Problem with xdmf.read_mesh
I am running a script to convert a .msh file to a .xdmf file, using the following part of the script:
if __name__ == "__main__":
    path_msh = Path("../meshes/patient9.msh")
    msh = meshio.read(path_msh)
    mesh_interior = create_mesh(msh, "tetra")
    mesh_facets = create_mesh(msh, "triangle")
    # store intermediate meshes in XDMF format
    path_tmp_tets = path_msh.with_name(path_msh.stem + "_tets.xdmf")
    path_tmp_tri = path_msh.with_name(path_msh.stem + "_tri.xdmf")
    meshio.write(path_tmp_tets, mesh_interior, file_format="xdmf")
    meshio.write(path_tmp_tri, mesh_facets, file_format="xdmf")
    # read back in with dolfinx to obtain the mesh in the correct format
    with io.XDMFFile(MPI.COMM_WORLD, path_tmp_tets, "r") as xdmf:
        print("test1")
        print("test2")
However, my script runs indefinitely en gets stuck at the mesh = xdmf.read_mesh(name=“Grid”) line: it prints test1 but not test2. do you have any idea why this happens?
Please add the output of the plaintext xdmf file in 3x` encapsulation, ie.
Output of xdmf
<Xdmf Version="3.0"><Domain><Grid Name="Grid"><Geometry GeometryType="XYZ"><DataItem DataType="Float" Dimensions="37093 3" Format="HDF" Precision="8">patient9cgs_tets.h5:/data0</DataItem></Geometry><Topology TopologyType="Tetrahedron" NumberOfElements="185097" NodesPerElement="4"><DataItem DataType="Int" Dimensions="185097 4" Format="HDF" Precision="4">patient9cgs_tets.h5:/data1</DataItem></Topology><Attribute Name="markers" AttributeType="Scalar" Center="Cell"><DataItem DataType="Int" Dimensions="185097" Format="HDF" Precision="4">patient9cgs_tets.h5:/data2</DataItem></Attribute></Grid></Domain></Xdmf>
To me this mesh looks perfectly valid (as xdmf).
Are you running this in serial or parallel?
Could you provide the msh file that you are using?
I am running it in serial. The msh file is a rather large file: with 200.000 elements and 3700 nodes, so i cannot post it here, unfortunately. maybe a small part is useful?:
$MeshFormat
2.2 0 8
$EndMeshFormat
$Nodes
37093
1 0.2698241770267487 -0.2756259739398956 -0.5569514036178589
2 0.2884699404239655 -0.2480147480964661 -0.5331186056137085
3 0.294191300868988 -0.2771624624729156 -0.5462889671325684
4 0.2622835636138916 -0.2926439344882965 -0.5369392037391663
5 0.2864086031913757 -0.2938072383403778 -0.5268594622612
6 0.3178472518920898 -0.2793562710285187 -0.5350016951560974
7 0.3099758923053741 -0.2957432270050049 -0.5159472823143005
8 0.2445784211158752 -0.2754203379154205 -0.5661513209342957
9 0.2649220824241638 -0.2454865276813507 -0.5443495512008667
A small part would not be useful, as I would have to try to reproduce your error message.
How is the mesh generated? Is is created with GMSH or is it just an intermediate format?
The mesh is created with GMSH. by importing as an stl file adding a volume as an physical entity, and the adding a volume mesh an exporting it as an msh file. I do now think of the fact that I exported it as a version 2 ASCII instead of the a version 4 ASCII, could that have anything to do with it?
what does dolfinx.io.gmshio.read_from_read_from_msh return?
for the following line:
mesh, cell_markers, facet_markers = gmshio.read_from_msh("../meshes/patient9cgs.msh", MPI.COMM_WORLD, gdim=3)
The following returned.
Info    : Reading '../meshes/patient9cgs.msh'...
Info    : 37093 nodes
Info    : 213865 elements
Info    : Done reading '../meshes/patient9cgs.msh'
  File "/home3/s3234266/nsx/examples/scripts/readmsh.py", line 4, in <module>
  File "/home3/s3234266/spack/var/spack/environments/fenicsx/.spack-env/view/lib/python3.10/site-packages/dolfinx/io/gmshio.py", line 311, in read_from_msh
    msh = model_to_mesh(gmsh.model, comm, rank, gdim=gdim, partitioner=partitioner)
  File "/home3/s3234266/spack/var/spack/environments/fenicsx/.spack-env/view/lib/python3.10/site-packages/dolfinx/io/gmshio.py", line 221, in model_to_mesh
    cell_id = cell_information[perm_sort[-1]]["id"]
IndexError: index -1 is out of bounds for axis 0 with size 0
So this error message means that you are not using phyiscal entity grouping in Gmsh, Which is adviced to avoid Getting duplicate nodes and cells in your mesh.
ok, thanks!
I managed to get rid of the indexerror above by adding a volume and a surface as a physical entity. However, when running the original code I still get the problem that it gets stuck at the mesh = xdmf.read_mesh(name=“Grid”) line…
I’ve provided the .msh file that I now use to run the code:
I cannot reproduce your error with the following code:
from pathlib import Path
import numpy
    out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    return out_mesh
path_msh = Path("patient9.msh")
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, path_tmp_tets, "r") as xdmf:
    print("test1")
    print("test2")
using docker
docker run -ti  -v $(pwd):/root/shared -w /root/shared --rm ghcr.io/fenics/dolfinx/dolfinx:nightly
 python3 -m pip install --no-binary=h5py h5py meshio
