I was wondering if there is any way to perform a circular mean interpolation in Fenicsx, as the one shown in the screenshot?
My problem is expressed in terms of angular coordinates theta1
and theta2
, which are defined over the intervals -pi<=theta2<=pi
and 0<=theta1<=pi
. Arithmetical interpolations lead to unphysical results if the nodal angles theta2
are close to the upper/lower limits of the definition range.
Can you please point me to an example where a user-defined interpolation is performed?
Many thanks!
Could you be more specific in your question and perhaps provide a minimal working example of what you’ve tried so far? The concept of a circular mean is likely unfamiliar to the FEniCS crowd; however, if the concepts are straightforward in the context of a FEniCS implementation we could provide help.
Hi Natan,
thank you for your kind reply.
The variational form of my problem is expressed in terms of the unknown vector theta=(theta1,theta2)
The domain of each of those functions is -pi<=theta2<=pi
and -pi/2<=theta1<=pi/2
Referring to the equations in the screenshot above:
theta1^I
andeta1^I
respectively denote the values of the unknown and test function at the nodeI
theta1^h
andeta1^h
denote the corresponding interpolated values -
N^I
are the basis functions, for instance of Lagrange elements
In the following MWE, what I am doing under the hood is discretizing both theta1
and theta2
as:
theta1^h = sum_I (N_I theta1^I)
theta2^h = sum_I (N_I theta2^I)
(same for the corresponding test functions), while what I would like to do is expressing theta2
as a circular interpolation, as indicated in the screenshot above.
I am attaching a MWE, which I hope would allow me to clarify the problem.
Thank you for your help, I really appreciate all the work that you guys do.
import os
import sys
import petsc4py
from dolfinx import fem, mesh, la
petsc4py.init(sys.argv)
os.system('clear')
# Create MPI communicator
comm = MPI.COMM_WORLD
# ----- Create the mesh
L = 1.0
N = 10
domain = mesh.create_box(comm=comm, points=[[0.0, 0.0, 0.0], [L, L, L]],\
n=[N, N, N], cell_type=mesh.CellType.tetrahedron)
metadata = {'quadrature_degree' : 4}
dv = ufl.Measure("dx", domain=domain, metadata=metadata)
# Define the function space
V_theta = fem.VectorFunctionSpace(domain,("CG", 1), dim=2)
# Solution, Test, and Trial functions
theta = fem.Function(V_theta)
theta_test, theta_trial = ufl.TestFunction(V_theta), ufl.TrialFunction(V_theta)
def initialize(x):
d = x.shape[1]
angles = [np.zeros(d), np.zeros(d)]
# Create noise
np.random.seed(123)
noise = abs(np.random.normal(np.mean(np.ones(d)*0), 1/100, size = d))
angles = [np.ones(d)*0.+noise, np.ones(d)*0.+noise]
return angles
theta.interpolate(initialize)
class SNESProblem:
def __init__(self, F, u, bcs, J=None):
V = u.function_space
du = ufl.TrialFunction(V)
self.L = fem.form(F)
if J is None:
self.a = fem.form(ufl.derivative(F, u, du))
self.a = fem.form(J)
self.bcs = bcs
self._F, self._J = None, None
self.u = u
def F(self, snes, x, F):
"""Assemble residual vector."""
x.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
x.copy(self.u.vector)
self.u.vector.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
with F.localForm() as f_local:
f_local.set(0.0)
fem.petsc.assemble_vector(F, self.L)
fem.petsc.apply_lifting(F, [self.a], bcs=[self.bcs], x0=[x], scale=-1.0)
F.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
fem.petsc.set_bc(F, self.bcs, x, -1.0)
def J(self, snes, x, J, P):
"""Assemble Jacobian matrix."""
J.zeroEntries()
fem.petsc.assemble_matrix(J, self.a, bcs=self.bcs)
J.assemble()
# --- Define lower bound and upper bound for theta
theta_min = fem.Function(V_theta)
theta_max = fem.Function(V_theta)
def eval_theta_lowerbound(x):
d = x.shape[1]
return [-np.pi*np.ones(d), -np.pi/2*np.ones(d)]
def eval_theta_upperbound(x):
d = x.shape[1]
return [np.pi*np.ones(d), np.pi/2*np.ones(d)]
theta_min.interpolate(eval_theta_lowerbound)
theta_max.interpolate(eval_theta_upperbound)
# convert m to Cartesian coordinates
def m(theta):
return ufl.as_vector([ufl.cos(theta[0])*ufl.cos(theta[1]),
ufl.sin(theta[0])*ufl.cos(theta[1]),
ufl.sin(theta[1])])
# Exchange energy
W_ex = ufl.tr(ufl.grad(m(theta))*ufl.grad(m(theta)).T)
# Uniaxal anisotropy energy
anisotropy_axis = (1.0, 0.0, 0.0)
a_u = fem.Constant(domain,PETSc.ScalarType(anisotropy_axis))
W_ua = -ufl.dot(a_u, m(theta))**2
# Total energy
W = (W_ex + W_ua)*dv
W_residual_theta = ufl.derivative(W, theta, theta_test)
W_jacobian_theta = ufl.derivative(W_residual_theta, theta, theta_trial)
# --- Allocate the memory needed for TAO
dofs_domain, dofs_borders = V_theta.dofmap.index_map, V_theta.dofmap.index_map_bs
b = la.create_petsc_vector(dofs_domain, dofs_borders)
J = fem.petsc.create_matrix(fem.form(W_jacobian_theta))
# --- Create optimization problem
problem = SNESProblem(W_residual_theta, theta, [], J= W_jacobian_theta)
solver_snes = PETSc.SNES().create()
solver_snes.setType("vinewtonrsls")
solver_snes.setFunction(problem.F, b)
solver_snes.setJacobian(problem.J, J)
solver_snes.setTolerances(rtol=1.0e-9, max_it=50)
solver_snes.getKSP().setType("preonly")
solver_snes.getKSP().setTolerances(rtol=1.0e-9)
solver_snes.getKSP().getPC().setType("lu")
# We set the bound (Note: they are passed as reference and not as values)
solver_snes.setVariableBounds(theta_min.vector,theta_max.vector)
solver_snes.solve(None, theta.vector)
print("Done") (edited)
