Hi. I’m trying to evolve a complex gaussian package under the harmonic oscillator Hamiltonian by means of an semi-implicit Euler scheme. In the next code at final line I received the error message “IndexError: tuple index out of range” but I don’t found that’s happen:
import matplotlib.pyplot as mpl
a = -4.5
b = 4.5
N = 200
T = 6.0 # final time
num_steps = 80 # number of time steps
n_save = 5 # save every n_save steps
Dt = T / num_steps # time step size
x0 = -1. # initial coordinate
p0 = 0.5 # initial momentum
mesh = generate_mesh(Rectangle(Point(a, -1), Point(b,1)), 64)# mesh has 2 dimensions: real and imaginary parts
V = FunctionSpace(mesh, 'CG', 2)
tol = 1E-14
def boundary(x, on_boundary):
return on_boundary
bc = DirichletBC(V, Constant(0), boundary)
u_0 = Expression('cos(p0*x[0])*exp(-0.5*pow((x[0]-x0),2))', 'sin(p0*x[0])*exp(-0.5*pow((x[0]-x0),2))',degree=2, p0=p0, x0=x0)
u_n = Function(V)
u_n.assign(u_0)
p = Expression('x[0]*x[0]',degree=2)
a = (u[0]*v[0]+u[1]*v[1] + Dt/4.*(dot(grad(v[0]),grad(u[1])) - dot(grad(v[1]),grad(u[0]))) + Dt/4. *p*(u[1]*v[0]+u[0]*v[1]))*dx
As you have not encapsulated your code with ``` this might be an issue with formatting. However, to me this looks like you are trying to create a vector expression. However, your function space is a scalar space.
Similarly, this is an issue in your code when you define your variational form as well.
If you want to have a vector function, you need to create a VectorFunctionSpace.
i.e. replace:
with
V = VectorFunctionSpace(mesh, "CG", 2)
This will create a second order vector function space (with an x and y component).
Additionally you need to account for your vector space in the following definitions
Thanks, this works fine. Other problem was happened. In the last line on my code:
mesh = generate_mesh(Rectangle(Point(-5, -1), Point(5,1)), 64)
return on_boundary
bc = DirichletBC(V, Constant((0, 0)), boundary)
u_0 = Expression('cos(p0*x[0])*exp(-0.5*pow((x[0]-x0),2))', 'sin(p0*x[0])*exp(-0.5*pow((x[0]-x0),2))',degree=2, p0=p0, x0=x0, domain=mesh)
u_n = Function(V)
u_n.assign(u_0)
I received the message
*** Error: Unable to interpolate function into function space.
*** Reason: Rank of function (0) does not match rank of function space (1).
*** Where: This error was encountered inside FunctionSpace.cpp.
