Invalid syntax importing GMSH to FEniCS
Hello.
I’m new at GMSH and FEniCS and I’m trying to import the mesh from GMSH to FEniCS. I am using the fallowing code lines to try to do that:
gmsh -2 filename.geo
dolfin-convert filename.msh filename.xml
mesh = Mesh("filename.xml")
But I always get the error:
SyntaxError: invalid syntax
The filename.geo and code.py files are in the same directory. I am using WSL and dolfin 2019.2.0.dev0.
Thanks,
Matheus Seidel.
To me it seems like you are trying to call gmsh -2 filename.geo as part of your python script.
To do so, you need to use os.system for such behavior, i.e.
import os
os.system("gmsh -2 filename.geo")
os.system("dolfin-convert filename.msh filename.xml")
Thanks.
Now I’m getting:
Info    : Running 'gmsh -2 filename.geo' [Gmsh 4.4.1, 1 node, max. 1 thread]
Info    : Started on Thu Oct 21 15:18:03 2021
Info    : Reading 'filename.geo'...
Info    : Done reading 'filename.geo'
Info    : Meshing 1D...
Info    : Meshing curve 1 (Line)
Info    : Meshing curve 2 (Line)
Info    : Meshing curve 3 (Line)
Info    : Meshing curve 4 (Line)
Info    : Done meshing 1D (0.0024824 s)
Info    : Meshing 2D...
Info    : Meshing surface 1 (transfinite)
Info    : Done meshing 2D (0.000872 s)
Info    : 121 vertices 244 elements
Info    : Writing 'filename.msh'...
Info    : Done writing 'filename.msh'
Info    : Stopped on Thu Oct 21 15:18:03 2021
Converting from Gmsh format (.msh, .gmsh) to DOLFIN XML format mbseidel@DESKTOP-NPRJ0E1:/mnt/c/users/matheus seidel/documents$
  File "/usr/bin/dolfin-convert", line 132, in <module>
    main(sys.argv[1:])
  File "/usr/bin/dolfin-convert", line 79, in main
    meshconvert.convert2xml(ifilename, ofilename, iformat=iformat)
  File "/usr/lib/python3/dist-packages/dolfin_utils/meshconvert/meshconvert.py", line 1301, in     convert2xml
    convert(ifilename, XmlHandler(ofilename), iformat=iformat)
  File "/usr/lib/python3/dist-packages/dolfin_utils/meshconvert/meshconvert.py", line 1322, in convert
    gmsh2xml(ifilename, handler)
  File "/usr/lib/python3/dist-packages/dolfin_utils/meshconvert/meshconvert.py", line 271, in     gmsh2xml
num_elements = int(line)
ValueError: invalid literal for int() with base 10: '9 244 1 244\n' Traceback (most recent call last):
File "NS_test.py", line 17, in <module>
RuntimeError:
*** Error:   Unable to read data from XML file.
*** Reason:  Not a DOLFIN XML file.
*** Where:   This error was encountered inside XMLFile.cpp.
*** Process: 0
*** Git changeset:  unknown
The code is as fallows:
from future import print_function
import os
Mesh and function space definition
#dolfin-convert filename.msh filename.xml
mesh = Mesh(“filename.xml”)
os.system(“gmsh -2 filename.geo”)
os.system(“dolfin-convert filename.msh filename.xml”)
V = FunctionSpace(mesh, ‘Lagrange’, 1)
Trial and test functions in the same space (BC defined separately)
Boundary condition
u_D = Expression(‘x[1] <= 0 + DOLFIN_EPS ? 0 : x[0] <= 0 + DOLFIN_EPS && x[1] <= 0.2 + DOLFIN_EPS ? 0 : 1’, degree=1)
def boundary(x):
return x[0] <= 0 + DOLFIN_EPS or x[1] <= 0 + DOLFIN_EPS
Define variational problem
vel = as_vector([0.707, 0.707])
f = Constant(0)
G = (vdot(vel, grad(u)) + dot(grad((0.000001u)), grad(v)))dx - fv*dx
R = dot(vel, grad(u)) - 0.000001*div(grad(u)) - f
modvel = 1
h = 0.1
tal = h/(2*modvel)
G += (dot(vel, grad(v)))talR*dx
a = lhs(G)
L = rhs(G)
Compute solution
solve(a == L, u, bc)
Plot solution and mesh
plot(u)
plot(mesh)
Save solution to file in VTK format
vtkfile = File(‘NS_test/solution.pvd’)
vtkfile << u
Hold plot
In general you should not use dolfin-convert to convert your meshes, and should rather use meshio as described here: Transitioning from mesh.xml to mesh.xdmf, from dolfin-convert to meshio - #181 by rkailash
