Hardware/driver-dependent compilation error?
I recently installed FEniCSx 0.5.1 on a laptop and on a desktop computer, both on a new install of Ubuntu 22 LTS. My existing scripts run fine on the laptop, but for some reason running the exact same scripts on the desktop PC results in the following error:
INFO:root:/home/sebastiaan/miniforge3/envs/caddee/bin/x86_64-conda-linux-gnu-cc -Wno-unused-result -Wsign-compare -DNDEBUG -fwrapv -O2 -Wall -fPIC -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include -fPIC -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include -march -DNDEBUG -D_FORTIFY_SOURCE -fPIC -I/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/ffcx/codegeneration -I/home/sebastiaan/miniforge3/envs/caddee/include/python3.9 -c libffcx_forms_062cdda3b79c1137c54891d6fea1c8be87a7275e.c -o ./libffcx_forms_062cdda3b79c1137c54891d6fea1c8be87a7275e.o -O2 -g0
x86_64-conda-linux-gnu-cc: error: unrecognized command-line option '-march'
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/setuptools/_distutils/unixccompiler.py", line 185, in _compile
    self.spawn(compiler_so + cc_args + [src, '-o', obj] + extra_postargs)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/setuptools/_distutils/ccompiler.py", line 1041, in spawn
    spawn(cmd, dry_run=self.dry_run, **kwargs)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/setuptools/_distutils/spawn.py", line 70, in spawn
    raise DistutilsExecError(
distutils.errors.DistutilsExecError: command '/home/sebastiaan/miniforge3/envs/caddee/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/cffi/ffiplatform.py", line 48, in _build
    dist.run_command('build_ext')
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/setuptools/dist.py", line 963, in run_command
    super().run_command(command)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
    cmd_obj.run()
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/setuptools/command/build_ext.py", line 88, in run
    _build_ext.run(self)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/Cython/Distutils/old_build_ext.py", line 186, in run
    _build_ext.build_ext.run(self)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/setuptools/_distutils/command/build_ext.py", line 345, in run
    self.build_extensions()
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/Cython/Distutils/old_build_ext.py", line 195, in build_extensions
    _build_ext.build_ext.build_extensions(self)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/setuptools/_distutils/command/build_ext.py", line 467, in build_extensions
    self._build_extensions_serial()
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/setuptools/_distutils/command/build_ext.py", line 493, in _build_extensions_serial
    self.build_extension(ext)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/setuptools/command/build_ext.py", line 249, in build_extension
    _build_ext.build_extension(self, ext)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/setuptools/_distutils/command/build_ext.py", line 548, in build_extension
    objects = self.compiler.compile(
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/setuptools/_distutils/ccompiler.py", line 600, in compile
    self._compile(obj, src, ext, cc_args, extra_postargs, pp_opts)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/setuptools/_distutils/unixccompiler.py", line 187, in _compile
    raise CompileError(msg)
distutils.errors.CompileError: command '/home/sebastiaan/miniforge3/envs/caddee/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
  File "/home/sebastiaan/Repositories/femo/examples/test_shell_m3l/run_pav_shell_2WayCoupling.py", line 249, in <module>
    fenics_invariantmatrix_petsc_component = assemble_matrix(form(inner(fenics_force_function_component, fenics_disp_function_component)*dx))
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/dolfinx/fem/forms.py", line 166, in form
    return _create_form(form)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/dolfinx/fem/forms.py", line 161, in _create_form
    return _form(form)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/dolfinx/fem/forms.py", line 135, in _form
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/dolfinx/jit.py", line 56, in mpi_jit
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/dolfinx/jit.py", line 204, in ffcx_jit
    r = ffcx.codegeneration.jit.compile_forms([ufl_object], parameters=p_ffcx, **p_jit)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/ffcx/codegeneration/jit.py", line 168, in compile_forms
    impl = _compile_objects(decl, forms, form_names, module_name, p, cache_dir,
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/ffcx/codegeneration/jit.py", line 252, in _compile_objects
    ffibuilder.compile(tmpdir=cache_dir, verbose=True, debug=cffi_debug)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/cffi/api.py", line 725, in compile
    return recompile(self, module_name, source, tmpdir=tmpdir,
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/cffi/recompiler.py", line 1564, in recompile
    outputfilename = ffiplatform.compile('.', ext,
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/cffi/ffiplatform.py", line 20, in compile
    outputfilename = _build(tmpdir, ext, compiler_verbose, debug)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/cffi/ffiplatform.py", line 54, in _build
    raise VerificationError('%s: %s' % (e.__class__.__name__, e))
cffi.VerificationError: CompileError: command '/home/sebastiaan/miniforge3/envs/caddee/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
I’ve encountered this in multiple scripts. Running the same scripts in debug mode in Visual Studio Code works fine for some reason.
Dolfinx was installed through mamba/conda on both computers, but the fact that this issue only occurs on my desktop computer makes me think that this is a hardware- or driver-dependent problem. @jkrokowski reported the same issue in this thread late last year with Dolfin 0.6.0. We’re both running Ubuntu 22 LTS on Dell Optiplex 7090 computers. I’m running version 10.4.0 of gcc_linux-64 and gxx_linux-64 whereas @jkrokowski runs version 12.3.0 of both.
This thread seems to contain the same issue, but no solution was found. Some coworkers that run Dolfinx on the same hardware reported no similar issues, but they were running Ubuntu 20 instead. I’m not sure what the issue could be, so I’m posting this in hopes that other people have encountered this as well and found a solution, or at the very least could help me out with finding a solution.
My first recommendation is to try to upgrade to a newer version of DOLFINx.
If this is not an option, could you:
  1. Provide an example that is failing.
  2. Try to run python3 -m ffcx poisson.py for the file at: dolfinx/cpp/demo/poisson/poisson.py at v0.5.2 · FEniCS/dolfinx · GitHub
    and then provide the full trace?
Agreed, sadly that’s not an option at the moment due to downstream dependencies.
This simple script already returns the aforementioned error for me. Here is the full console output:
INFO:root:running build_ext
INFO:root:building 'libffcx_elements_b886a906bcb7e11248de61964a699533d3720400' extension
INFO:root:/home/sebastiaan/miniforge3/envs/caddee/bin/x86_64-conda-linux-gnu-cc -Wno-unused-result -Wsign-compare -DNDEBUG -fwrapv -O2 -Wall -fPIC -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include -fPIC -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include -march -DNDEBUG -D_FORTIFY_SOURCE -fPIC -I/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/ffcx/codegeneration -I/home/sebastiaan/miniforge3/envs/caddee/include/python3.9 -c libffcx_elements_b886a906bcb7e11248de61964a699533d3720400.c -o ./libffcx_elements_b886a906bcb7e11248de61964a699533d3720400.o -O2 -g0
    cmd_obj.run()
  File "/home/sebastiaan/Repositories/dolfinx_test.py", line 90, in <module>
    V = fem.FunctionSpace(msh, ("Lagrange", 1))
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/dolfinx/fem/function.py", line 457, in __init__
    (self._ufcx_element, self._ufcx_dofmap), module, code = jit.ffcx_jit(
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/dolfinx/jit.py", line 206, in ffcx_jit
    r = ffcx.codegeneration.jit.compile_elements([ufl_object], parameters=p_ffcx, **p_jit)
  File "/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/ffcx/codegeneration/jit.py", line 126, in compile_elements
    impl = _compile_objects(decl, elements, names, module_name, p, cache_dir,
More specifically, it throws this error as soon as V = fem.FunctionSpace(msh, ("Lagrange", 1)) is called in line 90.
Then, for point two: Running python3 -m ffcx poisson.py for the v0.5.1 version of the file you linked doesn’t return any console output. Running it for the same basic Poisson example that resulted in an error above gives the following console output:
INFO:root:/home/sebastiaan/miniforge3/envs/caddee/bin/x86_64-conda-linux-gnu-cc -Wno-unused-result -Wsign-compare -DNDEBUG -fwrapv -O2 -Wall -fPIC -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include -fPIC -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/sebastiaan/miniforge3/envs/caddee/include -DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include -fPIC -I/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/ffcx/codegeneration -I/home/sebastiaan/miniforge3/envs/caddee/include/python3.9 -c libffcx_elements_b886a906bcb7e11248de61964a699533d3720400.c -o ./libffcx_elements_b886a906bcb7e11248de61964a699533d3720400.o -O2 -g0
INFO:root:/home/sebastiaan/miniforge3/envs/caddee/bin/x86_64-conda-linux-gnu-cc -shared -Wl,-rpath,/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-rpath-link,/home/sebastiaan/miniforge3/envs/caddee/lib -L/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-rpath,/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-rpath-link,/home/sebastiaan/miniforge3/envs/caddee/lib -L/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-O2 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,--disable-new-dtags -Wl,--gc-sections -Wl,--allow-shlib-undefined -Wl,-rpath,/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-rpath-link,/home/sebastiaan/miniforge3/envs/caddee/lib -L/home/sebastiaan/miniforge3/envs/caddee/lib -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/sebastiaan/miniforge3/envs/caddee/include -DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include ./libffcx_elements_b886a906bcb7e11248de61964a699533d3720400.o -o ./libffcx_elements_b886a906bcb7e11248de61964a699533d3720400.cpython-39-x86_64-linux-gnu.so
INFO:root:building 'libffcx_forms_b08ee883e09c7c0128f5016368e5b33727f64c00' extension
INFO:root:/home/sebastiaan/miniforge3/envs/caddee/bin/x86_64-conda-linux-gnu-cc -Wno-unused-result -Wsign-compare -DNDEBUG -fwrapv -O2 -Wall -fPIC -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include -fPIC -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/sebastiaan/miniforge3/envs/caddee/include -DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include -fPIC -I/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/ffcx/codegeneration -I/home/sebastiaan/miniforge3/envs/caddee/include/python3.9 -c libffcx_forms_b08ee883e09c7c0128f5016368e5b33727f64c00.c -o ./libffcx_forms_b08ee883e09c7c0128f5016368e5b33727f64c00.o -O2 -g0
INFO:root:/home/sebastiaan/miniforge3/envs/caddee/bin/x86_64-conda-linux-gnu-cc -shared -Wl,-rpath,/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-rpath-link,/home/sebastiaan/miniforge3/envs/caddee/lib -L/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-rpath,/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-rpath-link,/home/sebastiaan/miniforge3/envs/caddee/lib -L/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-O2 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,--disable-new-dtags -Wl,--gc-sections -Wl,--allow-shlib-undefined -Wl,-rpath,/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-rpath-link,/home/sebastiaan/miniforge3/envs/caddee/lib -L/home/sebastiaan/miniforge3/envs/caddee/lib -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/sebastiaan/miniforge3/envs/caddee/include -DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include ./libffcx_forms_b08ee883e09c7c0128f5016368e5b33727f64c00.o -o ./libffcx_forms_b08ee883e09c7c0128f5016368e5b33727f64c00.cpython-39-x86_64-linux-gnu.so
INFO:root:building 'libffcx_forms_f9c78865bee25ac465bdcbdb240645f484b08952' extension
INFO:root:/home/sebastiaan/miniforge3/envs/caddee/bin/x86_64-conda-linux-gnu-cc -Wno-unused-result -Wsign-compare -DNDEBUG -fwrapv -O2 -Wall -fPIC -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include -fPIC -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/sebastiaan/miniforge3/envs/caddee/include -DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include -fPIC -I/home/sebastiaan/miniforge3/envs/caddee/lib/python3.9/site-packages/ffcx/codegeneration -I/home/sebastiaan/miniforge3/envs/caddee/include/python3.9 -c libffcx_forms_f9c78865bee25ac465bdcbdb240645f484b08952.c -o ./libffcx_forms_f9c78865bee25ac465bdcbdb240645f484b08952.o -O2 -g0
INFO:root:/home/sebastiaan/miniforge3/envs/caddee/bin/x86_64-conda-linux-gnu-cc -shared -Wl,-rpath,/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-rpath-link,/home/sebastiaan/miniforge3/envs/caddee/lib -L/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-rpath,/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-rpath-link,/home/sebastiaan/miniforge3/envs/caddee/lib -L/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-O2 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,--disable-new-dtags -Wl,--gc-sections -Wl,--allow-shlib-undefined -Wl,-rpath,/home/sebastiaan/miniforge3/envs/caddee/lib -Wl,-rpath-link,/home/sebastiaan/miniforge3/envs/caddee/lib -L/home/sebastiaan/miniforge3/envs/caddee/lib -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/sebastiaan/miniforge3/envs/caddee/include -DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /home/sebastiaan/miniforge3/envs/caddee/include ./libffcx_forms_f9c78865bee25ac465bdcbdb240645f484b08952.o -o ./libffcx_forms_f9c78865bee25ac465bdcbdb240645f484b08952.cpython-39-x86_64-linux-gnu.so
Without any errors being displayed. If I then go back to VS Code to re-run the same script it runs without problems, so I’d assume the issue is specific to form compilation (since running a script with pre-compiled forms doesn’t raise any errors).
