I want to specify a Dirichlet boundary condition, which depends on a Function object rather than a constant (e.g. ScalarType(0), as is often the case in the standard examples I found). The following MWE produces a dtype error. My question is how this could be done properly.
Thank you.
import numpy
from ufl import (SpatialCoordinate, FiniteElement, MixedElement,
split, TestFunctions)
from dolfinx import fem, mesh
from dolfinx.fem import FunctionSpace, Function
# Geometry and mesh
x_left = -0.1
x_right = +0.1
NumberOfCells = int(1e3)
msh = mesh.create_interval(MPI.COMM_WORLD, NumberOfCells, points=(x_left, x_right))
x = SpatialCoordinate(msh)
CG1_elem = FiniteElement("CG", msh.ufl_cell(), 1)
ME_elem = MixedElement([CG1_elem, CG1_elem])
ME = FunctionSpace(msh, ME_elem)
u_test, v_test = TestFunctions(ME)
w = Function(ME)
u, v = split(w)
# Left boundary
facet_l_bdry = mesh.locate_entities_boundary(msh, dim=0, marker=lambda x: numpy.isclose(x[0], x_left))
dof_l_bdry = fem.locate_dofs_topological(V=ME.sub(1), entity_dim=0, entities=facet_l_bdry)
f = 2*u
PoissonEq_dirichlet_bc_l = fem.dirichletbc(value=2*u, dofs=dof_l_bdry, V=ME.sub(1))
Hi dokken,
thank you for your answer. Maybe my MWE was too obscure (and also not really a MWE, sorry for that). My problem is that I am not able to provide any Function object in a Dirichlet boundary condition. I tried to further reduce the MWE:
from ufl import SpatialCoordinate, FiniteElement
# Geometry and mesh
x_left = -0.1
x_right = +0.1
NumberOfCells = int(10)
s_cg1 = FiniteElement("CG", msh.ufl_cell(), 1)
V = FunctionSpace(msh, s_cg1)
# left boundary
facet_l_bdry = mesh.locate_entities_boundary(msh, dim=0, marker=lambda x: np.isclose(x[0], x_left))
dof_l_bdry = fem.locate_dofs_topological(V=V, entity_dim=0, entities=facet_l_bdry)
PoissonEq_dirichlet_bc_l = fem.dirichletbc(value=u, dofs=dof_l_bdry, V=V)
