(total_time)=2.15e-01 max(total_time)=2.15e-01 avg(total_time)=2.15e-01
2 proc:
Topological: min(total_time)=9.93e-02 max(total_time)=9.93e-02 avg(total_time)=9.93e-02
Geometrical: min(total_time)=1.08e-01 max(total_time)=1.08e-01 avg(total_time)=1.08e-01
And if you want to enter the “danger-zone”/special case of entities=cells, you can set remote=False in
dofs_0 = locate_dofs_topological(Q, mesh.topology.dim, cells_0, remote=False)
dofs_1 = locate_dofs_topological(Q, mesh.topology.dim, cells_1, remote=False)
to improve performance even further
