Improve accuracy for Poisson equation with subdomains
Hello All,
Recently, I encounter an accuracy problem for the Poisson equation with subdomains. Here I use the question in this post (Solving PDEs in Python - <br> The FEniCS Tutorial Volume I) for test and explanation. the unit square is divided by two subdomains. and the top and bottom boundaries are biased at certain voltages by DirichletBC (top: 1V, bottom: 0V). the permittivity for upper and lower materials is 6 and 2, respectively. the Poisson equation is sourceless. Theoretically, the potential line at y=0.5 is constantly 0.75V.
I find that the result for potential at y=0.5 is sensitive to the way generating mesh. For example, if I use the built-in mesh “UnitSquareMesh(10,10)” to generate the mesh, the potential at y=0.5 is exactly 0.75.
x potential
0.4 0.75
0.5 0.75
0.6 0.75
However, if I use below code to generate mesh,
geometry=Rectangle(Point(0,0),Point(1,1))
mesh=generate_mesh(geometry,10,'cgal')
the result has significant difference to the exact result.
x potential
0.4 0.7299
0.5 0.7463
0.6 0.7379
I am noticed that in fenics, the accuracy for vertices in the mesh is 10^(−15), while the accuracy for non-vertex points is 10^(−2) since interpolation is used for non-vertex points. Thus I was trying to move the points in the mesh to the points that would be calculated.
# mesh
vtkfile=File('data_mesh_before.pvd')
vtkfile<<mesh
calc_x=np.linspace(0.4,0.6,3)
# moving points in mesh
tree=BoundingBoxTree()
tree.build(mesh)
cell_index=mesh.cells()
vertex_index=mesh.coordinates()
for x in calc_x:
    p_flake=Point(x,0.5)
    first=tree.compute_first_entity_collision(p_flake)
    vertex_index[cell_index[first][0]]=[p_flake.x(),p_flake.y()]
vtkfile=File('data_mesh_after.pvd')
vtkfile<<mesh
The mesh now can include the points to be calculated. But it still doesn’t work for the potential at y=0.5.
x potential
0.4 0.7267
0.5 0.7475
0.6 0.7477
I will extend this 2D problem to 3D thus I prefer to use something like “generate_mesh(geometry,10,‘cgal’)” to generate mesh. May I ask if anyone can shed some light on this issue? Thanks. Below I attach the code without moving points in mesh.
# mesh
#mesh=UnitSquareMesh(10,10)
vtkfile=File('data_mesh.pvd')
vtkfile<<mesh
tol=1E-14
# boundary conditions
def Gate1(x,on_boundary):
    return on_boundary and near(x[1],0,tol)
def Gate2(x,on_boundary):
    return on_boundary and near(x[1],1,tol)
class hBN(SubDomain):
        return between(x[1],(0.0-tol,0.5+tol))
class SiO2(SubDomain):
        return between(x[1],(0.5-tol,1.0+tol))
hbn=hBN()
sio2=SiO2()
# define subdomain markers and integration measure
markers=MeshFunction('size_t',mesh,mesh.topology().dim())
dx=Measure('dx',domain=mesh,subdomain_data=markers)
hbn.mark(markers,0)
sio2.mark(markers,1)
# define permittivity for different domains
class Permittivity(UserExpression):
    def __init__(self,markers,**kwargs):
        super().__init__(markers,**kwargs)
        self.markers=markers
    def eval_cell(self,values,x,cell):
        if self.markers[cell.index]==0:
            values[0]=2   # hBN
        elif self.markers[cell.index]==1:
            values[0]=6    # SiO2
    def value_shape(self):
        return ()
er=Permittivity(markers,degree=0)
# initial voltages for gate 1 and 3
V=FunctionSpace(mesh,'CG',1)
u=TrialFunction(V)
v=TestFunction(V)
aint=er*dot(grad(u),grad(v))*dx
Lint=Constant(0)*v*dx
bc1=DirichletBC(V,0,Gate1)
bc2=DirichletBC(V,1,Gate2)
bcs=[bc1,bc2]
A,b=assemble_system(aint,Lint,bcs)
u=Function(V)
solve(A,u.vector(),b)
vtkfile=File('potential.pvd')
vtkfile<<u
# calculate potential profiles
points=[(x_,0.5) for x_ in calc_x]
p_line=np.array([[point[0],u(point)] for point in points])
np.savetxt('data_p_line.txt',p_line)
When you split your domain into two subdomains, these domains should align with the boundary of the interface between them (i.e. The straight line y=0.5). When you use mshr to generate unstructured meshes, this will not be the case.
As mshr has been deprecated for a long time, i would strongly suggest you move to Gmsh, where you can use the fragment option to create subdomains, see
Hi @dokken, thanks for your information.
