My apologies, I am attaching the full code below.
solve the problem with the following code:
V_element = basix.ufl.element("DG", mesh.basix_cell(), poly_o, shape=(4,))
V = dolfinx.fem.functionspace(mesh, V_element)
but I have the following problem that I solved by changing the directory file [.local\lib\python3.10\site-packages\dolfin_dg\dg_form.py], but I don’t know if it was the best option because it could affect other functions.
Change
return u.ufl_element().degree()
To
This is the error that appears if you do not make the change in the address mentioned in Dolfin_dg:
File "/home/oscar/code/viskex/dg_naca0012_2d.py", line 131, in <module>
F = ce.generate_fem_formulation(u_vec, v_vec, h_measure=h, c_ip=20.0)
File "/home/oscar/.local/lib/python3.10/site-packages/dolfin_dg/operators.py", line 439, in generate_fem_formulation
F += apply_interior_penalty(
File "/home/oscar/.local/lib/python3.10/site-packages/dolfin_dg/operators.py", line 146, in apply_interior_penalty
alpha, _ = dolfin_dg.penalty.interior_penalty(
File "/home/oscar/.local/lib/python3.10/site-packages/dolfin_dg/penalty.py", line 93, in interior_penalty
p = dolfin_dg.dg_form._get_ufl_element_degree(u)
File "/home/oscar/.local/lib/python3.10/site-packages/dolfin_dg/dg_form.py", line 50, in _get_ufl_element_degree
TypeError: 'int' object is not callable
ALL CODE:
import basix.ufl
import dolfinx.fem.petsc
import dolfinx.nls.petsc
import dolfin_dg
import dolfin_dg.dolfinx.dwr
import dolfin_dg.dolfinx.mark
import viskex
import generate_mesh
# In this example we use dual weighted residual based error estimates
# to compute the drag coefficient of compressible flow around a NACA0012
# aerofoil.
def info(*msg):
PETSc.Sys.Print(", ".join(map(str, msg)))
mesh = generate_mesh.generate_naca_4digit(
MPI.COMM_WORLD, *generate_mesh.parse_naca_digits("0012"), rounded=False,
gmsh_options={"Mesh.MeshSizeFromCurvature": 80})
# Polynomial order
poly_o = 1
# Initial inlet flow conditions
rho_0 = 1.0
M_0 = 0.5
Re_0 = 5e3
p_0 = 1.0
gamma = 1.4
attack = np.radians(2.0)
# Inlet conditions
c_0 = abs(gamma*p_0/rho_0)**0.5
Re = Re_0/(gamma**0.5*M_0)
n_in = dolfinx.fem.Constant(
mesh, np.array([np.cos(attack), np.sin(attack)], dtype=np.double))
u_ref = dolfinx.fem.Constant(mesh, M_0*c_0)
rho_in = dolfinx.fem.Constant(mesh, rho_0)
u_in = u_ref * n_in
# The initial guess used in the Newton solver. Here we use the inlet flow.
rhoE_in_guess = dolfin_dg.aero.energy_density(p_0, rho_in, u_in, gamma)
gD_guess = ufl.as_vector((rho_in, rho_in*u_in[0], rho_in*u_in[1], rhoE_in_guess))
# Assign variable names to the inlet, outlet and adiabatic wall BCs. These
# indices will be used to define subsets of the boundary.
INLET = 3
OUTLET = 4
WALL = 2
# Record information in this list
results = []
# Maximum number of refinement levels
n_ref_max = 3
for ref_level in range(n_ref_max):
info(f"Refinement level {ref_level}")
# Label the boundary components of the mesh. Initially label all exterior
# facets as the adiabatic wall, then label the exterior facets far from
# the aerofoil as the inlet and outlet based on the angle of attack.
bdry_facets = dolfinx.mesh.locate_entities_boundary(
mesh, mesh.topology.dim-1,
lambda x: np.full_like(x[0], 1, dtype=np.int8))
midpoints = dolfinx.mesh.compute_midpoints(
mesh, mesh.topology.dim-1, bdry_facets)
f_normals = dolfinx.cpp.mesh.cell_normals(
mesh._cpp_object, mesh.topology.dim-1, bdry_facets)
inner_facets = np.linalg.norm(midpoints, axis=1) < 10.0
inlet = np.dot(f_normals[:,:2], n_in.value) < 0.0
values = np.zeros(midpoints.shape[0], dtype=np.int32)
values[inlet] = INLET
values[~inlet] = OUTLET
values[inner_facets] = WALL
fts = dolfinx.mesh.meshtags(mesh, mesh.topology.dim-1, bdry_facets, values)
ds = ufl.Measure('ds', domain=mesh, subdomain_data=fts)
# Problem function space, (rho, rho*u1, rho*u2, rho*E)
V_element=basix.ufl.element("DG", mesh.basix_cell(), poly_o, shape=(mesh.geometry.dim,))
#V = dolfinx.fem.VectorFunctionSpace(mesh, ("DG", poly_o), dim=4) old version
n_dofs = mesh.comm.allreduce(
V.dofmap.index_map.size_local * V.dofmap.index_map_bs, MPI.SUM)
info(f"Problem size: {n_dofs} degrees of freedom")
u_vec = dolfinx.fem.Function(V, name="u")
if ref_level == 0:
# Use the initial guess.
u_vec.interpolate(
dolfinx.fem.Expression(gD_guess, V.element.interpolation_points()))
# Initial guess by interpolating from old mesh to new mesh
interp_data = dolfinx.fem.create_nonmatching_meshes_interpolation_data(
u_vec.function_space.mesh._cpp_object,
u_vec.function_space.element,
u_vec_old.function_space.mesh._cpp_object, padding=1e-4)
u_vec.interpolate(u_vec_old, nmm_interpolation_data=interp_data)
u_vec.x.scatter_forward()
v_vec = ufl.TestFunction(V)
# The subsonic inlet, adiabatic wall and subsonic outlet conditions
inflow = dolfin_dg.aero.subsonic_inflow(rho_in, u_in, u_vec, gamma)
no_slip_bc = dolfin_dg.aero.no_slip(u_vec)
outflow = dolfin_dg.aero.subsonic_outflow(p_0, u_vec, gamma)
# Assemble these conditions into DG BCs
bcs = [dolfin_dg.DGDirichletBC(ds(INLET), inflow),
dolfin_dg.DGAdiabticWallBC(ds(WALL), no_slip_bc),
dolfin_dg.DGDirichletBC(ds(OUTLET), outflow)]
# Construct the compressible Navier Stokes DG formulation, and compute
# the symbolic Jacobian
h = ufl.CellVolume(mesh)/ufl.FacetArea(mesh)
ce = dolfin_dg.CompressibleNavierStokesOperator(mesh, V, bcs, mu=1.0/Re)
J = ufl.derivative(F, u_vec)
# Set up the problem and solve
problem = dolfinx.fem.petsc.NonlinearProblem(F, u_vec, J=J)
solver = dolfinx.nls.petsc.NewtonSolver(mesh.comm, problem)
def updater(solver, dx, x):
# TODO: This causes a memory leak
tau = 1.0
theta = min((2.0*tau/dx.norm())**0.5, 1.0)
x.axpy(-theta, dx)
solver.set_update(updater)
ksp = solver.krylov_solver
opts = PETSc.Options()
ksp.setFromOptions()
solver.solve(u_vec)
# Assemble variables required for the lift and drag computation
n = ufl.FacetNormal(mesh)
rho, u, E = dolfin_dg.aero.flow_variables(u_vec)
p = dolfin_dg.aero.pressure(u_vec, gamma)
l_ref = dolfinx.fem.Constant(mesh, 1.0)
tau = 1.0/Re*(ufl.grad(u) + ufl.grad(u).T - 2.0/3.0*(ufl.tr(ufl.grad(u)))*ufl.Identity(mesh.geometry.dim))
C_infty = 0.5*rho_in*u_ref**2*l_ref
# Assemble the homogeneity tensor with dot(grad(T), n) = 0 for use in the
# adjoint consistent lift and drag formulation
sigma = dolfinx.fem.Constant(mesh, 20.0)*dolfinx.fem.Constant(mesh, float(max(poly_o**2, 1)))/h
import dolfin_dg.primal.aero
F_v_adiabatic = dolfin_dg.primal.aero.compressible_navier_stokes_adiabatic_wall(
u_vec, v_vec, gamma=gamma, mu=1/Re).F_vec[1]
G_adiabitic = dolfin_dg.math.homogeneity_tensor(F_v_adiabatic, u_vec)
G_adiabitic = ufl.replace(G_adiabitic, {u_vec: no_slip_bc})
# The drag coefficient
psi_drag = n_in
drag = 1.0/C_infty*ufl.dot(psi_drag, p*n - tau*n)*ds(WALL)
# The adjoint consistent drag coefficient
z_drag = 1.0/C_infty*ufl.as_vector((0, psi_drag[0], psi_drag[1], 0))
drag += ufl.inner(
sigma*dolfin_dg.math.hyper_tensor_product(G_adiabitic, ufl.outer(u_vec - no_slip_bc, n)),
ufl.outer(z_drag, n))*ds(WALL)
# The lift coefficient
psi_lift = dolfinx.fem.Constant(
mesh, np.array([-np.sin(attack), np.cos(attack)], dtype=np.double))
lift = 1.0/C_infty*ufl.dot(psi_lift, p*n - tau*n)*ds(WALL)
drag_val = mesh.comm.allreduce(
dolfinx.fem.assemble_scalar(dolfinx.fem.form(drag)), MPI.SUM)
lift_val = mesh.comm.allreduce(
dolfinx.fem.assemble_scalar(dolfinx.fem.form(lift)), MPI.SUM)
info(f"DoFs: {n_dofs}, Drag: {drag_val:.5e}, Lift: {lift_val:.5e}")
results += [(n_dofs, drag_val, lift_val)]
with dolfinx.io.VTXWriter(
mesh.comm, f"adapted_naca0012_meshes_{ref_level}.bp",
[u_vec.sub(0).collapse()], "bp4") as f:
f.write(0.0)
# If we're not on the last refinement level, apply goal oriented
# dual-weighted-residual error estimation refinement.
if ref_level < n_ref_max - 1:
V_star = dolfinx.fem.VectorFunctionSpace(mesh, ('DG', poly_o+1), dim=4)
V_star.dofmap.index_map.size_local * V_star.dofmap.index_map_bs, MPI.SUM)
info(f"Computing a posteriori error estimates:\n"
f"Dual space problem size: {n_dofs} degrees of freedom")
est = dolfin_dg.dolfinx.dwr.NonlinearAPosterioriEstimator(
J, F, drag, u_vec, V_star)
indicators = est.compute_indicators(petsc_options={
"ksp_type": "preonly",
"pc_type": "lu",
"pc_factor_mat_solver_type": "mumps"})
cell_markers = dolfin_dg.dolfinx.mark.maximal_indices_fraction(
indicators, 0.1)
info("Refining mesh")
edges_to_ref = dolfinx.mesh.compute_incident_entities(
mesh.topology, cell_markers, mesh.topology.dim, 1)
new_mesh, _, _ = dolfinx.cpp.refinement.refine_plaza(
mesh._cpp_object, edges_to_ref, True,
dolfinx.mesh.RefinementOption.none)
new_mesh = dolfinx.mesh.Mesh(
new_mesh, ufl.Mesh(mesh._ufl_domain.ufl_coordinate_element()))
mesh = new_mesh
u_vec_old = u_vec
if mesh.comm.rank == 0:
for result in results:
print("DoFs: {:d}, Drag: {:.5e}, Lift: {:.5e}".format(*result))
The library Dolfin_dg can be found at the following link:Dolfin_dg_NATE_SIME
