Interpolation on different grids
Hi,guys!As the title suggests.I want interpolate on different grids.
As code shows:I want to interpolate the function u1 on a coarse grid to the function u2 on a fine grid.
from dolfinx import default_real_type, fem, io, mesh,default_scalar_type
from dolfinx.fem.petsc import assemble_matrix, assemble_vector
from ufl import (CellDiameter, FacetNormal, TestFunction, TrialFunction, avg,
                 conditional, div, dot, dS, ds, dx, grad, gt, inner, outer,
                  TrialFunctions,TestFunctions,curl,cross)
from dolfinx.io import gmshio,XDMFFile
from basix.ufl import element,mixed_element
                                 create_vector, set_bc,create_matrix)
import time
import os
from dolfinx.cpp.mesh import CellType
def initial(x):
    values = np.zeros((2, x.shape[1]), dtype=PETSc.ScalarType)
    values[0]=x[0]
    values[1]=x[1]
    return values
n1=5
n2=10
msh1 =mesh.create_unit_square(MPI.COMM_WORLD, n1, n1,cell_type=CellType.triangle)  #triangle  quadrilateral
msh2 =mesh.create_unit_square(MPI.COMM_WORLD, n2, n2,cell_type=CellType.triangle)  #triangle  quadrilateral
U1_element=element("DG", msh1.basix_cell(),1, shape=(msh1.geometry.dim,))
U2_element=element("DG", msh2.basix_cell(),1, shape=(msh1.geometry.dim,))
V1=fem.functionspace(msh1,U1_element)
V2=fem.functionspace(msh2,U2_element)
u1=fem.Function(V1)
u2=fem.Function(V2)
u1.interpolate(initial)
print(u1.x.array)
u2.interpolate(u1)
Thanks!!!
The api Depends on what version of DOLFINx you are using. See:
dolfinx/python/test/unit/fem/test_interpolation.py at 7bb01adaa736a325ca048e37aec0b51cf9ff1f2e · FEniCS/dolfinx · GitHub For syntax for main branch, or
dolfinx/python/test/unit/fem/test_interpolation.py at v0.8.0 · FEniCS/dolfinx · GitHub
for 0.8.0 syntax (Which has a few bugs Fixed on main branch when it comes to parallel computing)
Thanks dokken!Are you saying that when the version of dolfinx is less than 0.8, there will be some bug when parallel computing?
No, on version 0.8 there is a bug that has been fixed on main, that resulted in a change in the API of interpolate for non-matching meshes.
If you are on version 0.7 or on the main branch it works fine.
