Interpolation matrix with non matching meshes
The interpolation matrix function for nonmatching meshes is done!
Works on dolfinx v0.6.0
Works only for lagrange element
from dolfinx import geometry
import basix
def interpolation_matrix_nonmatching_meshes(V_1,V_0): # Function spaces from nonmatching meshes
    msh_0 = V_0.mesh
    msh_1 = V_1.mesh
    x_0   = V_0.tabulate_dof_coordinates()
    x_1   = V_1.tabulate_dof_coordinates()
    bb_tree         = geometry.BoundingBoxTree(msh_0, msh_0.topology.dim)
    cell_candidates = geometry.compute_collisions(bb_tree, x_1)
    cells           = []
    points_on_proc  = []
    index_points    = []
    colliding_cells = geometry.compute_colliding_cells(msh_0, cell_candidates, x_1)
    for i, point in enumerate(x_1):
        if len(colliding_cells.links(i))>0:
            points_on_proc.append(point)
            cells.append(colliding_cells.links(i)[0])
            index_points.append(i)
    index_points_   = np.array(index_points)
    points_on_proc_ = np.array(points_on_proc, dtype=np.float64)
    cells_          = np.array(cells)
    ct      = dolfinx.cpp.mesh.to_string(msh_0.topology.cell_type)
    element = basix.create_element(basix.finite_element.string_to_family(
        "Lagrange", ct), basix.cell.string_to_type(ct), V_0.ufl_element().degree(), basix.LagrangeVariant.equispaced)
    x_ref = np.zeros((len(cells_), 3))
    for i in range(0, len(cells_)):
        geom_dofs  = msh_0.geometry.dofmap.links(cells_[i])
        x_ref[i,:] = msh_0.geometry.cmap.pull_back([points_on_proc_[i,:]], msh_0.geometry.x[geom_dofs])
    basis_matrix = element.tabulate(0, x_ref)[0,:,:,0]
    cell_dofs         = np.zeros((len(x_1), len(basis_matrix[0,:])))
    basis_matrix_full = np.zeros((len(x_1), len(basis_matrix[0,:])))
    for nn in range(0,len(cells_)):
        cell_dofs[index_points_[nn],:] = V_0.dofmap.cell_dofs(cells_[nn])
        basis_matrix_full[index_points_[nn],:] = basis_matrix[nn,:]
    cell_dofs_ = cell_dofs.astype(int) ###### REDUCE HERE
    I = np.zeros((len(x_1), len(x_0)), dtype=complex)
    for i in range(0,len(x_1)):
        for j in range(0,len(basis_matrix[0,:])):
            I[i,cell_dofs_[i,j]] = basis_matrix_full[i,j]
    return I
You can find it also here:
