Iterative Solver Convergence in High Aspect Ratio Models
Hi all,
I’m using DOLFINx version 0.8.0 to solve a coupled system in a beam model, but I’m facing convergence issues with high aspect ratio geometries. For the case of only linear elasticity problem in a beam model, with an aspect ratio of 2 (width = 50, length = 100), the simulation converges in 9.4 seconds with 11 iterations. However, when the aspect ratio increases to 20 (length = 1000), the iterative solver runs indefinitely without converging. I tried a denser mesh, but it had no effect.
The code works fine with a direct solver, but due to problem size, I need to use an iterative solver.
Here is a simplified code for a linear elasticity problem:
import pyvista
import math
from dolfinx.fem import (Constant, Function, functionspace, assemble_scalar, dirichletbc, form, locate_dofs_geometrical,
                         locate_dofs_topological, assemble, locate_dofs_topological, Expression)
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_vector, set_bc, LinearProblem
from dolfinx.io import XDMFFile, VTXWriter, gmshio
from dolfinx.mesh import create_unit_square, locate_entities, meshtags, locate_entities_boundary, create_box, CellType, exterior_facet_indices
from ufl import (FacetNormal, Identity, TestFunction, TrialFunction,
                 div, dot, dx, inner, lhs, nabla_grad, rhs, sym, indices, as_tensor, Measure, split, action,
                 SpatialCoordinate)
import time
from dolfinx import la
print(
    f"DOLFINx version: {dolfinx.__version__} based on GIT commit: {dolfinx.git_commit_hash} of https://github.com/FEniCS/dolfinx/")
start = time.time()
################# Material Properties
E = 1 * 190e9
nu = 0.3
laa = E * nu / ((1 + nu) * (1 - 2 * nu))
mu = E / (2 * (1 + nu))
# ......................................... Reading mesh file
H = 50
L = 1000
mesh = create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([L, H, H])],[15, 15, 15], cell_type=CellType.tetrahedron)
# ......................................... Define Loading
Force = 10
Area = H * H
tr = Force / Area
tr_top = Constant(mesh, ScalarType((0, 0, -tr)))
# ......................................... Define Elements
MIXEL = element("Lagrange", mesh.basix_cell(), 2, shape=(mesh.geometry.dim,))  # Displacement Element
Space = functionspace(mesh, MIXEL)
# ......................................... Define Trail and Test Functions
u = TrialFunction(Space)
del_u = TestFunction(Space)
# ....................................... Mark boundary regions
tol = 1e-14
def Left(x):
    return np.isclose(x[0], 0, atol=tol)
# ....................................... ds
boundaries = [(1, lambda x: np.isclose(x[0], 0.0, atol=tol)),
              (2, lambda x: np.isclose(x[0], L, atol=tol)),
              (3, lambda x: np.logical_and(np.isclose(x[0], 0, atol=tol), np.isclose(x[2], 0, atol=tol)))]
fdim = mesh.topology.dim - 1
    facets = locate_entities(mesh, fdim, locator)
    facet_indices.append(facets)
facet_tag = meshtags(mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = Measure("ds", domain=mesh, subdomain_data=facet_tag)
# ....................................... BCs
clamp_facets = locate_entities_boundary(mesh, mesh.topology.dim - 1, Left)
clamp_dofs= locate_dofs_topological(Space, mesh.topology.dim - 1, clamp_facets)
bc0 = dirichletbc(np.array([0,0,0], dtype=default_scalar_type), clamp_dofs, Space)
bc = [bc0]
# ......................................... Define tensor
delta = Identity(len(u))
i, j, k, l  = indices(4)
# Strain Tensor
def StrainT(u):
    return as_tensor((1. / 2. * (u[i].dx(j) + u[j].dx(i))), [i, j])
# Stress Tensor
def Elas(la, mu):
    return as_tensor(laa * delta[i, j] * delta[k, l] + 2. * mu * delta[i, k] * delta[j, l],
                     (i, j, k, l))  # Elasticity tensor
def StressT(u):
    return as_tensor((Elas(laa, mu)[i, j, k, l] * StrainT(u)[k, l]), [i, j])
# ......................................... Define Variational Formulation
a = StressT(u)[j, k] * StrainT(del_u)[j, k] * dx
L = tr_top[i] * del_u[i] * ds(2)
#.................................................SOLVER
########## Iterative SOLVER
if mesh.comm.rank == 0:
    print("Assembling...")
bilinear_form = form(a)
linear_form = form(L)
A = assemble_matrix(bilinear_form, bcs=bc)
b = create_vector(linear_form)
with b.localForm() as b_loc:
    b_loc.set(0)
assemble_vector(b, linear_form)
apply_lifting(b, [bilinear_form], [bc])
b.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)  # if run in parrallel
set_bc(b, bc)
b.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
Result = Function(Space)
def monitor(ksp, it, rnorm):
        print(f"iteration: {it} rnorm: {rnorm:.3e}")
solver = PETSc.KSP().create(mesh.comm)  # type: ignore
# # Set solver options
opts = PETSc.Options()  # type: ignore
opts["ksp_type"] = "gmres"
opts["ksp_rtol"] = 1e-4
opts["ksp_max_it"] = 70000
opts["pc_type"] = "hypre"
opts["pc_hypre_type"] = "boomeramg"
solver.setFromOptions()
solver.setOperators(A)
solver.setMonitor(monitor)
solver.solve(b, Result.vector)
    print(solver.getConvergedReason())
Result.x.scatter_forward()
# ......................................... Export Results
with VTXWriter(mesh.comm, ("Beam/DIS.bp"), [Result]) as vtx:
    vtx.write(0.0)
end = time.time()
    print('Time', end - start)
Thanks
I was wrong in thinking the iterative solver was running indefinitely without converging. It turns out the code does converge, but at a very low rate. After some research, I suspect this could be a locking issue that occurs with beam structures. Any suggestions on how to address this?
Are you actually observing locking in the solution field?
Typically locking in beam bending occurs when you have very few linear elements through the thickness. Essentially, the linear displacement field cannot represent the smooth bending curve well enough. The only deformation that the piecewise linear field permits (the trapezoidal shape), is one where it has incredibly strong bending resistance.
The solution to avoid shear locking would be to refine in the height direction, or to use P2 elements. But i see that you’re already using 15 elements in the height, that’s why I wonder if this is really the issue.
Poor aspect ratios tend to mess up the conditioning of your system matrix, giving iterative solvers a hard time. To make them work requires very careful preconditioning. Maybe the AMG preconditioner is not tuned right? Have you experimented with different preconditioners?
Thank you for your response. I’m not entirely sure if this is a locking issue. I’m still investigating, and as you mentioned, it seems more likely to be related to the preconditioner. I’ve tried using other preconditioners, but I haven’t observed any improvement.
To get some insights, you could:
Increase the number of elements in the length direction, until they have proper aspect ratios again. Of course, the solve may take longer (and perhaps too long for your application) but it would be interesting to see if the number of gmres iterations goes down. Then it is indeed an aspect ratio related preconditioning issue.
Reduce the number of elements by a factor two in all directions, and use P2 elements. The dof number remains the same, but the solution will not be forced into a shear-locking mode, which are the modes corresponding to the bad eigenvalues that would cause poor convergence of your iterative solver. (Not actually sure if that should help GMRes though…)
