Integrate a flux over an internal curve
I have a 2D geometry with an annulus shape and 2 internal curves, one at \theta=0, the other at \theta=\pi/2 (polar coordinates). I solve 2 coupled PDEs for the variables T and V (approximated as continuous Lagrange polynomials of degree 4). Then, after solving the FEM problem, I form \vec J in terms of T and V as \vec J = -\sigma \nabla V -\sigma S \nabla T where \sigma is a scalar that depends on the region:
R = functionspace(the_mesh.mesh, ("DG", 0))
sigma = Function(R)
sigma.x.array[three_quarters_cells] = np.full_like(three_quarters_cells, 1/(1e0), dtype=default_scalar_type)
sigma.x.array[quarter_cells] = np.full_like(quarter_cells, 1/1, dtype=default_scalar_type)
And S is a tensor (a diagonal 2x2 matrix) that also depends on the region:
        s_xx, s_yy = self.input_parameters.seebeck_components
        # Dokken's solution below
        tensor_el = element(family="DG", cell=str(the_mesh.mesh.ufl_cell()), degree=0, shape=(2, 2))
        T = functionspace(the_mesh.mesh, tensor_el)
        Seebeck_tensor = Function(T)
        def seebeck_three_quarters(x):
            tensor = np.array([[0, 0], [0, 0]])
            values = np.repeat(tensor, x.shape[1])
            #print(values.reshape(tensor.shape[0]*tensor.shape[1], x.shape[1]))
            return values.reshape(tensor.shape[0]*tensor.shape[1], x.shape[1])
        def seebeck_quarter(x):
            tensor = np.array([[s_xx, 0], [0, s_yy]])
        Seebeck_tensor.interpolate(seebeck_three_quarters, cells0=self.the_mesh.cell_markers.find(20))
        Seebeck_tensor.interpolate(seebeck_quarter, cells0=self.the_mesh.cell_markers.find(21))
        self.Seebeck_tensor = Seebeck_tensor
The usual
I_theta0 = assemble_scalar(form(dot(J_vector, n) * dS(22)))
print(f'I_theta0: {I_theta0}')
yields an error about restrictions whose traceback finishes by
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ufl/algorithms/apply_restrictions.py", line 61, in _require_restriction
    raise ValueError(f"Discontinuous type {o._ufl_class_.__name__} must be restricted.")
ValueError: Discontinuous type Coefficient must be restricted.
I tried several things, like using (‘+’), but nothing worked.
For example
    J_integrand_on_facet = (-sigma('+') * grad(volt)('+')
                                - sigma('+') * self.thermoelec_sim.Seebeck_tensor('+') * grad(temp)('+'))
        # Or, relying on UFL to correctly handle traces of gradients of CG functions:
        # J_integrand_on_facet = (-sigma('+') * grad(volt)
        #                         - sigma('+') * self.thermoelec_sim.Seebeck_tensor('+') * grad(temp))
        I_theta0 = assemble_scalar(form(dot(J_integrand_on_facet, n) * dS(22)))
yields
  File "/home/isaac/Documents/fenicsx/Bridgman/2d_bridgman_textbook_example/debug_quarter_annulus_renormalize_PF/full_annulus_Lukosz_v0dot9.py", line 338, in <module>
    post_proc.post_proc()
  File "/home/isaac/Documents/fenicsx/Bridgman/2d_bridgman_textbook_example/debug_quarter_annulus_renormalize_PF/full_annulus_Lukosz_v0dot9.py", line 322, in post_proc
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/fem/forms.py", line 337, in form
    return _create_form(form)
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/fem/forms.py", line 331, in _create_form
    return _form(form)
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/fem/forms.py", line 254, in _form
    ufcx_form, module, code = jit.ffcx_jit(
        mesh.comm, form, form_compiler_options=form_compiler_options, jit_options=jit_options
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/jit.py", line 62, in mpi_jit
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/jit.py", line 212, in ffcx_jit
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/codegeneration/jit.py", line 225, in compile_forms
    raise e
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/codegeneration/jit.py", line 205, in compile_forms
    impl = _compile_objects(
        decl,
    ...<9 lines>...
        visualise=visualise,
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/codegeneration/jit.py", line 330, in _compile_objects
    _, code_body = ffcx.compiler.compile_ufl_objects(
        ufl_objects, prefix=module_name, options=options, visualise=visualise
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/compiler.py", line 108, in compile_ufl_objects
    analysis = analyze_ufl_objects(ufl_objects, options["scalar_type"])  # type: ignore
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/analysis.py", line 94, in analyze_ufl_objects
    form_data = tuple(_analyze_form(form, scalar_type) for form in forms)
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/analysis.py", line 94, in <genexpr>
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/analysis.py", line 180, in _analyze_form
    form_data = ufl.algorithms.compute_form_data(
        form,
    ...<6 lines>...
        complex_mode=complex_mode,
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ufl/algorithms/compute_form_data.py", line 337, in compute_form_data
    form = apply_restrictions(form)
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ufl/algorithms/apply_restrictions.py", line 183, in apply_restrictions
    return map_integrand_dags(rules, expression, only_integral_type=integral_types)
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ufl/algorithms/map_integrands.py", line 86, in map_integrand_dags
    return map_integrands(
        lambda expr: map_expr_dag(function, expr, compress), form, only_integral_type
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ufl/algorithms/map_integrands.py", line 30, in map_integrands
    map_integrands(function, itg, only_integral_type) for itg in form.integrals()
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ufl/algorithms/map_integrands.py", line 39, in map_integrands
    return itg.reconstruct(function(itg.integrand()))
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ufl/algorithms/map_integrands.py", line 87, in <lambda>
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ufl/corealg/map_dag.py", line 35, in map_expr_dag
    (result,) = map_expr_dags(
        function, [expression], compress=compress, vcache=vcache, rcache=rcache
  File "/home/isaac/.conda/envs/fenicsx-env/lib/python3.13/site-packages/ufl/corealg/map_dag.py", line 101, in map_expr_dags
    r = handlers[v._ufl_typecode_](v)
ValueError: Discontinuous type Jacobian must be restricted.
Some more information, about the mesh, it comes from generating it from this file.geo:
// Gmsh project created on Sat Mar  8 22:37:56 2025
SetFactory("OpenCASCADE");
Mesh.CharacteristicLengthMax = 0.0009;
Mesh.CharacteristicLengthMin = 0.0001;
Disk(1) = {0, 0, 0, 0.05, 0.05};
Disk(2) = {0, 0, 0, 0.035, 0.035};
BooleanDifference{ Surface{1}; Delete;}{ Surface{2}; Delete;}
// Surface 3 is the full annulus. I need to split it into 2.
Point(4) = {0, 0.05, 0};
Point(5) = {0, 0.035, 0};
// Origin.
Point(6) = {0, 0, 0};
Line(4) = {2,3};
Line(5) = {4,5};
Circle(6) = {5, 6, 2};
Circle(7) = {4, 6, 3};
Curve Loop(8) = {5,6,4,7};
Plane Surface(9) = {8};
// 3-quarter surface
BooleanDifference{ Surface{1}; Delete;}{ Surface{9};}
BooleanFragments{ Surface{1}; Surface{9}; Delete; }{ }
Physical Surface("three_quarter_material", 20) = {1};
Physical Surface("quarter_material", 21) = {9};
Physical Curve("theta_0", 22) = {4};
Physical Curve("theta_pi_over_2", 23) = {5};
Physical Curve("r_inner_quarter", 24) = {6};
Physical Curve("r_outer_quarter", 25) = {7};
Physical Curve("r_inner_three_quarter", 26) = {8};
Physical Curve("r_outer_three_quarter", 27) = {9};
Maybe it is faulty but I don’t see it?
I read it with
class TheMesh:
    def __init__(self, mesh_file="meshes/quarter_annulus.msh") -> None:
        self.mesh, self.cell_markers, self.facet_markers = gmshio.read_from_msh(mesh_file, MPI.COMM_WORLD, gdim=2)
        self.x = SpatialCoordinate(self.mesh)
        self.dx = Measure("dx", domain=self.mesh, subdomain_data=self.cell_markers)
        self.ds = Measure("ds", domain=self.mesh, subdomain_data=self.facet_markers)
        self.dS = Measure("dS", domain=self.mesh, subdomain_data=self.facet_markers)
        self.n = FacetNormal(self.mesh)
My whole code is kind of gigantic, the MWE would be big too, since I have to recreate the tensor part, the mixed element part, etc.
I realize it’s very hard to offer guidance, but any idea is still welcome.
It doesn’t seem like you have restricted the FacetNormal (n) in either case
As you are working on an interior facet (dS) measure, the normal can go in either direction.
For one-sided integrals, see for instance
Thanks a lot dokken, that worked like a charm!
