Solving lagrange multiplier problem via iterative solver
Hello there friends from the fenicsx community,
I am following the example given in: scifem/examples/real_function_space.py at main · scientificcomputing/scifem · GitHub
to solve a Neumann-only boundary value problem by means of a Lagrangian multiplier.
In general, if I follow the example provided in the link, the results that I obtain work nicely. However, once I try to scale my simulation to a denser grid, the steps related to solving this linear system take a significant amount of my computation time.
I was wondering if it was possible to use an iterative solver in combination with this realfunction space approach to speed up the evaluation process?
As mentioned above, I follow exactly the provided example, even with the settings for the direct solver.
Any comment will be highly appreciated.
A request for this sort of capability was recently requested on the scifem repo at Real elements with non-linear problems · Issue #114 · scientificcomputing/scifem · GitHub
but the requestor found that a possible solution was already available at
