You typically want to search the forum before asking a question. Interpolating a function defined from an array is quite a common question, even though probably the case of a vector field is less common.
The very first search result I found is How to interpolate numpy array into VectorFunctionSpace? : it boils down to creating a LinearNDInterpolator
from scipy
. I won’t be searching further results for you.
Furthermore, taking the risk of sounding rude, I won’t be reading your code either. That is far from a minimal example: we don’t need to see your linear elasticity problem, which even uses dolfinx_mpc
, for your to formulate the question “how can I interpolate a 2D field defined in numpy to a dolfinx Function”? Just take a built in mesh, prepare mock numpy data, and then ask how to interpolate those in a dolfinx Function.
