Can you please decode this to Fenicsx
kernel is defined
kernel = Expression('(i+j)*exp(-x[0]-x[1])', i = 0, j = 0)
Iv = interpolate(kernel, V)
Trying to write Fenicsx code from this
x_ks = V.tabulate_dof_coordinates()
m = V.dim()
d = mesh.geometry().dim()
mesh.geometry is not working in Fenicsx
x_ks.resize((m, d))
resize is not working in fenicsx
dokken
July 27, 2023, 6:09am
2
I am trying to write code in fenicsx for
\int_{\Omega} \int_{\Omega} q(x,y) u(x) v(y) dy dx
where u and v are the trial and test function, respectively. Could you please suggest something.
dokken
July 27, 2023, 9:57am
4
First I am trying this in 1D then go further
Yes, I have gone through that. I am trying it this way
kernel = fem.Function(V)
kernel.interpolate(lambda x: np.exp(-x[0]) )
u = ufl.TrialFunction(V)
k = fem.Function(V)
# k = (kernel*uD) * ufl.dx
k.interpolate(lambda x: ( kernel * uD ) * ufl.dx )
a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = f * v * ufl.dx + 0.5*(k * v)* ufl.dx
problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
dokken
July 27, 2023, 10:11am
6
Could you write out the mathematical formulation of this operation ?
Whenever you multiply by ufl.dx it implies that you should do an integral. It is then unclear what the input x should be used for here
u: [0, 1] → R, such that
u(x) - \int_{0}^{1}e^{-y}u(y)dy = f(x) in [0, 1]
Variational formulation
(u,v )- (\int_{0}^{1}e^{-y}u(y)dy,v) = (f,v)
I am just trying to write (\int_{0}^{1}e^{-y}u(y)dy,v) as inner product (e^{-y},u) and again inner product with u
dokken
July 27, 2023, 10:46am
8
This problem is highly non-linear, and has several non-local couplings (in the y direction, note that u is a function of both x and y), which does not naturally fall under ufl.
What you first need to do is to find a way to linearize the problem (a newton iteration or piccard iteration, i would probably use Piccard on the non-local interaction).
Then secondly, you would have to build up an operation for the lon-local interaction. I would probably make my own quadrature scheme in y direction, and use Implementation — FEniCSx tutorial to make the contributions in y direction.
Okay. Could you please tell me how to assemble a matrix
a0 = Function(V)
K = inner(Iu,Iv)*dx
a0.vector()[:] = assemble(K)
How to write this in fenicsx ?
dokken
July 27, 2023, 11:36am
10
You have not made an attempt by making a minimal reproducible example, so I don’t have tine to guess what you would like to do.
I just need tyo write this in fenicsx
