Hello everyone,
i am currently working on a contact model for a multibody contact of a rigid circular shaped indenter and an elastic domain. The indenter should be realized as a boundary condition because of a considerable difference in stiffness (steel compared to rubber).
This topic refers to:
- my last topic
- the example: Hertzian contact with a rigid indenter using a penalty approach
- and the answers of @dokken and @evzen
However, I have difficulties creating a penalty term which use both x and y displacements of the rigid indenter as an additional energy term in the formulation. I tried lots of different ways to implement a circle equation but nothing worked. My idea was to use something like this:
def in_circle(x):
return np.less_equal( ((x[0]-center_x)**2 + (x[1]-center_y)**2), ((D/2)**2))
The MWE should realize the sketch below, where a circular boundary should cause a static deformation realized with linear elasticity and the penalty approach:
The code for the dolfinx MWE + mesh generation using gmsh:
from dolfinx import fem
from dolfinx.io import XDMFFile, gmshio
from petsc4py.PETSc import ScalarType, Options
from ufl import dx, inner, derivative, tr, Identity, sym, grad, TrialFunction, TestFunction, Measure
gmsh.model.add("rectangle")
lc=1e-1
# generate points for inner contour
gmsh.model.geo.addPoint(1, 1, 0, lc, 1)
gmsh.model.geo.addPoint(-1, 1, 0, lc, 2)
gmsh.model.geo.addPoint(-1, -1, 0, lc, 3)
gmsh.model.geo.addPoint(1, -1, 0, lc, 4)
# generate inner contour
gmsh.model.geo.addLine(1, 2, 1)
gmsh.model.geo.addLine(2, 3, 2)
gmsh.model.geo.addLine(3, 4, 3)
gmsh.model.geo.addLine(4, 1, 4)
# generate points for outer contour
gmsh.model.geo.addPoint(2, 2, 0, lc, 5)
gmsh.model.geo.addPoint(-2, 2, 0, lc, 6)
gmsh.model.geo.addPoint(-2, -2, 0, lc, 7)
gmsh.model.geo.addPoint(2, -2, 0, lc, 8)
# generate outer contour
gmsh.model.geo.addLine(5, 6, 5)
gmsh.model.geo.addLine(6, 7, 6)
gmsh.model.geo.addLine(7, 8, 7)
gmsh.model.geo.addLine(8, 5, 8)
# generate curveloops
gmsh.model.geo.addCurveLoop([1, 2, 3, 4], 1)
gmsh.model.geo.addCurveLoop([5, 6, 7, 8], 2)
# generate surface
gmsh.model.geo.addPlaneSurface([2, 1], 1)
gmsh.model.geo.synchronize()
# generate physical groups for boundary conditions
inside, outside, surface = 1, 2, 3
gmsh.model.addPhysicalGroup(1, [1, 2, 3, 4], inside, name="Inner Contour")
gmsh.model.addPhysicalGroup(1, [5, 6, 7, 8], outside, name="Outer Contour")
gmsh.model.addPhysicalGroup(2, [1], surface, name="Surface")
# finish gmsh
gmsh.model.mesh.generate(2)
gmsh.write("rectangle.msh")
# create a DOLFINx mesh
dim = 2
gmsh_model_rank = 0
domain_com = MPI.COMM_SELF
domain, cell_markers, facet_markers = gmshio.model_to_mesh(gmsh.model, domain_com, gmsh_model_rank, dim)
domain.name = "Stator"
cell_markers.name = f"{domain.name}_cells"
facet_markers.name = f"{domain.name}_facets"
with XDMFFile(domain.comm, f"rectangle_mesh_{MPI.COMM_SELF.rank}.xdmf", "w") as file:
file.write_mesh(domain)
file.write_meshtags(cell_markers)
domain.topology.create_connectivity(domain.topology.dim - 1, domain.topology.dim)
file.write_meshtags(facet_markers)
gmsh.finalize()
tdim = domain.topology.dim
fdim = tdim - 1
# define inner boundry
ds = Measure('ds', domain=domain, subdomain_data=facet_markers, metadata=metadata)
# define function space
V = fem.VectorFunctionSpace(domain, ("CG",1))
# definition of circular shape
########## Insert 'circle' here ##########
# test and trial functions
u = fem.Function(V, name="Displacement")
du = TrialFunction(V)
u_ = TestFunction(V)
# define outer contour as homogenous boundary condition
u_zero = np.array((0,)*domain.geometry.dim, dtype=ScalarType)
bc = fem.dirichletbc(u_zero, fem.locate_dofs_topological(V, fdim, facet_markers.find(outside)), V)
# constituive relation
E = fem.Constant(domain, ScalarType(10.))
nu = fem.Constant(domain, ScalarType(0.3))
mu = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
def eps(v):
return sym(grad(v))
def sigma(v):
return lmbda*tr(eps(v))*Identity(2) + 2.0*mu*eps(v)
def ppos(x):
return (x+np.abs(x))/2.
pen = fem.Constant(domain, ScalarType(1e4))
form = inner(sigma(u), eps(u_))*dx
#form = inner(sigma(u), eps(u_))*dx +pen*dot(u_, ppos(u-circle))*ds(1)
J = derivative(form, u, du)
problem = fem.petsc.NonlinearProblem(form, u, bcs=[bc], J=J)
from dolfinx import nls
solver = nls.petsc.NewtonSolver(domain.comm, problem)
with XDMFFile(domain.comm, "rec_output.xdmf", "w") as file:
file.write_function(u)
I use FEniCSx 0.6.0 inside a Docker container.
Many thanks in advance!
