I am trying to overload the built-in newton solver to implement a linear algebra trick. Specifically,
I am solving a system of linearized virtual work equations of the form [\mathbf{K} - k\mathbf{a} \otimes \mathbf{a}]\Delta\mathbf{u} =- \mathbf{F}. Here the tangent stiffness matrix \mathbf{K} is modified by the term k\mathbf{a} \otimes \mathbf{a}. Notably, \mathbf{K} is sparse, while the term k\mathbf{a} \otimes \mathbf{a} results in a full matrix. This problem can be solved efficiently (without ever forming the full matrix) using the Sherman-Morisson formula as follows:
(\mathbf{K} - k\mathbf{a} \otimes \mathbf{a})^{-1} = \mathbf{K}^{-1} - \frac{k\mathbf{K}^{-1} \mathbf{aa^T}\mathbf{K}^{-1}} {1 + k\mathbf{a^T} \mathbf{K}^{-1} \mathbf{a}} so
\Delta\mathbf{u} = -\mathbf{K}^{-1} \mathbf{F} + \frac{k \mathbf{K}^{-1}\mathbf{a}\mathbf{F }} {1 + k\mathbf{a} \mathbf{K}^{-1} \mathbf{a}} \mathbf{K}^{-1} \mathbf{a}
(See for example: http://fourier.eng.hmc.edu/e176/lectures/algebra/node6.html)
I have implemented the above as shown in the pseudo-code below (MWE is difficult…), but it is quite slow and I have no real control over the size of the Newton step. I am hoping that by overloading the built in solver, I can get access to PETSc’s line-search. From what I understand, I just have to overload methods for updating K and F, but I can’t seem to find the docs to help me. I did find this on the firedrake docs - https://www.firedrakeproject.org/petsc-interface.html#defining-a-preconditioner, but I have very limited experience with PETSc so any tips would be greatly appreciated. Thanks!
def NRsolver(self, external_load):
delU = Function(self.V) # incremental displacement
self.inc_load = Function(self.Vs) # incremental load
discr = 10
j = 0 # FOR CONVERGENCE COUNTER
f_form1 = #....bunch of calls to collect different parts of the rhs form
f_form2 = ...
k_form1 = ... # lhs (form of K above)
k_form2 = ...# self.K_load()
a_form = # code for form of vector a
# step up pressure vector in discr increments
for i in np.linspace(0.0, 1.0, discr):
# code to update external load vector goes here
n = self.update_normals()
delU.vector()[:] = -0.3
counter = 0
while (norm(delU) > self.tol):
current_int_p = ..... #return Constant
k = # ... call to function to calculate scalar k
a = assemble(a_form) # assemble a here because it for Sherman-Morisson
# collect all RHS
F = assemble(f_form2 - f_form1) - current_int_p*a
# collect all LHS
K = assemble(k_form1 + current_int_p*k_form2)
for bc in self.bc:
bc.apply(K, F)
bc.apply(K, a)
# Sherman-Morisson formula
Q = Function(self.V).vector()
R = Function(self.V).vector()
solve(K, Q, -F)
solve(K, R, -a)
beta = 1 / (1 + k * a.inner(R))
delU.vector()[:] = Q + beta * k * R.inner(F) * R
self.u.vector().axpy(0.25, delU.vector()) # poor man's line search
counter += 1
if (counter > 80):
raise Exception("Counter allowance exceeded")
j += 1
