Installing legacy fenics via anaconda - 10+ hours to resolve env
Hi everyone,
I am taking fenics up again after a break and would like to run some code I wrote way back in legacy fenics.
I’m following the install instructions:
1.
sudo apt-get install software-properties-common
sudo apt-get update
sudo apt-get install fenics
leads to install conflicts with ufl/ffc installed both system wide and locally and will fail to import certain elements such as VectorElement.
On the other hand
conda create -n fenicsproject -c conda-forge fenics
with a Python 3.8 install has been trying to resolve the environment for about 10 hours.
Any idea on how to proceed, especially with Anaconda ?
Regards,
M
On item 1.
