Imposing reflective boundary conditions in the Linear Euler equations
Hello all,
I am trying to impose Reflective boundary conditions to the Linear Euler equations using reflective indices R_in and R_out at the inlet and outlet respectively. I am having an issue with currently defining this in the variational form as I don’t see any effect of changing R_out in the output pressure and velocity plots. I have attached my equations and the variational form that I am currently using. Please let me know your thoughts on how I can better implement the reflective indices in my boundary conditions. Thank you!
My boundary conditions are:
utflow = DirichletBC(P, 0.0, “x[0] > 1 - DOLFIN_EPS”)
p_in = Expression(“t < 1.0 ? 0.223.142sin(23.142*t) : 0”, t=0.0, degree=2)
inflow = DirichletBC(P, p_in, “x[0] < DOLFIN_EPS”)
bcp = [inflow, outflow]
My variational form is:
F1 = (inner((p_trial - p_old) / (dt * c * c), p_test) * dx + rho * u_old.dx(0) * p_test * dx
+ (c * (1 + R_in) / (1 - R_in) * p_trial) * p_test * ds(1)
+ (-c * (1 + R_out) / (1 - R_out) * p_trial) * p_test * ds(2))
F2 = inner(((u_trial - u_old) * rho) / dt, u_test) * dx + p_old.dx(0) * u_test * dx
Please read Read before posting: How do I get my question answered?
Without the actual code, there’s not much one can do. If I were to guess, I’d say that you forgot to assign the facet markers (1 and 2) when creating the ds measure.
Hi, thank you for your response. Here is my whole code. I have assigned the ds measure in this way. Please let me know if my approach is right.
EDITED BY FB
Please use “```” when writing code, otherwise the output is very difficult to read.
from matplotlib import cm
from tqdm import tqdm
plt.rcParams['figure.figsize'] = [14, 8]
plt.rcParams.update({'font.size': 24})
set_log_level(30)
n_elements = 100
mesh = UnitIntervalMesh(n_elements)
U = FunctionSpace(mesh, "Lagrange", 1)
P = FunctionSpace(mesh, "Lagrange", 1)
u_trial = TrialFunction(U)
p_trial = TrialFunction(P)
u_test = TestFunction(U)
p_test = TestFunction(P)
u_initial_condition = Expression("0", degree=1)
p_initial_condition = Expression("0", degree=1)
u_old = interpolate(u_initial_condition, U)
p_old = interpolate(p_initial_condition, P)
EndT = 3  # sec
delta_t = 0.0001
dt = Constant(delta_t)
c = Constant(1)
rho = Constant(1.2)
heat_source = Constant(0.0)
R_in = 0.0
R_out = 0.0
outflow = DirichletBC(P, 0.0, "x[0] > 1 - DOLFIN_EPS")
p_in = Expression("t < 1.0 ? 0.2*2*3.14*2*sin(2*3.14*2*t) : 0", t=0.0, degree=2)
inflow = DirichletBC(P, p_in, "x[0] < DOLFIN_EPS")
boundary_markers = MeshFunction("size_t", mesh, mesh.topology().dim() - 1, 0)
class InletBoundary(SubDomain):
        return near(x[0], 0.0, DOLFIN_EPS) and on_boundary
class OutletBoundary(SubDomain):
        return near(x[0], 1.0, DOLFIN_EPS) and on_boundary
inlet_boundary = InletBoundary()
inlet_boundary.mark(boundary_markers, 1)
outlet_boundary = OutletBoundary()
outlet_boundary.mark(boundary_markers, 2)
ds = Measure("ds", domain=mesh, subdomain_data=boundary_markers)
a1 = lhs(F1)
L1 = rhs(F1)
a2 = lhs(F2)
L2 = rhs(F2)
u_solution = Function(U)
p_solution = Function(P)
n_time_steps = int(np.ceil(EndT / delta_t))
u_plot = np.array(u_old.vector().get_local())
p_plot = np.array(p_old.vector().get_local())
x_coords = mesh.coordinates()[:, 0]
boundary_indices = np.where((x_coords < DOLFIN_EPS) | (x_coords > 1 - DOLFIN_EPS))[0]
gf_boundary_all = []
time_current = 0.0
for i in tqdm(range(n_time_steps)):
    time_current += delta_t
    p_in.t = time_current
    solve(a1 == L1, p_solution, bcp)
    solve(a2 == L2, u_solution)
    u_old.assign(u_solution)
    p_old.assign(p_solution)
    u_current = u_solution.vector().get_local()
    p_current = p_solution.vector().get_local()
    f = (p_current / (rho(0) * c(0))) + u_current
    g = (p_current / (rho(0) * c(0))) - u_current
    gf_boundary = np.zeros(len(boundary_indices))
    for idx, boundary_index in enumerate(boundary_indices):
        if abs(f[boundary_index]) > 1E-12:  # Avoid division by zero
            gf_boundary[idx] = abs(g[boundary_index] / f[boundary_index])
    gf_boundary_all.append(gf_boundary)
    u_plot = np.vstack((u_plot, u_current))
    p_plot = np.vstack((p_plot, p_current))
gf_boundary_all = np.array(gf_boundary_all)
plt.figure(1)
plt.contourf(u_plot[::100])
plt.colorbar().set_label('$v$ [-]', rotation=270, labelpad=40)
plt.savefig('./Velocity.png')
plt.figure(2)
plt.contourf(p_plot[::100])
plt.colorbar().set_label('$p$ [-]', rotation=270, labelpad=40)
plt.savefig('./Pressure.png')´´´´
Disclaimer: I have no experience with Euler equations.
Still, I think that there is something wrong with your formulation. You are imposing Dirichlet BCs on boundaries 1 and 2, and at the same time adding boundary integrals on those markers (like if they were Neumann BCs in an elliptic problem). The unknown is effectively assigned by the Dirichlet BC, hence it’s expected that you will not see any difference changing the problem definition (e.g., the coefficients).
Understood. But does my definition of the ds measure look alright to you?
Yes, the definition of the measure is correct.
Hello, thanks for your input! Unfortunately, removing the Dirichlet BC is giving rise to graphs with 0 pressure and velocity values for the entire range of R_in and R_out.
set_log_level(30)
n_elements = 100
# Define a Function Space
# The initial condition, u(t=0, x) = sin(pi * x)
p_initial_condition = Expression("sin(pi * x[0])", degree=1)
#p_initial_condition = Expression("0", degree=1)
# Discretize the initial condition
# The time stepping of the implicit Euler discretization (=dt)
EndT = 3  # sec
delta_t = 0.0001
c = Constant(1)
rho = Constant(1.2)
# The forcing on the rhs of the PDE
R_in = 0.5
R_out = 0.5
# Boundary Conditions
#outflow = DirichletBC(P, 0.0, "x[0] > 1 - DOLFIN_EPS")
# inflow = DirichletBC(P, 0.0, "x[0] < DOLFIN_EPS")
#inflow = DirichletBC(P, p_in, "x[0] < DOLFIN_EPS")
# bcp = [inflow]
#bcp = [inflow, outflow]
# Define outlet boundary
# Create a MeshFunction for marking boundaries
# Initialize and mark the outlet boundary with a unique ID, e.g., 1
# inlet_boundary = InletBoundary()
# inlet_boundary.mark(boundary_markers, 1)
# outlet_boundary = OutletBoundary()
# outlet_boundary.mark(boundary_markers, 2)
def boundary(x, on_boundary):
    return on_boundary
# Define a Measure for the marked outlet boundary
# Variational formulation
a1 = lhs(F1)
L1 = rhs(F1)
a2 = lhs(F2)
L2 = rhs(F2)
# Time stepping
#Boundary points
time_current = 0.0
    # Update pressure boundary condition
    solve(a1 == L1, p_solution)#, bcp)
    # Compute f and g for the current time step
plt.figure(1)
plt.savefig('./Velocity01.png')
plt.figure(2)
plt.savefig('./Pressure01.png')
Which is not surprising, considering that there is no forcing term. I’d suggest that you sort out the weak formulation first: I can’t help with that since I have no specific domain knowledge.
