Projection of mixed elements over functionspace : jit error
Hi, I have been trying to project a vector of 20 numbers over a functionspace. it works till 2nd time steps but at 3rd time steps the following error is happening.
*Error: Unable to perform just-in-time compilation of form.
***** Reason: ffc.jit failed with message:
I have been trying to run following code:
import sys, pdb
sys.setrecursionlimit(100000)
import os as os
#import numpy as np
from math import *
import vtk
from mpi4py import MPI as pyMPI
from matplotlib import pylab as plt
deg = 4
flags = ["-O3", "-ffast-math", "-march=native"]
parameters["form_compiler"]["representation"]="uflacs"
parameters["form_compiler"]["quadrature_degree"]=deg
print(parameters.linear_algebra_backend)
le = 1.0  #length
wd = 1.0  #width
ht = 0.1  #height
#Mesh create
mesh = BoxMesh( Point(0.0, 0.0, 0.0),Point( le, wd, ht),4,4,2)
print "Plotting a BoxMesh"
File ("test/slabmesh"+".pvd") << mesh
print mesh.num_cells()
print mesh.num_vertices()
comm = mesh.mpi_comm()
class Top(SubDomain):
        return near(x[2], ht) and on_boundary
class Bottom(SubDomain):
        return near(x[2], 0) and on_boundary
class Left(SubDomain):
        return near(x[0], 0) and on_boundary
class Right(SubDomain):
        return near(x[0], le) and on_boundary
class Front(SubDomain):
        return near(x[1], wd) and on_boundary
class Back(SubDomain):
        return near(x[1], 0) and on_boundary
#Faceboundaries
facetboundaries = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
facetboundaries.set_all(0)
left = Left()
left.mark(facetboundaries, 1) # Mark left id as 1
right = Right()
right.mark(facetboundaries, 2) # Mark right id as 2
back = Back()
back.mark(facetboundaries, 4) # Mark back id as 4
dx = dolfin.dx(mesh)
ds = dolfin.ds(mesh)
#VectorFunctionSpace for fiber vector
VFS = VectorFunctionSpace(mesh, 'CG', 2)
FS = FunctionSpace(mesh, 'CG', 1)
TFS = TensorFunctionSpace(mesh, "CG", 1) #, shape=(3,3))
Telem = TensorElement('CG', mesh.ufl_cell(), 2, quad_scheme="default")
Telem._quad_scheme = 'default'
Velem = VectorElement('CG', mesh.ufl_cell(), 1, quad_scheme="default")
Velem._quad_scheme = 'default'
Qelem = FiniteElement('DG', mesh.ufl_cell(), 1, quad_scheme="default")
Qelem._quad_scheme = 'default'
Relem = FiniteElement("Real", mesh.ufl_cell(), 0, quad_scheme="default")
Relem._quad_scheme = 'default'
VRelem = MixedElement([Relem, Relem, Relem, Relem, Relem, Relem])
W = FunctionSpace(mesh, MixedElement([Velem,VRelem]))
w = Function(W)
dw = TrialFunction(W)
wtest = TestFunction(W)
du,dc = TrialFunctions(W)
(u, c) = split(w)
(v, cq) = TestFunctions(W)
tTot = 100
T1st = tTot /2
value = 0.0
## Boundary condition declaration
ux = Expression(("m0"), m0 = value, degree = 0)
cl = Expression(("0.0", "0.0", "0.0"), degree = 0)
#bcleft = DirichletBC(W, cl, facetboundaries, 1)
bcback = DirichletBC(W.sub(0).sub(1), Expression(("0.0"), degree = 0), facetboundaries, 4)
bcleft = DirichletBC(W.sub(0).sub(0),  Expression(("0.0"), degree = 0), facetboundaries, 1)
bcright = DirichletBC(W.sub(0).sub(0), ux, facetboundaries, 2)
bcs = [bcleft, bcback, bcright]
#COntinuum formulation
N = FacetNormal(mesh )
d = u.ufl_domain().geometric_dimension()
I = Identity(d)
F = I + grad(u)
#print F
C = F.T*F
J = det(F)
n0 = J*inv(F.T)*N
E = (F.T*F - I)*0.5
Ufile = File("test/Utensor.pvd")
Enh = 1.0E6 #Pa
nu = 0.19
sigmaMax = 2.0E5
k = Enh/(3*(1-2*nu))
G = Enh/(2*(1+nu))
sigmaNH = k*ln(J)*I/J + G*(F*F.T - I*J**2/3)/J
#FIber formulation
n = 20
k0 = 1.5e-06
k1 = 7.0e-07
kd = 1.0e-03
Qelem_array = MixedElement([Qelem]*n)
Velem_array = MixedElement([Velem]*n)
#Telem_array = MixedElement([Telem]*n)
WQ = FunctionSpace(mesh, Qelem_array)
wq = FunctionSpace(mesh, Qelem)
WV = FunctionSpace(mesh, Velem_array)
#WT = FunctionSpace(mesh, Telem_array)
Wphim = FunctionSpace(mesh, Qelem)
Q = Function(WQ)
Q.rename("fibervol","fibervol")
V = Function(WV)
Qm = Function(wq)
Qm.vector().array()[:] = 0.05
Q.vector().array()[:] = 0.0
thetain = -pi/2
thetafin = pi/2 -pi/n
dtheta = pi/n
K = 0.0
E0 = 0.12
THETA = []
for i in range(0,n):
	THETA.append(thetain)
	thetain = thetain + dtheta
knu = 5.0E01
sigmax = 2.0E05
phitotal = 0.05
zer = Constant((0.0))
phi = as_vector([(zer*k) for k in range (0,n)])
phivt = phi[0]
for k in range (0,n-1):
	phivt = phivt + phi[k+1]
phim =(phitotal -(phivt/n))
Vcell = as_vector([[cos(THETA[k]), sin(THETA[k]), 0.0] for k in range(0,n)])
Vnew = as_vector([(F*Vcell[k]) for k in range(0,n)])
lamda = as_vector([(dolfin.sqrt(inner(C*Vcell[k],Vcell[k]))) for k in range(0,n)])
strain = as_vector([((lamda[k]**2 - 1)*0.5) for k in range (0,n)])
strainOld = strain
straindot = (strain - strainOld)/1.0
fact = as_vector([(dolfin.exp((strain[k]/0.12)**2)) for k in range(0,n)])
fpas = as_vector([(conditional(ge(0.0, strain[k]), (strain[k]/0.1)**2, 0.0)) for k in range (0,n)])
fe = fact + fpas
fedot = as_vector([((knu*straindot[k] +2.0)/dolfin.sqrt((knu*straindot[k] + 2.0)**2 +1.0))/ (1+ 2/dolfin.sqrt(5.0)) for k in range (0,n)])
sigmatheta = as_vector([(sigmax*fe[k]*fedot[k]) for k in range(0,n)])
MCell =as_tensor([(outer(Vnew[k], Vnew[k])) for k in range(0,n)])
sigmacell = [(phi[k]*sigmatheta[k]*MCell[k]) for k in range(0,n)]
SigmaX = sigmacell[0]
	SigmaX = SigmaX + sigmacell[k+1]
SigmaCell = as_tensor(SigmaX)
cauchy = sigmaNH +  SigmaCell/n
piola = J*cauchy*inv(F.T)
F1 = - inner(grad(v),piola)*dx
X = SpatialCoordinate(mesh)
Wrigid = inner(as_vector([c[0], c[1], c[2]]), u) + \
	 inner(as_vector([0.0, 0.0, c[3]]), cross(X, u)) + \
	 inner(as_vector([c[4], 0.0, 0.0]), cross(X, u)) + \
	 inner(as_vector([0.0, c[5], 0.0]), cross(X, u))
F2 = derivative(Wrigid, w, wtest)*dx
Ftotal = F1 + F2
Jac1 = derivative(F1, w, dw)
Jac2 = derivative(F2, w, dw)
Jac = Jac1 +Jac2
problem = NonlinearVariationalProblem(Ftotal, w, bcs, Jac)
prm = solver.parameters
prm['newton_solver']['absolute_tolerance'] = 1E-7
prm['newton_solver']['relative_tolerance'] = 1E-6
prm['newton_solver']['maximum_iterations'] = 40
prm['newton_solver']['relaxation_parameter'] = 1.0
prm['newton_solver']['linear_solver']='umfpack'
fileu = File("test/disp.pvd")
fileu << w.sub(0)
track = 0.0
tsteps = 0.0
totalT = 100
dt = 1.0
while(track<=totalT):
	solver.solve()
	phiold = phi
	phi = as_vector([(phiold[k] + (k0 + k1*sigmax*fact[k]*fedot[k])*phim - kd*phiold[k]) for k in range(0,n)])
	phivt = phi[0]
	phim = (phitotal -(phivt/n))
	PHIv =  project(phi, WQ) ##The error happens here
	fileu << w.sub(0)
	tsteps = tsteps + dt
	track = track+dt
	if tsteps < totalT:
		ux.m0 = ux.m0+0.01
Can anybody shade some light on this issue? I need to extract the phi value over a node or a specific point in a mesh.
Could you reduce this problem to a minimal working example which reproduces your error? In its current form it’s not immediately compatible with the latest version of DOLFIN.
Hi Nate, thank you for prompt reply.
I tried to shorten the code. The error happens at following line under while loop:
PHIv =  project(phi, WQ) #Jit Error happens here
I tried to shorten the code in following way. will it work?
import sys
deg = 4
le = 1.0  #length
wd = 1.0  #width
ht = 0.1  #height
#Mesh create
n = 20
w = Function(W)
(u, c) = split(w)
tTot = 100
T1st = tTot /2
value = 0.0
#Faceboundaries
left = Left()
right = Right()
back = Back()
#Continuum formulation
I = Identity(d)
F = I + grad(u)
C = F.T*F
J = det(F)
n0 = J*inv(F.T)*N
E = (F.T*F - I)*0.5
Enh = 1.0E6 #Pa
nu = 0.19
G = Enh/(2*(1+nu))
piola = J*sigmaNH*inv(F.T)
Ftotal = F1 + F2
Jac = Jac1 +Jac2
thetain = -pi/2
dtheta = pi/n
K = 0.0
E0 = 0.12
THETA = []
phitotal = Constant((0.05))
phivt = phi[0]
track = 0.0
tsteps = 0.0
totalT = 100
dt = 1.0
while(tsteps<=totalT):
	solver.solve()
	phiold = phi
	## Updating Phi
	phi = as_vector([(phiold[k] + (7.0E-7*strain[k])*phim - 1.0E-3*phiold[k]) for k in range(0,n)])
	phivt = phi[0]
	ux.m0 = ux.m0+0.002
You are using Python2, indicating that you are using a version of FEniCS prior to the 2018.1.0 release. This is quite outdated, and I would strongly encourage you to update to a newer version with python3.
Another thing that seems strange to me is that you do not update w in your while loop. However, I must admit it is very hard for me to tell what you want to do, as your example is far from minimal.
To me, it seems like your projection loop is fully decoupled from the problem you are solving.
Hi, thanks for replying.
The error was updating phi under while loop. Since it was declared under while loop, the form was getting bigger at each time step and taking longer time to project. I solved that issue.
import sys, pdb
deg = 4
le = 1.0  #length
wd = 1.0  #width
ht = 0.1  #height
#Mesh create
n = 20
w = Function(W)
(u, c) = split(w)
tTot = 100
T1st = tTot /2
value = 0.0
#Faceboundaries
left = Left()
right = Right()
back = Back()
I = Identity(d)
F = I + grad(u)
C = F.T*F
J = det(F)
n0 = J*inv(F.T)*N
E = (F.T*F - I)*0.5
Enh = 1.0E6 #Pa
nu = 0.19
G = Enh/(2*(1+nu))
Ftotal = F1 + F2
Jac = Jac1 +Jac2
thetain = -pi/2
dtheta = pi/n
K = 0.0
E0 = 0.12
THETA = []
phiold = Function(WQ)
phinew = Function(WQ)
phiold.vector()[:] = 0.0
phinew.vector()[:] = 0.0
phi = as_vector([(phiold[k] + (7.0E-7*strain[k]) - 1.0E-3*phiold[k]) for k in range(0,n)])
track = 0.0
tsteps = 0.0
totalT = 100
dt = 1.0
while(tsteps<totalT):
	solver.solve()
	phinew.vector()[:]= project(phi,WQ).vector().array()[:]
	phiold.vector()[:] = phinew.vector().array()[:]
	print tsteps
	print phinew.vector().array()
	ux.m0 = ux.m0+0.002
