How to set the initial conditions in FEniCSx
Hello, every one
I am new to FEniCSx.
It is quite simple to set the initial conditions in FEniCS. The following example is written by FEnics.
set the intial conditions in FEniCS
import time
import matplotlib
T = 2.0 # final time
num_steps = 10 # number of time steps
Create mesh and define function space
nx = ny = 20
mesh = RectangleMesh(Point(0,0), Point(1,1), nx, ny)
V = FunctionSpace(mesh, ‘P’, 1)
Define initial value
u_0 = Expression(‘10.0’,degree=2)
u_n = interpolate(u_0, V)
u_n.rename(‘u’, ‘initial value’)
plt.figure(0)
plot(u_n)
But I have some difficulty in setting the same conditions using FEniCSx. There are some problems in the following codes. Could you give some help?
import time
from dolfinx import fem, mesh, io, plot
from ufl import SpatialCoordinate
T=2.0
num_steps=10
dt=T/num_steps
creat mesh and define function space
nx, ny = 20, 20
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([1, 1])],
[nx, ny], mesh.CellType.triangle)
tdim=domain.topology.dim
num_cells=domain.topology.index_map(tdim).size_local
V = fem.FunctionSpace(domain, (“CG”, 1))
u_0=10.0
u_n.interpolate(u_0,num_cells)
u_n.rename (“u_n”)
Thank you very much in advance.
Best regards,
Lei
Please use markdown formatting, i.e.
```python
mesh = .....
def f(x):
   return x
to make the code render nicely.
If you want to set the initial condition as a constant value you can either do
u_n.x.array[:] = 10.
or
u_n.interpolate(lambda x: numpy.full(x.shape[1], 10, dtype=numpy.float64))
Hi, Jorgen
Thank you very much for your quick reply.
I had been looking for the answers for several days. Thanks for helping me out. I really appreciate that!
Next time I will use the markdown formatting.
Best regards,
Lei
