Transitioning from mesh.xml to mesh.xdmf, from dolfin-convert to meshio
Thank you. This works perfectly.
If anyone is interested in adapting this for a 2D mesh, only minor modifications are necessary, and the code snippet is as follows:
import gmsh
import pygmsh
import numpy
msh = meshio.read("mesh2d.msh")
    out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    if prune_z:
        out_mesh.prune_z_0()
    return out_mesh
line_mesh = create_mesh(msh, "line", prune_z=True)
meshio.write("mf.xdmf", line_mesh)
triangle_mesh = create_mesh(msh, "triangle", prune_z=True)
meshio.write("mesh.xdmf", triangle_mesh)
with XDMFFile("mesh.xdmf") as infile:
    infile.read(mesh)
mvc = MeshValueCollection("size_t", mesh, 1)
with XDMFFile("mf.xdmf") as infile:
mf = cpp.mesh.MeshFunctionSizet(mesh, mvc)
File("dolfinmesh.pvd").write(mesh)
File("dolfincellfunc.pvd").write(mf)
